#164634 Sat Dec 12 2009 03:17 PM
Looking for an access door for a bowser 510/565, thats the only thing I am missing on my pump.
Donnie
Looking for anything Hancock, Signal, Veedol/Flying A and Richfield
Donnie,
I believe that is the same as a 575, I can check to make sure, if so, I have it.
Tom.
Carthage Indiana
Tom if it is the same door as the 575, let me know what ya want for it
thanks
Donnie
Tom, Donnies pump needs a large removable acc door (not hinged). The 575 will not work.
So close, yet so far frown
Donnie, I have a 565 that is also missing the access door. If the size is the same I can build a replacement.
I think it is the same, from what Matt told me the only difference between the 510 and 565 is the 510 is a non computing pump. Let me know.
Donnie
A new one would be pretty easy to duplicate if you have a bead roller.
Tony
Donnie,
I'm out...I have a 557 and a 565 and both of them are missing that door. They would be easy to fabricate, both pumps use them same door.
Tom.
Carthage Indiana
Thanks Tom
Donnie, I have this door in stock. Contact me at paulhittle@juno.com and I'll send you a picture. Paul
Paul, email sent
Donnie
Got one, Thanks Paul
Donnie
Looks like I am too late. wink Here is the door I made for mine today. Its a little different than original, I did not use a lock.
Itsagas,,,,
Can you make a set of access panels for a 245 Bowser????
Pg 92 of Jack's book...the small ovals near the base.
I have been needing a set for over 10 years now.
I will have to find a loaner or find someone to make a pattern.
I KNOW GOOD 'OL MR. BENNETT HAS A PUMP LIKE THAT!!!!!!
hint, hint.
Veeder Root Identification CD
Gas Pump Clock Repair
jkyocom@bellsouth.net
