Tokheim Model 39 Type BP #161253
Sun Nov 22 2009 03:26 PM
GA
chaingang Offline OP
GA
New guy here with a question or two.
I just purchased a Tokheim, model 39, type(BP?) seriel # 1048084-7-54 pump yesterday at a swapmeet. The pump is very complete and the original tag is intact so I am sure the model and type are correct unless it was changed in the past. I just ordered the "bible" and restoration guidebook from the site also. This pump has the hose coming from inside the body with 4 guide rollers in the side. Of all the pictures I have been able to find I haven't seen one like it yet. Any clues as to what year, brand of gas etc... it could be? There is a faint old sticker that has #2 diesel and a Pure emblem on it. Anybody have a picture or two of this style.
Re: Tokheim Model 39 Type BP [Re: chaingang] #161255
Sun Nov 22 2009 03:53 PM
Plover, Wisconsin, U.S.A.
Jolly-John Offline
Jolly-John  Offline
Hi, chaingang. I sent you a PM. John
Re: Tokheim Model 39 Type BP [Re: Jolly-John] #161262
Sun Nov 22 2009 04:25 PM
GA
jkyocom Offline
jkyocom  Offline
GA
Pure Diesel...boy it's going to stink if it still has the guts in it.
Let me know if you need the computer rebuilt.
Veeder Root Identification CD
Gas Pump Clock Repair
jkyocom@bellsouth.net
Re: Tokheim Model 39 Type BP [Re: Jolly-John] #161263
Sun Nov 22 2009 04:26 PM
St. Louis, MO, USA
Jack Sim Offline
Jack Sim  Offline
St. Louis, MO, USA
A great pump once you get the smell of diesel out of it.
If you meant my Gas Pump ID book when you said "Bible", thanks for buying my book.
The pump guys will have to confirm this, but I believe the hose exit with the rollers came off a Wayne pump. Am I correct?
Your pump was made in between April 1, 1954 and June 30, 1954.
It is from the A & B series where the doors lift off.
It is a 39B, the P means that it had ad glass panels originally.
I have the largest website devoted to this hobby (over 5000 images): www.petrocollect.com
If you want to see original Tokheim pictures of your pump (there is even an instruction sheet on how to install the rubber around the glass in the doors) check out: http://www.petrolianacollectibles.com/tokheim%2039a.htm
Also, the correct nozzle is also shown on: http://www.petrolianacollectibles.com/gas%20pump%20nozzles.htm
Re: Tokheim Model 39 Type BP [Re: Jack Sim] #161268
Sun Nov 22 2009 05:31 PM
GA
GA
Thanks for the replies so far. Yes it does have all the guts in it. It was a real bear getting it to the truck even with hand trucks. It does not have even a faint smell of diesel but I haven't opened it up yet. Yes Jack I was refering to your book. I look forward to getting it. So are you saying that mine had the side panel replaced in the past? I like the look of this hose style and would like to retain it when it is restored. Not sure of the lift off doors as I haven't unloaded it from the trailer but it does have the lower locks in both front and back panels. Also, one panel does have a filler piece in it that I would assume is for the add panel you mentioned. In this model it is below the computer, correct? Should it have the add panels in both sides? Can they be reinstalled when I do the restoration?
Thanks,
Dave
Re: Tokheim Model 39 Type BP [Re: chaingang] #161270
Sun Nov 22 2009 05:37 PM
GA
jkyocom Offline
jkyocom  Offline
GA
If there are stamped out holes in the doors under the face glass it would have taken glass w/ a rubber seal.
There should be reflectors inside the doors, to send light outward through the ad glass
There should be some stainless strips or bars on the corners on the hose side.
Make sure your doors will slide under the stainless top trim easily,,,BEFORE YOU PAINT
Re: Tokheim Model 39 Type BP [Re: Jack Sim] #161275
Sun Nov 22 2009 05:41 PM
Santa Paula, Calif
Dick Bennett Offline
Santa Paula, Calif
Jack,
Tok. made 4 different 39L body styles [39 LHR pg 287, 39L-EP & 39L-EZ pg 288, 39-A-BP pg 290] that have the long hose retracting into pump. 300 models have a couple more.
