#124446
Tue Feb 19 2008 04:14 PM
Posts: 107 |
Need the inspection doors for a gilbarco 87,they fit below the outer casting frame.
mona mike
#124447
Tue Feb 19 2008 07:07 PM
Posts: 1,672 Likes: 13
Posts: 1,672 Likes: 13 |
I thought only the G&B 86 had inspection doors below the bezel? My 87 has no inspection doors below the bezel. I was always told that's how you could tell 86 doors from 87 doors. No need for the doors on a clock pump. I've seen people weld in plates on the 86 doors to make them look like 87 doors when finished.
KJV Psalms 16:11
#124448
Tue Feb 19 2008 07:49 PM
Posts: 107 |
this clock pump has got a hole in each door for a inspection plate.
mona mike
#124449
Tue Feb 19 2008 08:09 PM
I realize that but I think your doors have been swapped out sometime over the years with 86 doors. This is not un-common. The 87's never had the inspection doors, no need for them. I would weld in a patch to get rid of the opening and once the body work is done no one will know. I can post a pic. of my 87 doors w/o openings if needed.
KJV Psalms 16:11
#124450
Wed Feb 20 2008 05:18 AM
Posts: 246 |
Mike is right 87's did not have inspection doors but you can make them out of sheet metal and get the clips for the 36B tokheim from gas pump heaven and make a nice copy. I think I have one to go buy if you need the measurements Thanks Blair Underwood 704-485-8839 Petrolights
#124451
Wed Feb 20 2008 05:22 AM
Posts: 3,389 Likes: 40
Posts: 3,389 Likes: 40 |
I have an 87 and the doors are much shorter than the 86, were they all like this
------------------ Visit 15th Annual MASS GAS BASH September 7th 2008
#124452
Wed Feb 20 2008 11:57 AM
Posts: 246 |
Do not know what kind of 87 KZ1000 has but have measured 4 87 doors and 6 86 doors and all are just a shade over 86". Thanks Blair
#124453
Wed Feb 20 2008 11:59 AM
Posts: 246 |
Sorry for the typo, 66" Blair
#124454
Wed Feb 20 2008 03:06 PM
Posts: 107 |
thanks for everyones assistance, special thanks to Blair Mike
mona mike
#124455
Wed Feb 20 2008 07:40 PM
Posts: 1,728 Likes: 19
Posts: 1,728 Likes: 19 |
For what it's worth, the GB 87 AR parts breakdown DOES show the pump as having two "Inspection" doors... Ron
#124456
Wed Feb 20 2008 07:51 PM
Thanks Ron, I have 2 G&B 87 clockfaces and 3 86's, the 2 87's are at least 12" shorter than the 86's, and the one 87 with doors has the 2 inspection doors.
#124457
Fri Feb 22 2008 12:40 PM
Well, I've never seen a shorter 87. Sounds like you have 2 that have been cut down for some reason. I have had 86's and 87's and they are identical in height and width. It is possible to see 87's with the inspection doors since the pumps were made at the same time as the 86's. I guess G&B used which ever door was being run at the time. I will post a pic. of my 87 w/o inspection door. If you will look at an 87 though you will see that there would have been no use whatsoever for an inspection door below the face.
KJV Psalms 16:11
#124458
Fri Feb 22 2008 03:12 PM
Posts: 107 |
Mike I could not agree with more there is no need for the inspection doors , But like Ron said the breakdown does show doors on the GB 87, Mine is the GB 87 AR119 thanks for you input. Mike
mona mike
#124459
Fri Feb 22 2008 03:14 PM
Posts: 107 |
also the doors are 66 7/16" tall Mike
mona mike
#124460
Sat Feb 23 2008 10:06 AM
Here's my 87 with No inspection doors. For what it's worth I also just missed another 87 that a local picker found. He sold it a few hours before I got there but I did look at it. It had No inspection doors either. Mike
KJV Psalms 16:11
#124461
Sat Feb 23 2008 01:36 PM
Here is 1 of my 87's, total height is approx. 65", I have another exactly like it, and I looked at 2 more this morning that a friend of mine owns and both of them were also 65" tall, Very odd to have 4 of the short versions that don't exist, 2 came from Vermont, 1 from a farm in western Mass, and 1 from Springfield Mass where the Gas Pumps were made. Note my pump has the access doors. Anybody else have or seen a short 87 ------------------ Visit 15th Annual MASS GAS BASH September 7th 2008 [This message has been edited by KZ1000 (edited 02-23-2008).]
#124462
Sat Feb 23 2008 06:10 PM
Interesting indeed. Gilbarco's were also made right here in Greensboro,NC. All I've seen here are exactly the same height. My 86 and 87 are identical except for one being a clockface. Most all 87's here in NC don't have the inspection doors. I've only seen one that did and figured it had the wrong doors on it. I know where a few more are still out on the farms being used and the 87's don't have the inspection doors on them either. I have never seen one version shorter than the other here in NC. We have tons of 86's and 87's around here along with every other type of G&B since they were the most common pump in NC. Actually it was 1966 when Gilbarco moved to NC. I had to drag out my old Gilbarco book but I find nothing on a shorter 87. Anyone else have a clue why KZ1000 has these shorty versions?
[This message has been edited by Mike Smith (edited 02-23-2008).]
KJV Psalms 16:11
#124463
Sat Feb 23 2008 07:57 PM
Even more interesting is G&B (Gilbert & Barker) did not move to North Carolina till 1965, Before that all the G&B and Gilbarco pumps were made in Springfield Mass. Look at any ID tag, I myself have never seen an early pump with North Carolina on the tag
