Re: Tokheim 34 skins [Re: Dick Bennett] #156666
Wed Oct 21 2009 01:56 PM
Edgewater, Colorful Colorado
st.rod Offline
st.rod  Offline
Hey, Thanks for posting that Dick! I have wanted to measure someones pump for a future pattern and never had the chance. I saved the image to 'my documents'. wink
Larry
Re: Tokheim 34 skins [Re: st.rod] #156675
Wed Oct 21 2009 02:26 PM
Santa Paula, Calif
Dick Bennett Offline
Santa Paula, Calif
No problem.
I meas. it last year for a friend that cut the design from 2 pcs of 16 gauge & spot welded them to repo skins.
BTW, original clips & pins were made of steel, not brass.
Re: Tokheim 34 skins [Re: Dick Bennett] #156717
Wed Oct 21 2009 06:41 PM
So. Illinois
oldgoaly Offline
oldgoaly  Offline
So. Illinois
If the side is flat, take Dick's pattern, cutout proper thickness of sheet metal. Using cutout sheet and the cutout part, and sandwich the pump side. Using either sheet metal roll, english wheel or a press can apply pressure to the sandwich and that will give you the embossed side no welding. use the pattern for many more sides. tt
Re: Tokheim 34 skins [Re: oldgoaly] #156737
Thu Oct 22 2009 01:50 AM
COLORADO
LC 336 Offline OP
LC 336  Offline OP
COLORADO
Thanks for the diemensions, I can cut that out on the flat bed plasma cutter. I will try Joe's idea and see how it turns out, it should work perfect. I will even try and find some one local to press them like TT sugested and see which way looks best. All of these are great ideas. Thank You for the advice.
Re: Tokheim 34 skins [Re: LC 336] #156774
Thu Oct 22 2009 10:37 AM
So. Illinois
oldgoaly Offline
oldgoaly  Offline
So. Illinois
a common 20 ton shop/bearing press should work. tt
Page Time: 0.019s Queries: 14 (0.006s) Memory: 1.8618 MB (Peak: 1.9517 MB) Zlib disabled. Server Time: 2018-07-15 19:45:31 UTC