Re: Tokheim Model 39 Type BP [Re: Dick Bennett] #161283
Sun Nov 22 2009 06:14 PM
GA
GA
Joe,
It does have a stamped opening in one panel, no way it could have been cut out, to smooth and uniform. Should it have had glass panel on both sides? I will check into the reflectors when I can. One of the stainless bars is missing there are open holes on the right side of the nozzle so I figured it had 2 originally. That appears to be the only thing really missing at this point. I will keep you in mind for the computer rebuild when I get to that point. What part of GA are you in? I am about 60 miles south of Atlanta.
Dick,
You referenced a 39L in your post. What does the L mean? Also, the pages you referenced, what book is this from? I hope it is Jack's since I have one on order. So my pump would be correct with this hose style? Any pics of this style restored or even unrestored?
I really apreciate the info so far guys.
Dave
Re: Tokheim Model 39 Type BP [Re: chaingang] #161291
Sun Nov 22 2009 06:54 PM
Santa Paula, Calif
Santa Paula, Calif
CG,
The L stands for LOW. That body style is a shorter version of the 6' 39, w/ exception of adv panels being above the faces.
Yes, I'm referring to Jack's 2nd book. 1st book had more oil pumps included, in 2nd book some of those were dropped for more pumps.
db
Re: Tokheim Model 39 Type BP [Re: Dick Bennett] #161295
Sun Nov 22 2009 07:11 PM
GA
jkyocom Offline
jkyocom  Offline
GA
I am in Carrollton
Re: Tokheim Model 39 Type BP [Re: jkyocom] #161323
Sun Nov 22 2009 08:58 PM
Walla Walla, WA USA
gatorgaspumps Online content
gatorgaspumps  Online Content
Walla Walla, WA USA
Here is a picture of one like yours but without the add glass.
Richard
Re: Tokheim Model 39 Type BP [Re: gatorgaspumps] #161324
Sun Nov 22 2009 09:00 PM
Oneida IL USA
gasoildude Offline
gasoildude  Offline
Oneida IL USA
Nice pump. I think 39s dont get enough credit. I think they are good looking pumps when all done up smile
Brad Ralston & my website is
www.petrobarn.com
Re: Tokheim Model 39 Type BP [Re: gasoildude] #161375
Mon Nov 23 2009 09:12 AM
Wisconsin
Mr.Wadhams Online sad
Mr.Wadhams  Online Sad
Wisconsin
I have a pair of ad glass and light reflectors for your pump on Ebay right now. Everything in excellent condition. Item #370295316760
Re: Tokheim Model 39 Type BP [Re: Mr.Wadhams] #161407
Mon Nov 23 2009 03:26 PM
GA
GA
Yep, that is what mine looks like. Looks like another layer of red showing through my white paint, I wonder if mine was done up like yours. I will look at the EBAY items. Thanks,
Dave
Re: Tokheim Model 39 Type BP [Re: chaingang] #161437
Mon Nov 23 2009 07:28 PM
Jolly-John Offline
Jolly-John  Offline
Hi, Dave. I just sent you a private message. John
Re: Tokheim Model 39 Type BP [Re: Jolly-John] #162400
Sun Nov 29 2009 04:53 PM
GA
GA
After taking the doors off this I have a couple of questions. Can a pump this old be restored to a fully functioning unit? Is it worth while to do so? It has all the internals and the drive belt is still intact. I don't know if it will turn but since it had diesel in it I figure it is still lubricated. The computer probably needs work but it did reset with the crank handle. The reason I was thinking about making it functional would be to restore it to a diesel brand then set it up for use on the farm for the tractor. Tank would be above ground but it could be hidden from view then plumbed to the pump. Anybody else make theirs funtional?
Dave
Re: Tokheim Model 39 Type BP [Re: chaingang] #162476
Mon Nov 30 2009 06:36 AM
GA
jkyocom Offline
jkyocom  Offline
GA
If you decide to do so, there is a place in Cartersville that can rebuild the meter to work correctly, they can also get parts for the pumping unit, or rebuild it too.
I can rebuild them too, but I have no testing equipment.
If you use an above ground tank, the air eliminator line needs to be plugged.
I sold a Bowser pump a few years ago to a guy who is using it to fill his bi-plane.
Page Time: 0.495s Queries: 15 (0.177s) Memory: 1.9323 MB (Peak: 2.1032 MB) Zlib disabled. Server Time: 2018-10-22 15:30:09 UTC
