#145224
Mon Jul 13 2009 09:49 AM
Posts: 66 |
I was given a Model 98 that was in working condition when "liberated" but has not functioned in many years. It appears to be a Canadian version with Canadian cities listed on the face plate. This one is white inside and out. Although I remember seeing white ones when I was a kid, weren't they mostly red?
I am stripping it down to have the cover bead blasted and painted. The ID tag has been painted over and I was wondering if I could use paint remover on it without harming the tag itself.
I need a replacement glass, and face plate. I'll try to have the chrome parts polished to see if I can remove most of the pitting. Also on one of the pics below, a red arrow is pointing to a broken spring. Just wondering what this is for and where I can get a replacement.
Bernie Retired but refuse to grow up.
Jack Sim has all the parts you need. I'd buy new chrome parts instead of wasting money on old.
If you were buying an ECO from the local equipment dealer it was red. If you were Shell and you were buying 100 for all your stations in a large city, they would paint them any way you wanted. The ID tag should be removed and treated by itself. Sandblast the cover. Anything used on the ID tag will remove all the paint. I see a lot of units like yours from Canada, where they didn't want to put the unit back together the way it was intended. So they drilled three holes in the chrome and put screws in them. They are not susposed to have screws in the chrome. You can polish all you want, but you will never get the pits out of the chrome. Replaters can't get the pits out of the chrome. I have seen some pieces of chrome ground so much you read a newspaper through them. They especially can't get the pits out of the lines on the Emblem (upper) and Scuff (lower) plate. The spring that is broke is part of the shot lengthener. We have a Service manual, covering the repair of this unit, I have even added "Jack's tips" to further help you. We stock every part that is in you unit, including the spring you need. We have a Chrome kit that has all the chrome you need, the chome plating is actually better than the original as the original was industrial chrome and not too thick. Here is a picture of a unit I just finished. http://img29.imageshack.us/i/eco97e.tif/Check out my website, it is the largest website devoted to this hobby (over 5000 images). All the parts are listed on the site. And we do ship to Canada. www.petrolianacollectibles.comJack Sim
Posts: 1,730 Likes: 19
Posts: 1,730 Likes: 19 |
I'll have parts available also along with the porcelain face (US style) if I can be of any help. The "shot lengthener" is the item you have the arrow pointing to. It was optional equipment. You can eliminate it and save yourself some $$.
Ron
Posts: 66 |
Jack, I sent you a lengthy e-mail Friday.
Ron, I'll check out your site.
Thanks.
Posts: 203 |
nice piece, wish I had one!!! Maybe next on my list
Dave
Bernie,
One more thing. You listed your unit as a 98. Your unit is not a 98. The 98 was an ECO on a pedestal. Your unit is a 97. It appears the head part of your unit was originally on a pedestal, at sometime in its lifetime it was removed from the pedestal and put on a wall mount. Or....Maybe the rear cover of the wall mount 97 was damaged and a repair man put a used rear cover on the unit, and the used cover came off an old 98.
We have ID tags if you wish to change the model number to a 97.
Posts: 66 |
Thanks Jack.
Hmmm.... Originally, my money would have been on a 98 that was removed from the pedestal. The ID tag has been on there since day one. The whole unit seems to have been together forever and the inside of the wall unit and head are both white. The only part that has red on it is the bottom wall unit plate on the inside. Now I'm not so sure if it was originally a 97 or 98.
BTW, I started carefully removing the paint from the ID tag and found that there is another coat of dark grey paint under the white.
I have told this story of the lonely air meter many times.
The station operator decides to buy a air meter. He calls the local equipment warehouse and they send out a salesman. Sometimes he brings a sample, but most of the time he just brings a brochure.
The station operator is already mad because he has to buy something in order to give something away, so when he is asked if he wants the light option, he thinks, "I'll have to run electricity out to that thing, no way." (This is why you find so many ECOs with a light in them). Then he is asked if he wants the water option and he thinks "I'll have to run a water line out to that thing, Hell no, let them carry the bucket."
When the unit is installed the operator is told to be sure to bleed off the water every week. This is never done and it rusts so bad that it requires a service man to repair it.
Then there are the customers. After filling their tires they don't hang up the hose, and if there is the smallest air leak anywhere, the air compressor runs all night. Some throw the hose back at the meter and the chuck hits the glass and brakes it, then it lays on the ground and the nest car runs over it. Any if that isn't bad enough, the next guy to come in unscrews the hose and steals it.
Yet, this trusty lonely air meter stands out there year after year, out living probably 15-20 pumps and some people ask why they are rare?
One more thing, these units were regularly painted by that 12 year old kid that hung around the station, he was given a can of battleship gray (the most used paint after WWII), a brush, and was told to paint everything he could reach.
Posts: 2,139 Likes: 48
Posts: 2,139 Likes: 48 |
Having owned and worked in several gas stations over the years what I remember most about using an eco is the phenomenal number of bicycle tires blown up too high and hearing them 'pop'.
You could almost always tell who was going to do it too. We'd be wrenching and somebody would say here comes another one. And...right on cue they would put too much air in it and pop it.
Posts: 36 |
Saw a guy air up a bike tire for his soe, as usual too much air---they put the bike in the car then it blew..wanna see a chinese firedrill when they piled out of the car!!
take out the main valve and clean it; thats the big brass valve with 3 lines going to it under the broken spring..99% of your troubles are in that main valve..good luck
gaspumpchas
Serving your ECO air meter needs since 1992....
Posts: 66 |
I took the big brass valve apart and cleaned it. Not much gunk in there to begin with. Thanks for the tip.
Posts: 66 |
The "shot lengthener" is the item you have the arrow pointing to. It was optional equipment. You can eliminate it and save yourself some $$. Ron, Should I remiove the broken spring completely or just leave it as is?
Bernie,
Just buy a service manual, follow follow the instructions. A unit as old as your is doesn't need a repair, it needs a rebuild.
Have you checked the diaphragm, is is leaking?
Have you checked the strainter, is is filled with rust?
On a unit that dates back to the 60's (almost 50 years old), it needs to be rebuilt!
Buy your parts from anyone you choose, but if you have a problem, here is my phone number: 314-427-3943
Posts: 66 |
Sounds like I need one of your tip manuals. Please add that to the list of stuff I sent you for pricing.
