Page 1 of 3 1 2 3
WORTH A TRY.... #194296
Tue Jul 13 2010 05:45 PM
PECONIC BAY, L.I., NY, USA
THE AMERICAN GARAGE Offline OP
LAST MONTH I SCORED SOME CHEAP ESSO REALTED SIGNS IN JERSEY. THERE WERE 4 TOTAL AND THE GUY SAID THAT IF I BOUGHT ALL THE SIGNS, HE'D THROW THE 4TH ONE IN FOR FREE. THESE WERE ALL PRE-WWII.
SADLY THIS RARE ESSO AVIATION PRODUCTS SIGN (9' X 3') MADE OF TIN SPENT A VERY LONG TIME ON A ROOF IN SOUTH AMBOY, NEW JERSEY POSSIBLY USED AS LEAK PROTECTION OR IN PLACE OF TAR PAPER(?). WHATEVER THE CASE MIGHT'VE BEEN, THE GUY FOUND THEM (ALL 4 SIGNS) A YEAR AGO WHILE RIPPING OFF SEVERAL LAYERS OF SHINGLES. UNFORTUNATELY, THE SIGNS SAT OUTSIDE FOR ABOUT A YEAR IN THE ELEMENTS NOT GETTING OR LOOKING ANY BETTER.
ON CRAIGS LIST ONE NIGHT I SPOTTED THE SIGNS IN AN AD WITH HORRIBLE PICTURES THAT HIGHLY INTRIGUED ME. I SPOKE TO THE GUY ON THE PHONE AND
MADE PLANS TO COME AND LOOK WITH THE OPTION TO BUY ON SATURDAY JUNE 19TH. LONG STORY SHORT I CAME HOME WITH ALL 4 SIGNS ON MY 10' TRAILER.
HERE IS A PICTURE OF THE SIGN RIGHT OFF THE TRAILER:
I SAVED THE CLEANING AND TOUCH-UP OF THIS HEAVILY INFLICTED FOR LAST AS THE OTHER SIGNS DID QUITE WELL ONCE I PULLED SEVERAL DOZENS OF ROOF NAILS FROM THE FRAMES, REMOVED TAR AND SHINGLES, ETC.
I WOULD BRING OUT THIS ROUGHLY 6-7LB TIN SIGN IN THE COOL MORNING HOURS AND LAY IT FLAT ON MY OUTSIDE 8' X 33" WORK TABLE.
I STARTED BY REMOVING ALL THE FLAKING LOOSE PAINT WHICH MADE THE SIGN LOOK EVEN WORSE. I LIGHTLY SANDED ALL THE HEAVY RUST AND EDGES WHERE THE ORIGINAL PAINT MET THE BARE METAL. FOLLOWED THAT UP WITH A POLY CLEAR COAT TO HELP SEAL THE RUST AND BARE METAL THEN LET IT DRY:
I FOLLOWED ALL THE CLEAR COATED AREAS WITH A SOMEWHAT CLOSE MATCHING CORRESPONDING COLOR. I STARTED WITH RED, USING A FOAM BRUSH IN THE LARGE AREAS AND A TOUCH-UP BRUSH IN THE DETAILED AREAS
WHERE NEEDED:
I FINISHED THE RED AND FOLLOWED UP WITH THE OFF WHITE. HERE'S A PICTURE OF THE SIGN MINUS THE BLUE TOUCH-UPS ABOUT HALF WAY DONE:
Re: WORTH A TRY.... [Re: THE AMERICAN GARAGE] #194297
Tue Jul 13 2010 05:46 PM
CON'T....
THE BLUE AREAS WERE TRICKY, BUT AS YOU CAN SEE WERE IN OPPOSITE AREAS AT LEAST ON THE WINGS. I BASICALLY TRACED THE AREAS TO BE FILLED IN WITH OFF WHITE AND BLUE AND REVERSED THE TRACING ON THE OPPOSITE WING. THE OVAL BLUE BORDER AROUND "ESSO" WAS TOUGH BUT DID THE BEST I COULD WITH MY EYES AND JUDGEMENT.
I ALSO MIXED ALOT OF OFF WHITE AND RAN A FOAM BRUSH AROUND THE BORDER FOR GOOD MEASURE.
