Page 1 of 5 1 2 3 4 5
Bowser 585 Restoration. My first attempt. #134759
Sun Mar 15 2009 10:14 PM
Modesto, Ca
Donnie Boger Offline OP
Modesto, Ca
As I stated in my New Guy thread, I am going to be restoring my first pump, a Bowser 585. My plan is to turn it into a Hancock pump to surprise my dad. The station we both worked at growing up was a Hancock station when he worked there. I am leaning towards orange sides and top with the white doors. while taking the pump apart today I noticed some of the old paint flaking off so I decided to take a couple of layers off. After doing so I found that this pump used to have RPM decals on it.. Here are a couple of pictures before I took it apart today. I had to bust out my torches and heat up some of the screws .
Here it is disassembled. Notice the burned paint from the heat of the torch
Does anybody know what this hole is for? It is on the same side as the reset crank.
This is my next little project after I get the base and frame painted, the computer looks like it will take me a while to do, looks like there are a lot of little parts in there.
Looking for anything Hancock, Signal, Veedol/Flying A and Richfield
Re: Bowser 585 Restoration. My first attempt. [Re: Donnie Boger] #134760
Sun Mar 15 2009 10:25 PM
Modesto, Ca
Modesto, Ca
Here are the rest I took today.
Here you can see where the studs broke off for the sight glass warning plate. 3 of them on one door and 2 on the other. I am going to have the guys at school weld on some more studs.
This is the only rust problem besides the rusty bolts, nuts and screws. I am going to be making a new bottom part to the door.
And here you can make out the words RPM, Chevron, outboard motor oil.
Now I have a couple of questions. Where would I put the "contains lead" plate? On the sides or the corner of the doors? Would I use a vinyl decal or porcelain plate? Also should I use a porcelain pump plate or vinyl water slide decal. Keep in mind I am going to be using a 13.5" globe on top of the pump. I am not sure if I am going to be using Hancock ad glass or not yet. Any input will help me out greatly.
Donnie
Re: Bowser 585 Restoration. My first attempt. [Re: Donnie Boger] #134763
Sun Mar 15 2009 10:39 PM
Janesville, Mn. 56048
Esse's Garage Offline
The Hole is Probably for a Light Switch. Use Porcelain "Contains Lead" signs vinyl decals look Cheesy you wouldn't be happy with them. I would say they most likely go on the side panels. The First Picture of the side panel you show looks like it has 4 small holes in it, most likely that is where the small Contains lead sign goes.
Re: Bowser 585 Restoration. My first attempt. [Re: Esse's Garage] #134793
Mon Mar 16 2009 10:23 AM
Modesto, Ca
Modesto, Ca
Thanks to Ted and the hot tank at the college the doors, sides, and top are now soaking. When I get home from school today I am going to finish gutting it and start cleaning the computer up.
Re: Bowser 585 Restoration. My first attempt. [Re: Donnie Boger] #134801
Mon Mar 16 2009 11:21 AM
Lodi, CA.
Signal Gas & Oil Offline
Lodi, CA.
Good start. I will show you where the lead signs go and find you a deal on some originals. Donnie is a quick learner when it comes to cars and doing good with pumps also. I told him I always take the best students with me to the gas bash. He is the first in 34 years of teaching. Not bad.
Ted Pam Ethyl & Polly Roach
Lodi CA.
209-210-8971
Looking for Signal, Hancock, Mohawk, Douglas, Gilmore and Richfield
Re: Bowser 585 Restoration. My first attempt. [Re: Signal Gas & Oil] #134805
Mon Mar 16 2009 11:38 AM
Antioch,IL
oldnfuelish Offline
oldnfuelish  Offline
Antioch,IL
looking good there!Wow!"gaspumps 101"never had a class like that when i went to school!!and ted roach as the teach!!this young man scored big time!! keep the pics comin!!
Last edited by oldnfuelish; Mon Mar 16 2009 11:39 AM. Reason: well wasnt sure the pic thing worked but it did twice
Re: Bowser 585 Restoration. My first attempt. [Re: oldnfuelish] #134869
Mon Mar 16 2009 06:59 PM
Modesto, Ca
Modesto, Ca
Thanks Ted it means a lot to hear something like that. And we need a gas pump restoration class too..lol
Re: Bowser 585 Restoration. My first attempt. [Re: Donnie Boger] #134911
Tue Mar 17 2009 09:26 AM
Grants Pass, OR, USA
bruzer75 Offline
bruzer75  Offline
Me likey the Chevron. Keep up the good work and pictures.
Re: Bowser 585 Restoration. My first attempt. [Re: bruzer75] #134927
Tue Mar 17 2009 03:04 PM
Modesto, Ca
Modesto, Ca
will do, and here you go. Its now in the body shops hands.
Since it is now in the body shops hands I can turn my attention to the base and frame as well as the computer.
Re: Bowser 585 Restoration. My first attempt. [Re: Donnie Boger] #134976
Tue Mar 17 2009 06:43 PM
Modesto, Ca
Modesto, Ca
My poor computer has seen better days...a lot better days. The good news is I was able to spin the "This Sale" dials all the way around to 999, but I can't get them to reset. There is going to be a whole of pressure washing and soaking in WD 40.
Re: Bowser 585 Restoration. My first attempt. [Re: Donnie Boger] #139319
Thu Apr 30 2009 04:31 PM
Modesto, Ca
Modesto, Ca
Well got the frame back from the sand blasters today, have it primed and ready to do the body work on the base (I will be doing that here at home)
Here she is as bare metal
And here she is as primed
I can't wait for the body shop to finish the doors and skins, now I need to take apart the computer to restore the wheels.
Re: Bowser 585 Restoration. My first attempt. [Re: Donnie Boger] #139376
Fri May 01 2009 06:58 AM
Sunbury, PA, USA
lordparaffin Offline
Sunbury, PA, USA
Haven't done a pump yet but truely enjoy watching this through all the photos. Feel like I'm almost a part of it all somehow!! There's a pile of elbo grease going around here lately. You may need some of it for that computer!! Keep up the good work and the slide show. It's been educational.
........Dave
Re: Bowser 585 Restoration. My first attempt. [Re: lordparaffin] #149419
Sat Aug 22 2009 04:01 AM
Modesto, Ca
Modesto, Ca
Our body shop class takes forever to get anything done, but yesterday I was over there checking out the progress on the pump, it doesn't even look like the same pump I dropped off. The one door with a good portion missing from rust doesn't even look like it was missing. All the parts are in primer and the guys are doing the final wet sanding before the color coat. I have decided to do the doors in orange and the sides and top in black. And since I took a welding class over the summer I cannot wait to get my next pump and do all the work myself. I have yet to tackle the computer, I might just send it out and have it done. The base and frame are almost done, I just need to do a little more body work on the base. All of the cast iron parts that I kept are blasted and ready for some cast iron engine paint. I need to get started on building the island for my display. So for now there are no new pics, sorry. I thought I would let you guys know the progress on the pump and progress is very slow...lol
Re: Bowser 585 Restoration. My first attempt. [Re: Donnie Boger] #149423
Sat Aug 22 2009 05:36 AM
Keep us Updated!!!
Re: Bowser 585 Restoration. My first attempt. [Re: Esse's Garage] #149707
Mon Aug 24 2009 06:33 PM
North Dakota
K
Koolmotor Offline
Koolmotor  Offline
K
North Dakota
Love them Bowsers - that's some bad hat Harry!
Page Time: 0.027s Queries: 15 (0.007s) Memory: 1.9301 MB (Peak: 2.0928 MB) Zlib disabled. Server Time: 2018-07-17 04:17:00 UTC
