Page 2 of 4 1 2 3 4
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: TeeTee] #154933
Tue Oct 06 2009 03:24 PM
MI
TeeTee Offline OP
TeeTee  Offline OP
MI
Next we go back to the anvil to tighten up that seam. I use a hammer and a hardwood block and gently tap down on the seam a little at a time. After each hit with the hammer I pull on the seam to keep the each end of the hem tight to the opposite hem. These next three pictures show the progression of the seam and the fourth one here shows the completed seam.
I offer quart can re-lidding, can rolling, lid stamping, and dent removal.
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: TeeTee] #154935
Tue Oct 06 2009 03:44 PM
MI
TeeTee Offline OP
TeeTee  Offline OP
MI
Notice that most of the distortion in the shape of the can is gone...when the top and bottom are installed that will take care of the rest.
The next step is to stamp the top lid with an SAE designation. This can will have the 20-20W stamp. For this process the arbor press along with a set of original dies is used. The lid is centered on top of the male die with the top of the lid facing up. The female die is then placed on top of the lid...this is done carefully with the aid of alignment marks to make sure that the two dies line up correctly for the stamping. The arbor press is used to put some pressure on the dies and then the top of the press is given a good strike with the hammer. The next several photos show this process.
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: TeeTee] #154936
Tue Oct 06 2009 03:47 PM
MI
TeeTee Offline OP
TeeTee  Offline OP
MI
Tomorrow I will show how the top and bottom of the can is flared and lids installed to complete the can.
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: TeeTee] #154941
Tue Oct 06 2009 04:20 PM
Sunbury, PA, USA
lordparaffin Offline
Sunbury, PA, USA
This is very interesting. Somehow I expected something more complex in the seam itself.
That's also interesting about the Hoosier Pete can and known examples having only been from flats.
Is it a certainty that this brand was actually marketed using this label?
........Dave
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: lordparaffin] #154966
Tue Oct 06 2009 07:30 PM
OKC, OK
publicenemy1925 Offline
OKC, OK
Is this tech week? Way cool! I come across flats all the time but have been at a loss to find a way to seam them together.
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: publicenemy1925] #155038
Wed Oct 07 2009 07:56 AM
richmond , Virginia
eshaver Offline
eshaver  Offline
richmond , Virginia
Damn , I could learn some great sheet metal tips from you ! Thanks for sharing the information with us - really ! Ed Shaver
see ya on the road folks !
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: eshaver] #155040
Wed Oct 07 2009 08:03 AM
Devils Lake, ND---USA
K W FRITH Offline
K W FRITH  Offline
TeeTee--To get the finished look along the seam, did you use the wood block placed along the edge of the seam or how did you do that? I expected a flat folded seam but yours actually folds over the other seam and sort of "locks" itself in place, just like a factory seam would be. I was wondering if you needed a special tool for that or was the wood block enough? Thanks---KEVIN
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: K W FRITH] #155085
Wed Oct 07 2009 03:05 PM
MI
TeeTee Offline OP
TeeTee  Offline OP
MI
Dave...when I first started thinking about rolling cans, I also thought that it would be much more complicated. Often times we tend to over think things.
Kevin...Just used the wood block. After a few cans it gets a small groove indented in it and gives the nice looking seam.
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: TeeTee] #155086
Wed Oct 07 2009 03:08 PM
MI
TeeTee Offline OP
TeeTee  Offline OP
MI
The next step in the process is to flare the top and bottom of the can to get it ready to accept the lids. This is done on the can sealer with the flaring attachment and roller. The next four shots show this process.
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: TeeTee] #155087
Wed Oct 07 2009 03:12 PM
Longview, WA
Bob Richards Online happy
Bob Richards  Online Happy
Longview, WA
What kind of price would one be looking at to have a "flat" made into a round can? I have my "Red Indian Aviation can" that I have been thinking would look good "round", again.
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: TeeTee] #155089
Wed Oct 07 2009 03:15 PM
MI
TeeTee Offline OP
TeeTee  Offline OP
MI
As you can now see the distortion is gone and the can is round. The final step is to install the top and bottom lids of the can. The first step is to put the lidding attachment and rollers on the can sealer. In this case the bottom was put on first and then the top. Be sure to put the stamped lid on the top and the blank lid on the bottom...I have done it the other way around a few times!! The next three shots show the process.
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: TeeTee] #155090
Wed Oct 07 2009 03:24 PM
MI
TeeTee Offline OP
TeeTee  Offline OP
MI
And...drum roll please...here is the completed can.
Total time was about a half hour including taking of the pictures. Without pictures it takes about 15 minutes from start to finish....assuming that I have some lids stamped and ready to go.
If you have any questions, feel free to ask. If you run across any flats the key measurements for them to be usable are approximately 12 5/8 long by 5 11/16 tall...give or take a little.
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: TeeTee] #155092
Wed Oct 07 2009 03:26 PM
MI
TeeTee Offline OP
TeeTee  Offline OP
MI
I don't have John's address handy...anybody want to buy the rights to have their name and address put on the box??? lol
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: TeeTee] #155093
Wed Oct 07 2009 03:28 PM
Antioch,IL
oldnfuelish Offline
Happy Birthday oldnfuelish  Offline
Antioch,IL
i'll give you five for the rights!!LOLdid you make sure you packed that REALLY well?
Re: The Jarvis Hoosier Pete can...from "Flat to Phat" [Re: oldnfuelish] #155094
Wed Oct 07 2009 03:39 PM
Mishawaka, IN USA
ryanfair Offline
ryanfair  Offline
Mishawaka, IN USA
Wow is that great TeeTee. Super work. Being from IN as well, I love the can. Thanks for the tutorial!
Ryan
WANTED: Lonzo Oil, Pacer, Super Par Items
Page 2 of 4 1 2 3 4
Page Time: 0.047s Queries: 20 (0.018s) Memory: 1.9273 MB (Peak: 2.0824 MB) Zlib disabled. Server Time: 2018-06-23 00:33:58 UTC