NEXT ON THE PROCESS WAS WAIT FOR A LOW HUMIDITY DAY AND THAT CAME THIS PAST SUNDAY JULY 11TH. AT 60% HUMIDITY I BROUGHT THE SIGN OUT AND POURED OUT SOME BRAND SPANKIN' NEW MINWAX SEMI-GLOSS CLEAR POLYURETHANE AND PROCEEDED TO ROLL IT OUT WITH A 4" FOAM ROLLER AROUND NOON UNTIL COMPLETELY COVERED. BY 2PM FULL SUN COVERED THE SIGN AND GAVE IT A NICE BAKED ON JOB! AT 5PM, I STARTED TO CUT LUMBER AND DOOR MOULDING TO SANDWICH THE SIGN FROM FRONT AND BACK FOR A FINISHED LOOK AND FOR SAFETY SAKE AS THE EDGES OF THE SIGN WERE TETANUS SHOT WAITING TO HAPPEN!
I USED 1X 3" #2 PINE BOARDS FOR THE ENTIRE OUTSIDE EDGE FRAME ON THE BACK AND SOME KIND OF COMPOSITE MATERIAL MOULDING ON THE FRONT SIDE WHICH CAME PRIMED AND I PAINTED WITH A WATER BASED ACRYLIC IVORY WHICH CLOSELY MATCHED THE OFF WHITE ON THE AGING SIGN. THIS WAS THE ONLY TIME I USED A WATER BASED PAINT. ALL OTHER TOUCH-UPS WERE DONE WITH OIL-BASED AND WITH VARIOUS BRANDS.
HERE IS A SHOT OF THE CORNER KINDA LIKE A CUT AWAY VIEW:
I LINED UP THE PINE ON THE BACK WITH THE MOULDING ON THE FRONT EDGE KEEPING THE SIGN EDGE SANDWICHED IN BETWEEN AND OUTTA SIGHT. THE MOULDING WAS 2.1/2" WIDE AND COVERED ABOUT 90%+ OF THE ORIGINAL BORDER.
FROM THE BACK ABOUT A 1/2" IN FROM THE OUTSIDE EDGE I USED COARSE DRYWALL SCREWS 1.1/4" LONG AND DRILLED IT THRU THE PINE, THE SIGN AND INTO THE MOULDING. ONLY ONCE DID A SCREW POP THRU THE FRONT SIDE DUE TO A SOFT SPOT IN THE PINE I GUESS. SO, FOR THE MOST PART THE BACK FRAME AND FRONT MOULDING IDEA WAS STARTING TO COME TOGETHER....NO PUN INTENDED! smile
(DINNER BREAK...PIZZA WITH THE FAMILY AT 6PM).
7PM, AFTER DOING THE BOTTOM SECTION OF THE FRAME EARLIER, I CAME HOME AND DID THE TOP SIDE THE SAME WAY. THEN THE SIDES. I COULD SEE FROM THE GHOSTY MARKS ON THE BACK OF THE SIGN THAT THERE WERE 3 SUPPORTS FROM TOP TO BOTTOM. I USED 1 X 2" #2 PINE HERE AND SCREWED THESE IN PLACE WITH 3.1/2" DECK SCREWS PRE-DRILLED FOR OBVIOUS REASONS:
THE NEXT MORNING I BROUGHT THE SIGN OUT INTO THE SUN FOR THE FINAL PHOTO SHOWING A SIGN THE MAY NEVER BE PERFECT BUT WORTH A TRY:
IT DEFINITELY LOOKS MUCH BETTER AND IS SOMETHING THAT I MIGHT EVEN HANG IN MY BASEMENT EVENTUALLY. NOT TO MANY PLACES I HAVE LEFT TO HANG A 9' WIDE SIGN! LOL! I KNOW I STILL HAVE TO REPLACE THE "U.S. REG PAT OFF" BELOW THE "ESSO" LOGO....WILL NEED TO GET STENCILS FOR THIS. THEN IT WILL BE OFFICIALLY DONE!
THANKS FOR READING AND LOOKING!
wink
Re: WORTH A TRY.... [Re: THE AMERICAN GARAGE] #194299
Tue Jul 13 2010 05:49 PM
Antioch,IL
oldnfuelish Offline
oldnfuelish  Offline
Antioch,IL
looks great doc!!
