#100408
Mon Apr 21 2008 12:26 PM
Posts: 2,131 Likes: 76
Posts: 2,131 Likes: 76 |
This months POTM will be the Wayne 50. The Wayne 50 was produced between 1935 thru 1938. There were two different versions of this pump. The 50 had an inside sight gauge and the showcase had rounded corners. The 50A had an exterior sight gauge and the corners of the showcase where more square. The head on the 50A was similar to the second version of the 40A. The overall dimensions without the globe is 19 1/2" X 33 1/2" X 83 1/2" tall. Serial numbers for the 50 are: 1935 350-BBA to 15001-BBA 1936 1825-BDB to 25019-BDB 1937 25023-BDB to 45947-BDB 1937 40196-BDV to 50163-BDV 1938 52645-BDV to 65013-BDV The breakdown will be for a 50A. The serial number on this particular pump is 3345-BAA. I'm guessing that it was produced in 1935. The base is 19 1/2" X 33 1/2" X 3 3/4" tall. These next pictures show the lower legs and the brackets that are used to connect the lower inside shelf and inside trim pieces. The lower legs are 53 9/16" long. The next series of pictures show the lower panles. The side panels are 15 1/2" X 15" and have a vent. One side has a round inspection door. The front panels are 29 1/4" X 15" and have the T slot so the retainer key assemblies can be used. [This message has been edited by gatorgaspumps (edited 04-21-2008).]
#100409
Mon Apr 21 2008 12:50 PM
These next series of pictures show the upper support bracket for the side with the door, and the lock assembly on the leg for the door. This lock assembly was not complete, the inside lock portion is missing. The hole for the lock is 1/2" and the lock tube extends out 1/2". This set of pictures show the lower shelf. It is 16 3/4" X 30 1/2". These pictures show the top of the show case portion. It is 18 1/4" X 32 3/8" X 1 3/4" tall. The alignment of all the parts of this pump is very critical. You must install the legs to the base then the lower shelf, leaving the bolts loose on the shelf. Next attach the lower panels. When they fit properly tighten the lower shelf. You then put the support bracket above the door on the legs. Next you will put the top of the showcase on. There are 1/16" rubber spacers that fit between the legs and the top. Do not tighten the screws yet. Next you need to put the door and show case windows in. Now you can add more spacer rubbers so as you tighten the top you have the correct spacing all the way around the shows case windows. Once the top is in place remove the windows and door. [This message has been edited by gatorgaspumps (edited 04-21-2008).]
#100410
Mon Apr 21 2008 01:04 PM
The next step is to install the conduit that runs up the leg and the light assembly that attaches to the bottom side of the showcase top. These pictures show those parts. The head can now be assembled. The upper set of pictures show the upper legs and key assembly. The upper legs are 20" long. The pictures below that show the step out side assembly for the head. The top is 13" X 17 1/2" X 6" tall. In the middle picture you can see the hole where the sight glass attaches. This pump did not have a globe attached so a rounded globe hole protector was installe. [This message has been edited by gatorgaspumps (edited 04-21-2008).]
#100411
Mon Apr 21 2008 01:13 PM
These next series of pictures show the nozzle receiver, nozzle fork, sight glass, and head light assembly. The next set of pictures show the meter brackets, meter, and original faceplate. The meter and faceplate are the same ones that are used on the Wayne 40. This picture shows the face bezel. It is also the same one as used on the 40 [This message has been edited by gatorgaspumps (edited 04-21-2008).]
#100412
Mon Apr 21 2008 01:22 PM
After all the parts to the head are installed we can now go back and finish up the show case portion. The next pictures show the top panel. It is 16 3/4" X 30 1/2". The center support bracket is 3/4" chrome pipe, 35 1/2" long. It has two adjustable shelf brackets. This picture shows the stainless steel corner bracket with clips, and the glass shelf. This corner bracket is 34 5/8" long. There are two sizes being re-popped by Ron Scobie a 34 5/8" and a 34 5/16". [This message has been edited by gatorgaspumps (edited 04-21-2008).]
#100413
Mon Apr 21 2008 01:31 PM
These pictures show the doorframe, which is 15 1/4" X 37 3/8". These pictures show the window frames. The side window is 15 1/4" X 37 3/8". the front and back windows are 29 3/4" X 37 3/8". The two screws pictured on the left are used on the windows. The screw on the left connects the window frame to the legs. It is 1/4 X 1/4 fine thread. I thought this round headed screw was original but it is not. The original screw are the same as used on the Wayne 60 to connect the face bezels to the legs. The screw on the right is original. They connect the glass frame to the window frame. They are a pan head 1/4 X 1/8 course thread. This is the finished pump with a Bear Cat Globe. I used PPG DCC 4679 Flame Red, DCC 909966 Gold/Brown but changed the mix trying to match the decal, (one quart mix DMC900-604.7, 908-399.8, 925-114.8, and 929-37), and the shelves were DCC 27440 Beige. Would Love to see any other 50's out there, if you need help posting send them to me and I will be glad to post for you. Richard [This message has been edited by gatorgaspumps (edited 04-21-2008).]
#100414
Mon Apr 21 2008 10:59 PM
Posts: 263 |
These are my favorite posts on oldgas because you can learn so much. It took a long time for you to post this information and it is appreciated.
That is one beautiful pump!
Thank you again for posting this great information!
Posts: 5,980 Likes: 24
Posts: 5,980 Likes: 24 |
Posts: 274 |
Posts: 2,084 |
Why don't we do POTM anymore
The answer is real easy....
