Paint and body work #161304
Sun Nov 22 2009 07:58 PM
COLORADO
LC 336 Offline OP
LC 336  Offline OP
COLORADO
Hi guy's, does anyone know of a good paint and body man in the Colorado area? I am in Arvada, but I can travel if necessary.
Thanks Lee
Re: Paint and body work [Re: LC 336] #161312
Sun Nov 22 2009 08:11 PM
Four Corners
itsagas Offline
itsagas  Offline
Four Corners
What do you need done?
Re: Paint and body work [Re: itsagas] #161326
Sun Nov 22 2009 09:02 PM
Oneida IL USA
gasoildude Offline
gasoildude  Offline
Oneida IL USA
Now you know Lee we will want pictures wink smile
Brad Ralston & my website is
www.petrobarn.com
Re: Paint and body work [Re: gasoildude] #161351
Mon Nov 23 2009 02:37 AM
COLORADO
LC 336 Offline OP
LC 336  Offline OP
COLORADO
I am restoring a couple pumps, they will need minor body work and then everything painted. Sometime after the first of the year. The parts would be sand blasted,and everything would be taken apart. If possible I would like to emboss a couple of the new skins. If I new it would work, I would cut out a pattern of the origional embossing and redo it on a new skin. "Tokheim 34" prety simple pattern, i just wonder if you would get warpage.
Or maybe cut out patern and tack weld on skins. If this can not be done just simple body and paint on.
Any help would be appreciated, thanks for the responce.
Would be glad to post some pictures when done.
Lee
Re: Paint and body work [Re: LC 336] #161371
Mon Nov 23 2009 08:18 AM
New Mexico
Old Iron Offline
Old Iron  Offline
New Mexico
Hi Lee,
Your concern about panel warpage from sandblastihg is well founded. Personally, I had so much problem with it that I haven't done it in years. See what some of the other guy's think; maybe I just had bad luck. Is that a 34 you are working on?
Re: Paint and body work [Re: Old Iron] #161373
Mon Nov 23 2009 08:36 AM
Four Corners
itsagas Offline
itsagas  Offline
Four Corners
Its true if done wrong sandblasting can really hurt a panel. But if you have someone who knows how to do it and uses the right media, then it can't be beat for getting a panel clean and ready for body work.
Lee I sent you a PM
Re: Paint and body work [Re: itsagas] #161408
Mon Nov 23 2009 03:35 PM
COLORADO
LC 336 Offline OP
LC 336  Offline OP
COLORADO
Yes its a Tokheim 34 I'm working on.
I was also concerned about warpage when trying to re emboss it.
Thanks Lee
Re: Paint and body work [Re: LC 336] #161428
Mon Nov 23 2009 06:46 PM
Four Corners
itsagas Offline
itsagas  Offline
Four Corners
Ok, Here's what I ended up with after a bit of work.
Re: Paint and body work [Re: itsagas] #161431
Mon Nov 23 2009 07:04 PM
Jackson, MO, USA
sanford Offline
sanford  Offline
Jackson, MO, USA
That looks good. How did you end up with that, did you make a die to stamp it? I have a 34 and was thinking of making something like that or adding a second layer to my repro skins.
tony
Re: Paint and body work [Re: sanford] #161433
Mon Nov 23 2009 07:17 PM
Cameron Park,Ca.
MATT ALVAREZ Offline
Cameron Park,Ca.
That stamping does look good. I have been banging, hammering and heat shrinking on my original doors. Alot of work just to save that little design. One door is in primer ready for paint and the other has the metal work done and ready for body filler.
Re: Paint and body work [Re: MATT ALVAREZ] #161448
Mon Nov 23 2009 07:56 PM
Oneida IL USA
gasoildude Offline
gasoildude  Offline
Oneida IL USA
That is really cool!! Very nice work smile
www.petrobarn.com
Re: Paint and body work [Re: gasoildude] #161713
Wed Nov 25 2009 02:45 AM
BEULAH CO
besgar Offline
besgar  Offline
BEULAH CO
Wow that looks good! Be carefull you will have fleet of new skins showing up to be done. HA HA. Nice work.
Re: Paint and body work [Re: besgar] #162363
Sun Nov 29 2009 02:03 PM
Four Corners
itsagas Offline
itsagas  Offline
Four Corners
A little more work on my dies and I will be ready to stamp out as many panels as you guys need done. grin
Here is another one I was playing with...
Re: Paint and body work [Re: itsagas] #162433
Sun Nov 29 2009 06:44 PM
COLORADO
LC 336 Offline OP
LC 336  Offline OP
COLORADO
That would look sharp on an old street rod pump.....
Re: Paint and body work [Re: LC 336] #162440
Sun Nov 29 2009 07:00 PM
Cameron Park,Ca.
Cameron Park,Ca.
Here is the one that was mudded before primer.
Page Time: 0.030s Queries: 14 (0.007s) Memory: 1.9197 MB (Peak: 2.0705 MB) Zlib disabled. Server Time: 2018-09-26 13:42:19 UTC