Re: WORTH A TRY.... [Re: oldnfuelish] #194300
Tue Jul 13 2010 05:54 PM
Janesville, Mn. 56048
Esse's Garage Offline
Turned out great!!
Re: WORTH A TRY.... [Re: THE AMERICAN GARAGE] #194301
Tue Jul 13 2010 05:56 PM
Albuquerque, N. M.
HI-OCTANE Offline
HI-OCTANE  Offline
Albuquerque, N. M.
Looks excellent" " JOB WELL DONE "
wink
Re: WORTH A TRY.... [Re: HI-OCTANE] #194329
Tue Jul 13 2010 08:43 PM
Pueblo Colorado usa
DuceCpe Offline
DuceCpe  Offline
Pueblo Colorado usa
NICE Doc!
Re: WORTH A TRY.... [Re: DuceCpe] #194338
Tue Jul 13 2010 10:48 PM
Marshall Va USA
archer2 Online content
archer2  Online Content
Marshall Va USA
Super job Doc, looks great. Love that aviation stuff.
Ed
Re: WORTH A TRY.... [Re: THE AMERICAN GARAGE] #194340
Tue Jul 13 2010 11:31 PM
Ontario, Canada
barn_raider Offline
barn_raider  Offline
Ontario, Canada
Nice work there.
Re: WORTH A TRY.... [Re: barn_raider] #194344
Wed Jul 14 2010 12:44 AM
Gualala, CA
Scott Baselt Offline
Gualala, CA
Very nice job !
Re: WORTH A TRY.... [Re: Scott Baselt] #194358
Wed Jul 14 2010 05:33 AM
OKC, OK
publicenemy1925 Offline
OKC, OK
Fantastic work!
Re: WORTH A TRY.... [Re: publicenemy1925] #194360
Wed Jul 14 2010 06:13 AM
Spokane, Washington
hillsideshortleg Offline
Spokane, Washington
Nice sign Doc! I have room if your having problems. Reduce the stress of deciding where to put it. Just ship it!!
Re: WORTH A TRY.... [Re: hillsideshortleg] #194363
Wed Jul 14 2010 06:16 AM
Down in Mississippi
bmclemore Offline
bmclemore  Offline
Down in Mississippi
Good job on that Doc.
Barry
Re: WORTH A TRY.... [Re: publicenemy1925] #194408
Wed Jul 14 2010 03:45 PM
Moline, IL, USA
Mac Offline
Mac  Offline
Moline, IL, USA
Doc,
You are truly an artist. Sweet work. I love the way you framed it out in white rather than trying to touch up the white border. I can't believe it's the same sign! Get that thing hung up in the house!
Great job!
Mac
Re: WORTH A TRY.... [Re: Mac] #194416
Wed Jul 14 2010 04:41 PM
Wellington MO
TomL Offline
TomL  Offline
Wellington MO
Great job
Re: WORTH A TRY.... [Re: TomL] #194418
Wed Jul 14 2010 05:02 PM
La Porte, In
tomzcollectiblez Offline
La Porte, In
Killer job! Outstanding presentation!
Re: WORTH A TRY.... [Re: tomzcollectiblez] #194419
Wed Jul 14 2010 05:14 PM
THANKS EVERYBODY FOR THE NICE COMMENTS. WISH I COULD SHOW IT TO THE GUY I BOUGHT IT FROM.
Re: WORTH A TRY.... [Re: publicenemy1925] #194460
Wed Jul 14 2010 09:07 PM
Cameron Park,Ca.
MATT ALVAREZ Offline
Cameron Park,Ca.
That is a good looking sign.
Re: WORTH A TRY.... [Re: publicenemy1925] #194463
Wed Jul 14 2010 09:49 PM
Portland Oregon
Craig Osbeck Offline
Portland Oregon
Great job making something out of an outcast. Had to do the same thing one time, and it is just as enjoyable as a perfect one. Excellent idea with the frame and one to remember.
Thanks Craig
Re: WORTH A TRY.... [Re: THE AMERICAN GARAGE] #194500
Thu Jul 15 2010 06:38 AM
California
Gas Pump Rob Offline
California
Wow that came out nice! Neat sign!!!!!
