#165147
Tue Dec 15 2009 07:33 PM
Posts: 473 |
I am trying to find some pics for reference if anyone has anything. Thanks Bob
I have looked through my gas pump literature collection for any reference to the 665, but I can find nothing.
The closest thing I find is a a 65 or 66, which was a Tokheim conversion kit for the G&B pump. It is shown on page 162 of my Gas Pump Identification book. This was a conversion kit for the G&B 105.
While I don't usually ask for pictures, one is needed here.
Maybe its a 65 or 66 curb type pump which wasn't a true clockface but had a round gallon indicator on it???? Jack is right--get some pictures up and if you can't get them posted, send them to me and I'll get them posted for you.
Posts: 473 |
Kevin, I will email you a pic. There is one listed in Jack's new book on page 160 is closet I have found.
Restored pump was sold by Nicky Fox @ Iowa Gas a few years ago.
Bob did you acquire one of these? If so Im jealous
Posts: 473 |
I actually picked up two of them. Thanks for the pictures DB. Mine are actually a little different. I sent a pic to Kevin Frith in hopes he would post it.
Hey Bob--Still trying to find out how to move the picture from my email. I gotta run right now but I'll get it figured out. Later--KEVIN
Here's Bob's pump & a half
Heres a pic of Bob's new pump. Thanks for the help DB! Looks like we were posting it at the same time. aaaaoh well, 2 pics are better than one anyway!!!
IMO, That is one of the best looking pumps G&B ever made.
Electric operated. Still a Heavy Pump like most of the G&B's !
Knowing guts like I do, it surprised me that it has a cylinder. How in the heck does THAT WORK????....I understand piston goes up, piston goes down, but the motor & belt goes round and round
Posts: 473 |
I was amazed at how much they could pack in that little space for a motor and pump to operate it. The tall has the same sight glass as the smaller one it was just in a box when I got it.
Posts: 473 |
Forgot to thank Dick and Kevin for the help on putting pic's on. One of these days i will get it.
Motor turns a gear that raises the rack on piston. Gear kicks out @ top of stroke or goes into a back gear allowing piston to return to bottom for another lift.
FUNKY!!!!! Afterwards the by-pass valve was invented!!!!...????
Very cool
Posts: 281 |
In that 3rd pic above it looks like a bypass valve ( w/ brass cap) and a check valve or screen filter next to it, that cylinder may pump in both directions. I would like to see the mechanism the motor belt drives. Interesting !!
After closer inspection of the pump & a half pic, the pump on the left shows the pumping unit in the background inside the pump and the right part shows the motor so what the heck is the huge cylinder for???/ Air eliminator?????
Joe--I believe what you're seeing is the gearbox that raises the piston rack and not a pumping unit. That large cylinder is the piston pump. IMO
Look closer at the pump and a half they are facing the same direction the left one is missing the motor that is a pumping unit in the left one The right one is a motor The rack for the cylinder would have to come out in the center and if it did it would hit the clock. I see no rack and no hole.
You have all the correct components to make an electric pump work....motor, pumping unit and it looks like a Trident clock reset knob so it would have a Neptune( Red Seal) meter in it. Only thing that is missing from the lineup is an air eliminator. Gilbarco used air eliminators in their later pumps that are scaled down versions of a cylinder like that....that rattley cylinder that is next to the computer on a TRIMLINE pump.
Jeff's is showing the pumping unit on the right and the motor on the left. Between the two veiws of the pumping unit, the unit looks similar to a Wayne or Southwest pumping unit...some Wayne and Southwest pumping units are almost identical. The brass cap is access to adjust the tension on the bypass valve spring. The bypass valve opens & recirculates fuel when you have the nozzle closed so the pump does not lock up.
Posts: 473 |
DB the box looking thing at the top opposite the visiguage is where the ID Tags are mounted.
Joe, I see what you mean. I went out to the farm and checked my 65, which is very similair but is a crank unit. The cylinder is the pump on that one and it has a brass rod going down the center of the cylinder that is lifted by a gear rack on each side of the cylinder. This rack goes up into the tower to raise the pump cylinder and you can barely see it. You're right in that there is no lift mechanism protruding above the cylinder and there wouldn't be enough room in the tower above it anyway. The cylinder looks exactly the same as a 65 and must have been converted for another use. Very interesting pump!---KEVIN
I have had several pumps like the one you are describing, that is what had me so puzzled on this one. It didn't make sense to have a stroke pump and radial drive. My 245 has the rack & pinion setup, and has a cutout for the rack to come out of the sheetmetal. And a huge packing nut, and cylinder inside the cabinet and is a manual pump.
A 276 Wayne has a drive system similar to what DB was describing but it is manual....Handle in to pump (rack up), handle out to reset(rack down) ??...same direction of drive. But to hook some kind of drive like that to a motor would be rediculous from my point of veiw.
I've never had this pump, so was only guessing how it COULD work. Your right about the lifting rod hitting the clock mech. Joe.
http://www.petrolianacollectibles.com/gb%20trim.htm2nd pic down shows cylindrical air eliminator on left of computer in pump on the left
Posts: 3 |
