Page 1 of 3 1 2 3
#233288 Sun Feb 13 2011 11:06 AM
Mikemas Offline OP
Hello Forum Members - I came up with this post to help shed some light on the high quality of some of the newer signs that have recently been released.
Let me make a blanket statement that I’m not trying to sell this or other signs to any of the forum members. I only wish to expose this sign to hopefully dispel the rumors that all reproduction and newer signs are only scrap!
First off, it’s important to note this sign cannot be termed a reproduction, since it really does no replicate any existing sign from the past. This sign displays the recognizable Pegasus horse mounted on a flange, since the sign is 2-sided it offers the beauty and appearance of the horse jumping into space.
This product is typical of some of the newer signs we offer on our site. Unlike some of the other product out there, these signs have a quality of their own. Instead of just printing on flat straight cut piece of steel with a primed back, this sign is laser cut precisely like no other sign companies have offered in the past. If I can draw your attention to the close up images of the head or the front hoofs, you see that the laser actually rounds the edges of the steel therefore enabling just as much paint to be applied to the edge as on the field of the sign. You’ll also notice the fine blue trim line on the edges, which is thickened to again protect the sign from common chipping and rust spots that appear when the sign is mounted outdoors. Also pay attention to the surface of the sign, this coating gives both the illusion and durability of porcelain however unlike porcelain, this surface will never chip out have plugs missing when someone throws a stone at the sign.
This is an expensive sign to make since the there is both inside and outside cuts which all increase the time it takes to manufacture this product. In addition while most signs are made of 18-20, gauge steel, this sign is manufactured of even thicker material.
All in all, regardless of if you’re a vintage collector or just a guy who is dressing up his garage or basement, this sign can only enhance anyone gas collection. I hope I was able to shed some light on the new technology of both re-issue and new release signs.
Mikemas #233290 Sun Feb 13 2011 11:11 AM
...moderator: please move this topic to the 'Known & Suspected Unmarked Reproductions' forum, where it will do the most good...
gulfiend! #233295 Sun Feb 13 2011 11:22 AM
JUNK
gulfiend! #233296 Sun Feb 13 2011 11:22 AM
Mikemas Offline OP
Gulfriend,
Hello - This is not in any form of a known & suspected Reproduction sign of any sign from the past and has no place in a forum to where others are taking advantage of anyone.
I put up the post just to share it with other collectors and forum members.
Thanks for your consideration!
Mikemas #233297 Sun Feb 13 2011 11:25 AM
I have a lot of thoughts on this matter but somehow, knowing the explosive nature of this whole topic, I think it best to say nothing. Let's all try to use some restraint because this could turn ugly quickly.
........Dave
THEY NEED TO BE DATED, in a way that will damage the sign if removed.
Still looking for that Union 76 ball
And I collect big old porcelain neon signs
This sign appears to be undated, so it has been moved to the proper forum.
Mikemas Offline OP
I did want to note that I have been discussing markings with the manufacture and we are now looking into embossing a date and number in the inside portion of the 90 angle of the flange which would make it almost impossible to remove.
W
W
Mike lets not pretend that you know anything about manufacturing it takes no time to lazer cut 16 ga steel you can lazer cut these signs for 3.oo each and 10-1 they are not painted but powder coated.
ward
Mikemas #233304 Sun Feb 13 2011 11:34 AM
I DON'T OFTEN TYPE IN ALL CAPS, BECAUSE I DON'T WANT PEOPLE TO THINK I'M YELLING...PLEASE CONSIDER THIS TO BE YELLING, AS YOU SEEM TO BE 'TONE DEAF' TO WHAT EVERYONE ON THIS SITE HAS BEEN SAYING TO YOU...
...YOUR SIGN IS NOT DATED - SOMEONE, SOMEWHERE WILL BUY ONE OF THOSE SIGNS, BECAUSE IT WOULD NEVER OCCUR TO THEM THAT ANYONE WOULD MAKE SUCH A THING TODAY, AS IT SERVES NO PURPOSE OTHER THAN TO DECORATE (LIKE EARRINGS!) UNLIKE SIGNS MADE 75 YEARS AGO, WHICH WERE MADE TO ADVERTISE A PRODUCT...SOMEONE WHO SELLS YOUR SIGNS IS TAKING ADVANTAGE OF THAT PERSON...EITHER NOW, OR DOWN THE ROAD, WHEN THAT SIGN IS SOLD AND RESOLD...
...NOW HOPEFULLY YOU UNDERSTAND...YOU CAN CHANGE YOUR METHODS OR GO ON WITH THE KNOWLEDGE OF WHAT YOU ARE DOING...
...I SUPPOSE YOU GOT TIRED OF TRYING TO MAKE A BUCK OFF OF ORIGINAL ITEMS, AS IT'S HARDER TO SUPPLY THAT DEMAND, AND SAW THIS AS A LOT EASIER...
Mikemas #233305 Sun Feb 13 2011 11:38 AM
Mikemas Offline OP
I'm confused why on a sign that is not a reproduction of any sign in existence would be moved to this forum . . .
The post was put up as general information for the forum members only.
Mikemas #233306 Sun Feb 13 2011 11:41 AM
W
W
I guess you do not want to respond to my question/ Your question is simple date it on the flange and it is over other than that it is a un marked repo re issue repo fantasy they are all the same.
I am really suprized this post is still up?
Also I sure did like the number of post showing!! It gave me a little better idea on who's thoughts I was reading
Mikemas #233308 Sun Feb 13 2011 11:42 AM
Mikemas Offline OP
I just ask that you guys play fair . . . I found numerous items in the general discussion forums that were not original and not dated yet they don't appear on this forum why is that?
Mikemas #233309 Sun Feb 13 2011 11:42 AM
Okay Mike:
Read this r e a l slow and maybe you can understand.
In twenty years when this sign has hung in the weather and aged - a new collector won't be able to tell if this is an original piece produced by Mobil or something produced by an unscrupulous sign-maker.
Was that clear enough for you?
BTW - are these authorized by Mobil Corporation?
Page 1 of 3 1 2 3
Support the expenses of Oldgas.com. Thanks!
Copyright © 2024 Primarily Petroliana Interactive, All Rights Reserved
