A Piece of metal #150136
Fri Aug 28 2009 08:21 AM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
I need the bottom sheet metal for an early Veeder Root computer.
It should be 4 1/4" in Height and in good enough shape to restore.
I have NO idea what it looks like besides that measurement, cause I ain't never seen one.
Dig one up, tell me a price, and I will buy it.
If you have one and DON"T want to sell it, I could use a pic or two to try to copy it.
Joe
Veeder Root Identification CD
Gas Pump Clock Repair
jkyocom@bellsouth.net
Re: A Piece of metal [Re: jkyocom] #150172
Fri Aug 28 2009 12:46 PM
Durand, Ill
big blazer Offline
big blazer  Offline
Durand, Ill
I have this.It is 4 1/4 " high.Would this work for you?
Re: A Piece of metal [Re: big blazer] #150188
Fri Aug 28 2009 05:50 PM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
I checked that too. Correct dimensions,
It won't have the door hole in it, and I imagine it would have a hasp like the older ones.
This style is too short.
Thanks for the try.
Re: A Piece of metal [Re: jkyocom] #150512
Mon Aug 31 2009 05:13 AM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
Anyone have an EARLY, 1932-34 Wayne 40 that may have this metal???? I beleive it may be the only pump to have used it.
it is the only thing keeping me from finishing this computer.
If nothing else just a pic?
Re: A Piece of metal [Re: jkyocom] #150622
Mon Aug 31 2009 08:30 PM
Cameron Park,Ca.
MATT ALVAREZ Offline
Cameron Park,Ca.
Joe, there was an early Wayne 40 with the brass faces at Freds gas bash a couple years ago. It was Michael Slamas, maybe he can remember who bought it and they can check the computer for you.
Re: A Piece of metal [Re: MATT ALVAREZ] #150707
Tue Sep 01 2009 06:12 PM
kokomo,indiana usa
O
oldiesbutgoodies Offline
O
kokomo,indiana usa
I have a wayne 40 I just picked up and will take some pictures of meter and e-mail you tomorrow.
Bob
Re: A Piece of metal [Re: oldiesbutgoodies] #150730
Wed Sep 02 2009 04:51 AM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
cool....thanks a bunch
Re: A Piece of metal [Re: jkyocom] #151029
Fri Sep 04 2009 09:18 PM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
From what I gathered, the metal I need will come from a Wayne 40 that has the original computer like the two shown above and has the hasp like the metal in the pic above but should be 4 1/4'".
Re: A Piece of metal [Re: jkyocom] #151035
Fri Sep 04 2009 10:23 PM
Cameron Park,Ca.
Cameron Park,Ca.
260471612972 this one is on ebay. It looks like the early one like yours. Maybe the guy has the metal band.
Re: A Piece of metal [Re: MATT ALVAREZ] #151039
Sat Sep 05 2009 12:32 AM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
There was enough there for him to describe it too me.
Re: A Piece of metal [Re: jkyocom] #151161
Sun Sep 06 2009 10:45 AM
Devils Lake, ND---USA
K W FRITH Offline
K W FRITH  Offline
Joe--I finally got the time to take my 40 apart and get you some pictures! The metal part is all solid and mine actually measurers 4 3/8 inches. The part with the wire loop is set back 1 1/2 inches from the edge and the little channel piece on the other side is set back 3/4 inch from the end. Email if you need anything else while I've got it apart.--KEVIN
Re: A Piece of metal [Re: K W FRITH] #151170
Sun Sep 06 2009 12:26 PM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
Is there anything left of the decal?
If you wet the metal it might show up.
I have some newer metal I can rob the parts off to make the band .
It is the two dimples for the lever restraint is what I need someone
w/ experience and the right tools to copy.
Any sheet metal guys out there that can do that????
Kevin
Re: A Piece of metal [Re: jkyocom] #151172
Sun Sep 06 2009 12:31 PM
K W FRITH Offline
K W FRITH  Offline
Sorry--Nothing left of the decal. I'm a little worried about the sheet metal when I go to bead blast it!
Suprisingly--the variator internals look like new! When I get around to restoring this pump, you'll have to do the computer for me!
How about those little price wheels at the top of the face? Were they used to indicate price per gallon? Is there a trick to moving them, or are mine just stuck in place?
Re: A Piece of metal [Re: K W FRITH] #151177
Sun Sep 06 2009 02:25 PM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
Ain't never worked on a 40...
Got a pic of the computer????
From what I have been able to determine there should be one variator style or another if it is original to the pump.
1 being 1932, 1 being 1933
Re: A Piece of metal [Re: jkyocom] #151222
Sun Sep 06 2009 08:11 PM
Cameron Park,Ca.
Cameron Park,Ca.
Kevin, there should be a removabl pin that keeps the wheels price wheels from turning after the price is set. Mine were rusted in place even after I removed the pin. Joe used to make replacement wheels. They were a lot of work so I am not sure if he still does them. Here are mine before and with Joes replacements.
Page Time: 0.028s Queries: 14 (0.008s) Memory: 1.9193 MB (Peak: 2.0608 MB) Zlib disabled. Server Time: 2018-09-25 08:07:54 UTC
