#127387 - Sat Jan 28 2006 12:20 PM
Re: Paint Removal By Electrolysis
Loc: Nebraska
I use the 15 amp setting on my charger. If the water is 65 degrees or warmer you should start seeing little bubbling near the metal and later some foam. This is a sign it's working. If you don't, the water might be too cold or you might not be getting a good connection at the alligator clips. I did learn to unplug the charger when touching the alligator clips. One very calm morning, while removing a door for my barrel, I removed one of the clips causing a spark. Evidently I had made enough hydrogen to be "set off" by the spark. It sounded like a shotgun going off. Not to mention giving me the feeling I'd just been shot at. I had messed with the connectors many times w/o unplugging the charger first with no worries but I don't do it now without unplugging. You would think if I can make hydrogen this easy, someone ought to be able to make it run my vehicle down the road pretty cheap. LOL I also put a cement block inside the plastic barrel to keep the door/panel from contacting the stainless. This would be like the + and - clips touching each other. Good luck! Rod
Top
#127388 - Sat Jan 28 2006 12:41 PM
Loc: Eastpointe Mi.
Rod;
Right on - on all counts......
------------------ Regards .... Jerry J .....
_________________________
Top
#127389 - Sat Jan 28 2006 04:25 PM
Loc: Baltimore, MD
Still going very slowly, not sure whats wrong. Its been in all day and the paint has bubbled, but not even to the extent that was shown here after 20 minutes. The water has stayed warm. I did, however, use Oxyclean instead of the Arm & Hammer brand stuff. After looking around online I was given the impression that they're pretty much the same, but I could be way wrong. Couldn't find the Arm & Hammer so I went with this.
Top
#127394 - Sun Jan 29 2006 09:19 AM
Loc: Baltimore, MD
Well, I let the panel sit overnight. I scraped off an area for better contact with the alligator clip and it definitely improved things. You could see the bubbles coming off the panel and it stripped a lot more paint. Still didn't really touch the rust unfortunately.
I looked in a couple different stores around here yesterday. Couldn't find the Arm & Hammer brand washing soda, so I settled on Borax which seems to be close. Its working way better than the Oxyclean. Not sure what else to try though.
Top
#127399 - Wed Feb 08 2006 02:01 PM
Loc: Baltimore, MD
I'll have to check out the local carwash place, see if they can hook me up. I still don't know whether one of those 55 gallon drums will be tall enough to do 1/2 of a Wayne 70 skin. We'll see I guess.
Top
#127400 - Wed Feb 08 2006 02:39 PM
Loc: Dyer, IN
Chris Bowers: Is there a soft drink bottler near you? I got one of those plastic drums from a Pepsi bottler near me for free. Still smelled like Mountain Dew, and they cleaned it out for me too! Your cut 70 doors will probably have stipes in the middle of them like my Tok 39 tall doors have, Im going to blast mine anyway. -Scott-
Top