No one would do a Month, except the same Members. These Members were stuck doing the thread; Month after Month after Month with no help.... Some Members that had a specific pump relating to a Month, would participate... But, most Members would not....
IMO, it is the same reason Shawn is the only one doing the COTM. And has been for the last 6 months or so... Members like to look, but they want the other guy to do all the work...
When I did the expanded Tydol/Associated COTM... I noticed that more than a few Members, instead of participating in the thread and posting images of their items... Would instead post their images in the For Sale Forum.... They didn't/don't care about the site, instead their commitment is geared towards themselves and their only interest in Oldgas is..... What can Oldgas do for them, not what they can do to make the site better.....
Same reason that the same "handful" of Members answer the questions about "history" on the site....
Why do research on a Company(s).... Let someone else do the "hard work"....
Those that have joined Oldgas in the last 3-5 years have missed out on so much... Curt and his histories of the Buellton/ Santa Ynez/ Santa Barbara Area... And how the area became "Gas Station City" and then when the Interstate by passed the area.... It all changed....
Other threads from Members with decades of experience they were willing to share... But, too many "New Members" could care less about the history of the Company's or the history of the Hobby... Instead their interests laid and in the case of oh so many; still lay in what they can add to their pocketbooks.
So for many of the "longtime Hobbyists, Oldgas became a place they didn't understand anymore... It wasn't about the Hobby anymore or knowledge or sharing.... For the first time it was about "what is this worth"? So they left!
Well said & VERY TRUE Bob. Very few questions are asked that can't be Found by doing a Simple Search thru Google at bottom of ALL pages. OVER 15,000 members & only a Hand Full post/reply!
IF your afraid of getting a Blunt/S.A. answer, you should have done the searching.
Posts: 3,423 Likes: 19
Posts: 3,423 Likes: 19 |
dont generalize all 'new' members... just saying. i recently posted all the local Cities Service history I currently have, to help members look at Cities Service as a whole and not only gas/service stations & am always interested in contributing & reading more everyday. in regards to the search... its tough sometimes to find what you are looking for. for example, if a new member was to search Cities Service on oldgas, they would get thousands of useless threads before finding one of interest. I search the archives all the time... just last week I finally came across an old Cities Service COTM thread, it is now bookmarked in my browser There are cans pictured in that thread that I didnt even know existed! http://www.oldgas.com/shoptalk/ubb/Forum4/HTML/001673.html
I must have missed where someone "generalized about ALL NEW MEMBERS"....
As to it being tough to find what one is looking for? What the hell? It takes seconds to sometimes minutes to find an answer... That is tough?
Like I said, I also don't understand Oldgas nor a lot of those in the Hobby, right now...
We have it so easy! Imagine what Hobbyists from the 40s through the 1990s would have given to have such info at the touch of a finger.... Oh wait, I don't have to imagine... I am one of those people....
I remember quite well, sending out 20 to 30 letters in the 1960s -1990s by what is considered "snail mail", everytime I had complex questions about the Hobby, items in the Hobby and Company(s) in the Hobby... Asking Collectors across the US questions about specific Company(s)... And waiting for weeks, most likely months for an answer... Now I can get the same info in greater detail by typing on the computer keyboard and clicking a mouse key...
There is nothing tough about having to scroll through some information on a computer!...
(Oh for the record, Bryce... It took me less than 30 secs to find Cities Service COTM on my computer... Both of the COTM's based on the Cities Service Company... The Jan '07 and Nov '13 versions...)
Posts: 735 |
So for many of the "longtime Hobbyists, Oldgas became a place they didn't understand anymore... It wasn't about the Hobby anymore or knowledge or sharing.... For the first time it was about "what is this worth"? So they left! Very Well Said; "Hit the Nail on the Head"
Bob, you misunderstood what i was trying to say... I was just simply implying that there are new members, such as myself and others, that try to contribute and add to this forum as much as we gain from it
Heres a photo of mine as I picked it up! Its currently been reduced to a pile of sand blasted sheet metal and parts! I'd have loved to have it as a firestone pump, but this will be a black/white Cities Service pump. I hope it turns out as well as Matts did!
Bryce, believe it or not... Those that have been on Oldgas and in the Hobby for a period of time. Do notice that you and some other New Members are "doers/givers" not "takers"... But, honestly you folks are and have been the exceptions to "the rule", in the last few years...
And I did misunderstand your point and I apologize for that...
A PS: Normally I would have sent this to Bryce in a PM. But, since I made my comments "in Public".. I felt that I should also apologize "in Public"....
Thanks Kevin for getting this thread back to pumps. Here is one that comes up on craigs list as a want ad looking for display pumps and one I found surfing the web one day.
I have the Firestone signs for the sides now I just need to find the pump! LOL!
Keith--You'd better star collecting all the Firestone stuff you can, so you'll have it when the pump is done! I know Matt didn't find all those nice items in a single day, week month!!
Posts: 327 |
show me more, show me more,
Here is Tom Schillings (dundign) Wayne 50. Hope he does not mind me posting it. It was posted on oldgas when he first finished it by another oldgasser for him so it should be OK. Nice pump, it looks much better than the black that it was when you first got it.
Posts: 1,627 |
Thanks Matt ..No problem. Tom
I have some more pictures of Wayne 50s but some I do not know whos they are and some are or were oldgas members. I posted Tom`s because I was 99% sure it would be OK. Not sure if it would be OK on the others. If you guys want me to post them I will.
Posts: 4,293 Likes: 27
Posts: 4,293 Likes: 27 |
I feel like us "New Members" have missed out on some amazing people and information in this hobby. Times change…I try to learn as much as I can by searching, asking questions, and simply paying attention to peoples comments and threads.
