#190767
Sat Jun 12 2010 01:14 PM
Posts: 1,550 |
Hi All, I finally started putting my pump back together and think I have figured out where most things go. I know there are a few parts I will have questions about, but right now I am trying to figure out how to rewire the lights. I know this has been discussed but cant seem to find it in the archieves. I recall reading that the hard,black sealant (bakelite?) is difficult to remove and is toxic to burn so I decided to run my new wires through an unused plug in the manifold (I believe thats the term for the cast iron piece that the light sockets screw in to?) The plug is rusted solid. I have sprayed it with PB Blaster for 2 days and cant get it to budge. Would heating with a propane torch do any good? Any other suggestions to get it out? Also, it looks like the black sealant is also in the bottom of the light sockets so I am going to have to deal with that eventually in order to put new sockets and wiring in the porcelain. Whats the best way to remove this stuff? Also, what is it called so I can try searching that? Many thanks, John
Posts: 2,738 Likes: 61
Posts: 2,738 Likes: 61 |
When I took the wiring out of my Wayne 866 manifold I just broke the black sealant stuff up with a straight screwdriver and a hammer and had to pull like H**L to get some of the wiring out but it came out. That's about the only part of your question I can advise on! Darin
Posts: 1,557 Likes: 4
Posts: 1,557 Likes: 4 |
Torch/burn the livingn hell out of evrything. Get all the junk out and yes it does nothing good for the respiratory system. Once out you will be much happier hold it upside down and it runs like lava. Also heat the metal and get a large pipe wrench to break the seal. It will eventually come off or break. Heat, heat heat and remember that there are few things in life that can't be solved with brute force.
Kris Strong
Posts: 2,460 Likes: 24
Posts: 2,460 Likes: 24 |
John, I really think that the black sealant is nothing more than tar. I remember that in the Fifties and Sixties, it was used by the can, to seal just about everything. Kris is correct, you need to melt it out. There might be a bit of oakum in the pipes to act as a blocker for the tar. Try an electricians snake if it is too much to push out with stiff wire? Where ever you have a tight elbow, you might have to take it apart to clean and then run the wire before you reassemble? Good luck, Paul www.severngaspumps.com
Posts: 18 |
The best way I've found to remove the black stuff is chipping it out with a screwdriver. It fills all the the pipe nipples and conduit to make it explosion proof. You need to unscrew any pipe nipples and conduit from the main manifold(electrical box) and clean it out. Using anything to try and soften the stuff will only make a real mess.
Posts: 2,250 |
I use a torch like southfloridagas and the rewire everything. Its easier in the long run
Posts: 1,550 |
Thanks guys. Thats the thread I was thinking about. I tried scraping that stuff out a little yesterday and think I will have to put the heat to it. Very slow going and am afraid I will break the porcelain sockets. Still cant get that plug out so I will either try to clear the manifold pipe or go through the hole for the light socket on the back side of the pump. Thanks again. Probably more questions later today. John
Posts: 3,739 Likes: 87
Posts: 3,739 Likes: 87 |
John:
Don't worry so much about the porcelain part of the sockets too much - you can always replace that part. Worry about the white metal bases on the sockets. Some of those are no longer available.
You can by porcelain sockets at Lowe's or Home Depot. Remove the porcelain part and reinstall it into you original base.
Posts: 858 |
Either torch it or stick them all in a metal barrel with some wood/paper and burn it. It'll melt out and then resolidify. That's the only way I've found that is "easy".
Posts: 1,550 |
Update: I was able to chip it out of the manifold,pipe and switch with a screwdriver without much of a problem. It pretty much fractured when I gave it a good whack. One I got one wire loose, it all fell apart. The porcelain lamp holders are a different story. I scraped one out after a long while and decided to just get new ones. Bought some at the hardware, brought them home, but there was no way to attach the metal threaded piece to it that screws in the manifold. Then I tried to rewire the old one I had already cleaned out and the new end clips for the wire that attach to the porcelain socket were too big. Spinning my wheels all day. Ill try to find some smaller ones tomorrow. John
Posts: 1,550 |
Jim, Do the porcelain sockets at Home Despot fit onto the white metal bases? If so, Ill get those and save a lot of time and effort. John
Posts: 1,550 |
Forgot to ask. What size and type wire is everyone using. Looks like the old stuff was #10 aluminum twisted. I was going to use 14/2 twisted wire (copper) from the lamp sockets through the manifold to the switch, then run 14-2 romex from the switch to my plug. I would think 14 wire would be plenty for 2 lamps/80 watts and would be easier to work with than 10 wire. That sound ok? Thanks guys. John
john see if travis has any more of the light sockets he had.i bought a dozen from from him,they work great and fit alot of different pumps.
Even 18 guage wire is OK. You won't want to be using too big of lamps in the pump anyway. Too big causes heat buildup and all you need is enough light to illuminate it for the room you have it in. Definitely don't over wire the thing.
Here is one of the sockets I keep in stock. I got it on-line, but I don't remember where. This hex end will fit 'most' pumps as is without any modifications.
