Page 3 of 3 1 2 3
Re: Mistake of the Sentry.....245 Gas/Oil twins #13523
Sat Mar 17 2007 12:08 PM
Raleigh, North Carolina
gulfiend! Offline
gulfiend!  Offline
Joe...
...here are the long-promised photos of the details on my Bowser that you asked about...
(1) this is the top of the pump, showing the hole in the cap, and the threads in the top of the pump:
(2) this is the dome, showing where the conduit would attach (the small hole on the bottom of what I guess to be the junction box - you can see how the cast piece in front was designed to curve around the conduit:
(3) this is the nozzle:
(4) this is the wood handle on the crank:
[This message has been edited by gulfiend! (edited 03-17-2007).]
Re: Mistake of the Sentry.....245 Gas/Oil twins #13524
Sat Mar 17 2007 12:09 PM
gulfiend! Offline
gulfiend!  Offline
(5) this is the crank handle:
(6) this is the name plate & id tag:
(7) this is the access plate, near the base:
(8) this is the pump opened, with the arrow indicating the location of Photo 1:
(9)...and this shows the length of the pipe 'tower', from where it appears coming out of the cap on the pump, to where it disappears going into the dome hardware, it's 19 5/8"...the arrow shows the location of Photo 2...
...Hope this helps!! Sorry about the wait...
Re: Mistake of the Sentry.....245 Gas/Oil twins #13525
Sat Mar 17 2007 07:23 PM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
Yes, it helps a lot...I have some questions though and some info.
Inside the red circle do you have brass indicator tags...I can't tell....mine has 3
1/2 gallon, 1qt, 1pt...you should have 4 since you have 4 stops....the 4th is inside the black circle...That is also where the calibration for the gallon was done.
There is a hole in the screw and the strange shaped plate to put a lead wire seal through.
This is to show that the calibration has not been tampered with.
What is the "door" looking thing in the blue circle and what is it's purpose???
My ID tag looks just like that one but it is brass, and in terrible shape.
Bob Lee wrote me back and said he would see if he had any info on these pumps
Joe
Another question...where is the light switch??/
If you copied the ID tag onto paper do you think I could get one made at a place that makes trophies?
[This message has been edited by jkyocom (edited 03-17-2007).]
Veeder Root Identification CD
Gas Pump Clock Repair
jkyocom@bellsouth.net
Re: Mistake of the Sentry.....245 Gas/Oil twins #13526
Sat Aug 25 2007 05:04 AM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
I brought this back up for Hardy's Garage
Re: Mistake of the Sentry.....245 Gas/Oil twins #13527
Sun Aug 26 2007 07:32 AM
paducah ky
briansbodyshop Offline
paducah ky
Joe,How do you go about stamping the serial numbers onto the tag?? You know Im new to this hobby,so I havent gotten to that stage yet.. Thanks..
WANTED: TOKHEIM NOZZLES
Re: Mistake of the Sentry.....245 Gas/Oil twins #13528
Sun Aug 26 2007 08:30 AM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
They make # and letter punches.....
They look like a peice of square stock with a # or letter on the end..
You have to buy them as sets which can be pricey...0-9 , A-Z
http://upload.wikimedia.org/wikipedia/en/5/52/Bowser_No_Background.png
Another ugly Bowser
[This message has been edited by jkyocom (edited 08-26-2007).]
Re: Mistake of the Sentry.....245 Gas/Oil twins [Re: jkyocom] #700911
Wed Dec 20 2017 11:59 AM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
Patent #1,274,039. WILL TAKE YOU STRAIGHT TO IT.
This was not consigned for Bowser
1917-1918
https://patents.google.com/patent/US1274039A/en
Page 3 of 3 1 2 3
Page Time: 0.020s Queries: 14 (0.005s) Memory: 1.8779 MB (Peak: 1.9842 MB) Zlib disabled. Server Time: 2018-07-18 18:37:58 UTC
