#164706
Sat Dec 12 2009 07:32 PM
Posts: 2,050 Likes: 4
Posts: 2,050 Likes: 4 |
I picked up a nice straight Wayne 70 this past fall at Peotone. Took the computer out and removed the trim parts last night. Took it to the paint shop today. The paint guy looked it over, was very impressed with the pump as it needs minimal body prep work. Said I may even get it back this week yet. In the trailer on the way home; At the shop; It had a repaired base on it but I got another good base when I bought the pump. Does anyone have a good picture showing how the light manifold attaches? Thanks
Posts: 3,622 Likes: 1
Posts: 3,622 Likes: 1 |
Already looks great. Cleanest looking before shot I have ever seen. Mike
Posts: 1,519 |
What brand are you going to do Wes? very staight I did a wayne 70 one of my favorite pumps.
I would bet it will end up Sinclair. Dont know why but I just have that hunch
Posts: 744 |
Wes--
On the inner top of your Wayne 70 (that looks like a range hood in a pit bbq restaurant) there are two holes. You put a couple of machine screws through those and attach the light monofld via two cut out areas in the light manifold casting. As you look at it, you'll see that there will be two light sockets per door when it is attached to the inner top. You can use nuts or wing nuts to cinch it up. Hope this helps. Dave Folck
It is getting a gloss black base, red body and white doors. I will put a Sinclair globe of some kind on it, possibly an Ethyl. I already have a couple red and while pumps but I like them so I am getting another one.
Dave Thanks for the light manifold installation directions, they should be just what I need. Hope to pick it up this Wednesday or Friday
Got my pump back Saturday. Took a little longer than planned but there is no reason to rush the Paint Man. I think he did a nice job on it. The old base was cracked and had a patch on it but I got a replacement when I bought the pump. Swapped the base out and put on the doors so far.
Posts: 197 |
Looking great Wes, I just about have my 70 put back together. I did mine all red and it is going to be a Texaco Sky Cheif.
Hey Wes--Looking good! It'll be great to see it as a finished pump! I like these "in progress" photos. Kind of gives me ideas for the next restoration! Nice to see how others do it.---KEVIN
Looks good there Wes
Got some more parts on the pump; Got the add glasses from Vic's; Put in the computer, may go for a restored one some time. Popped on the faces and the face plate glass. Put on a globe ring and a US Motors globe. It has a new hose on it, the nozzel is an old one I still need to polish and clean up. Have some small things to do to it yet. Am working on a set of US Motors add glasses for the front also. Does any one know how these two items are fastened on? Pins, rivets?
i dont remember the name but they are held on with small pins that have a rounded top,no slot for a screw driverthey push in tightly and hold the plates on.someone here will know the name of them
Posts: 2,139 Likes: 48
Posts: 2,139 Likes: 48 |
Looks great Wes, keep up the good work!!
Posts: 2,336 Likes: 2
Posts: 2,336 Likes: 2 |
i recently got door to a 70 and only one screw was attached,it was threaded and i want to say it was Phillips,very small ,the pics of the wayne name plate are under showcase & stories ,"thrift store find in Houston" i can provide a pic sat if need be!
The ID tag probably had very small slotted screws that held it on and the "WAYNE" tag would have had the small pins as oldnfuelish stated. I don't know what they are called either. I have never seen phillips head screws in old pumps with the exception of some of the later version pumps in the 50's and those were limited in use.
Most ID plates were put on w/ Twist Rivets.
Posts: 398 |
Keithia, you make a good point about the phillips screw. I talk to a lot of people who restore cars, gas engines,furniture and all kinds of antiques, and remind them that the phillips screw was not invented untill 1937 and certainly could not have been found in anything made before then. I refer to those pins as "spiral rivits" they are used to hold nameplates on electrical gear and motors also. However one little slip when you use them can sure mess up a nice paint job. Norm.
Norm Huff
1936 Caddy was 1st auto to use the Phillips head screws.
Posts: 2,702 |
On my Wayne 70 I believed I used slotted 4/40's from the hardware store in town. Quick and simple. : ) Here's your drill size http://www.marfas.com/machinescrewtapping.shtml
Posts: 4,005 Likes: 7
Posts: 4,005 Likes: 7 |
Dick is correct, aluminum twist rivets, got mine at Fastenal.