But . . .You can buy any porcelain socket that Lowe's or Home Depot sells - but you need to remember that you need to have two (2) screws in the bottom of the socket assembly. These are what attach the porcelain assembly to the white metal piece. You have to take the old pump socket(s) apart anyway to re-wire it so you might as well start with a new porcelain socket.
Here is a shot of the unit apart. The screws are 'captured' in the porcelain piece so they won't fall out during assembly.
And here is one of the 'rare' 90-degree fittings that you need for a M&S 80. I keep a few of these in stock, sandblasted and ready to go for restorations.
When I need one - I just swap out the straight hex end for the 90-degree end and I'm set.
I hope this helps.
Here is one place you can buy the sockets on-line. Not cheap, but these can be hard to find if you don't have a large electrical supply house available locally.
Socket
Posts: 1,550 |
Thanks Jim, that is helpful. The new sockets I got at the hardware have the holes that match up with the white metal piece but they are too small for the screw to fit. If I use a smaller screw, its too small to grab the threads in the metal piece. I thought of drilling the holes bigger, but it looks like the holes are rivits that hold the metal socket to the porcelain. Afraid it will fall apart if I drill them out. I wonder if I could put some JB weld or something like that in the whire metal holder to hold the smaller screws in? Does JB work on white metal? Little reluctant to do that in case I need to replace it someday. Can I assume the ones at Home Despot have larger holes in the porcelain? I can run there later in the week and get them and smaller wire. If not, Ill check with Travis Thanks everyone. John
Posts: 18 |
I wouldn't think of trying to reuse a porcelain socket, the contacts in most are dirty or shot. I buy all new sockets at Lowe's for 3 or 4 dollars ,they come in a bag brand "Servalite" part no 10045U. The porcelain is screwed into a bottom for a quarter inch thread like a lamp. Unscrew the 2 screws inside the socket and throw out the new metal bottom. The 2 screws match up exactly to the old mountings.
Posts: 1,550 |
Thanks Doug. Actually the sockets on mine look pretty good, so I could reuse them. Nearest Lowes is over an hour away so am hoping I can make the ones I bought at the local hardware work, or get others at Home Despot. Do the ones at Lowes have screw holes that are the same size as the metal part that you screw it to? John
Posts: 18 |
I've never been able to find them at Home Depot, always got them at Lowe's. The porcelain one's I get are identical to the old porcelain socket and once you remove the the new metal bottom the screws go right into the old metal bases. Perfect fit, look exactly like original.
I buy mine at Orchard Supply Hardware. They have a good selection except for the one with the big threaded base. I found this web site on my hunt for them. Cheapest I could find without having to buy a whole box. http://www.thecollegetoolbox.com/leel.html
Posts: 762 Likes: 8
Posts: 762 Likes: 8 |
Thanks Matt for that website. The last time I needed some of those I went Lowes and bought the sockets then made the adaptors. That was a pain. Mitch
Posts: 1,550 |
Good site to know Matt. My metal base has male threads that screw into the manifold. I suppose I could just add a 1/2" nipple to the female ones they sell,or try to swap out the bases. I am hoping to get it wired tomorrow as its supposed to rain so want to see if I can rig something up. As I said above, the screw holes in my new porcelain sockets are smaller than the old ones. So if I use a smaller (diameter) screw to fit them, they dont screw into the base because the holes in the base are larger. Could I use JB weld, or maybe lock tite or silicone to get them to stay put? If I did, will I be able to get it apart in the future if I need to? Another question. I bought #18 lamp wire as suggested which will be a lot easier to wire, but I am wondering about grounding. The plugs that fit the lamp cord are only 2 "pronged". I know that the sockets themselves are grounded but am worried because the pump is going to be outside. The outlet that it will plug into is a GFCI. Do I have anything to worry about? Thanks again for all the advice. John
Posts: 1,550 |
Can someone chime in on whether I can use JB weld,silicone,lock tite or similar product to get the smaller screws to attach to the metal bases on the sockets? (See above post for details) Id like to give it a shot today if I can. If not, Im going to have to order new sockets I guess. Also, do I have anything to worry about with the lack of a ground wire if I am plugging it into a GFCI? Thanks guys, John
If your old bases are broken or do not fit, simply remove them and change out to a 1/2 inch street elbow. Them use the new porcelain base mount and screw it on. Very easy fix as long as the new sockets you bought have 1/2 inch mountings. As for grounding. Consider....when they were built.....no one grounded anything. Furthermore....the GFI works as a failsafe in this case. Paul www.severngaspumps.com
Posts: 1,550 |
Well, I give up on trying to rewire my old ones. The biggest problem is the screws that attach the wires need to go into a wire connector that acts like a nut. Cant find any small enough. Tried modifying bigger and smaller ones, but cant get a good connection. Id like to find a socket with a male end like mine with screws that you can just wrap the wire around. I suppose I can try to modify the female bases, but does anyone know where I can find some like this?
I have only seen these as I cut them out of the old pump and replaced them with the type shown above in Tways response. Never seen a place to buy new ones as I never had a need.....always used what was available....Consider doing a little new plumbing to accept the newer sockets. I'm not sure how much time and agravation you have spent on this simple job but try it this way now....it will be a bit easier, I'm pretty sure. Good luck, Paul www.severngaspumps.com