Rob
Re: WORTH A TRY.... [Re: THE AMERICAN GARAGE] #194516
Thu Jul 15 2010 09:08 AM
New Mexico
Old Iron Offline
Old Iron  Offline
New Mexico
Hi Doc,
Very nice work.What I like most about it is that you are showing that with a little work it doesn't have to cost a ton to have a really nice sign,and then you explain exactly hou you did it.Well done.
Re: WORTH A TRY.... [Re: Old Iron] #194522
Thu Jul 15 2010 10:32 AM
California
pollyman Offline
pollyman  Offline
California
Well done. Thanks for sharing.
~Jason
6 ft signs & rare pump plates Signal, Hancock, Mohawk, Polly, Flying A, Douglas, Richfield, PDQ, Stinker, Beeline, Neon , Dealership.
Re: WORTH A TRY.... [Re: pollyman] #194955
Sun Jul 18 2010 05:26 PM
new zealand
bowserguy Offline
bowserguy  Offline
new zealand
very nice job, well done !!
CHEERS, FROM RIK IN NEW ZEALAND
Re: WORTH A TRY.... [Re: bowserguy] #194963
Sun Jul 18 2010 05:48 PM
Antioch,IL
oldnfuelish Offline
oldnfuelish  Offline
Antioch,IL
rik glad to see ya back!!
Re: WORTH A TRY.... [Re: oldnfuelish] #195054
Mon Jul 19 2010 08:28 AM
Grants Pass, OR, USA
bruzer75 Offline
bruzer75  Offline
Looking good Doc.
Re: WORTH A TRY.... [Re: bruzer75] #195063
Mon Jul 19 2010 11:07 AM
Las Vegas, Nevada
Jack R Offline
Jack R  Offline
Las Vegas, Nevada
Doc, you did a great job fixing the sign. Jack
Re: WORTH A TRY.... [Re: Jack R] #195125
Mon Jul 19 2010 07:10 PM
VT
V
Vermonter Offline
Vermonter  Offline
V
VT
im impressed and thanks for the tutorial.
John
Re: WORTH A TRY.... [Re: Vermonter] #195171
Tue Jul 20 2010 08:43 AM
DFW Texas USA
marxmobilgas Offline
DFW Texas USA
Doc
Would a small silkscreen work with that lettering?
Or would you have to worry about overspray?
Mark
Graphic artists chime in please.
Re: WORTH A TRY.... [Re: tomzcollectiblez] #195183
Tue Jul 20 2010 12:09 PM
TEXAS
DIESEL Offline
DIESEL  Offline
TEXAS
MAKE OVER 101, GREAT JOB DOC!
CHRIS
Re: WORTH A TRY.... [Re: marxmobilgas] #195189
Tue Jul 20 2010 01:14 PM
Originally Posted By: nbkz7w8
Doc
Mark
ARE YOU REFERRING TO THE "REG U.S. PAT OFF." THAT I STILL HAVE TO DO?
I'VE YET TO CONSIDER MY OPTIONS, BUT A SILK SCREEN SOUNDS LIKE THE LONG WAY TO GO...UNLESS THE S/S PROCESS HAS CHANGED ALOT SINCE I WAS A KID.
Re: WORTH A TRY.... [Re: THE AMERICAN GARAGE] #195346
Wed Jul 21 2010 12:34 PM
COLORADO
LC 336 Offline
LC 336  Offline
COLORADO
Wow that's a great job....... I'm going to be looking at rough signs in a different way. You made that sign come to life.
Re: WORTH A TRY.... [Re: tomzcollectiblez] #212038
Mon Nov 08 2010 05:46 PM
IT'S BEEN SITTING IN MY BASEMENT IN THE WAY UNTIL ABOUT AN HOUR AGO LOL!
FINALLY GOT IT OFF THE FLOOR AND DISPLAYED....WHEW! smile
Re: WORTH A TRY.... [Re: THE AMERICAN GARAGE] #212510
Thu Nov 11 2010 09:34 AM
Berwyn, IL
hvychev Offline
hvychev  Offline
Berwyn, IL
Absolutely freakin amazing job DOC.....
Page 1 of 3 1 2 3
Page Time: 0.057s Queries: 14 (0.006s) Memory: 2.0194 MB (Peak: 2.2749 MB) Zlib disabled. Server Time: 2018-06-24 22:52:35 UTC
