Rotating Globe #243941
Mon Mar 28 2011 07:46 PM
Destin, Fl
Miken Offline OP
Miken  Offline OP
Destin, Fl
I would like to get a wall sconce for one of my gas globes, but I'd like to come up with a way to make it rotate since I have two different lenses on it. I'm thinking Standard had something like this for one of their pumps. Any ideas how I can make this happen.
Re: Rotating Globe [Re: Miken] #243944
Mon Mar 28 2011 08:01 PM
Devils Lake, ND---USA
K W FRITH Offline
K W FRITH  Offline
Standard had a rotator for their crown globes but it was with a 7 inch base. They're fairly rare but do come up every so often. Problem is how to reduce it to a 6 inch globe holder. If you're talented, you could probably fabricate something!
Re: Rotating Globe [Re: K W FRITH] #243948
Mon Mar 28 2011 08:11 PM
Destin, Fl
Miken Offline OP
Miken  Offline OP
Destin, Fl
I have ideas to make sure it doesn't fall off the wall. I'm just trying to think of what already rotates and take the parts out of it. I'd like to make it turn very slow like the rotating pub lights do. Kinda thought someone else might have had the same idea and found a way to make it work.
Re: Rotating Globe [Re: Miken] #243957
Mon Mar 28 2011 08:39 PM
Santa Paula, Calif
Dick Bennett Offline
Santa Paula, Calif
The Rotator made for the Crowns will NOT work for regular globes as the motor is too far offset from center. Someone has made a Rotator for 6"base globes. Not sure if it will work on Capco's through.
Mobil-100 posted a pic of a narrow 60 [in Gilmore] last week w/ a Rotator.
Re: Rotating Globe [Re: Dick Bennett] #243963
Mon Mar 28 2011 09:02 PM
Santa Paula, Calif
Santa Paula, Calif
Plug should be down thru center, other wires are for switch.
Re: Rotating Globe [Re: Dick Bennett] #243966
Mon Mar 28 2011 09:23 PM
Destin, Fl
Miken Offline OP
Miken  Offline OP
Destin, Fl
I plan to use a glass body globe. These pics will help me come up with something. Thanks
Re: Rotating Globe [Re: Miken] #243967
Mon Mar 28 2011 09:28 PM
Santa Paula, Calif
Santa Paula, Calif
IF you mounted the motor below [inside pump top], should work on ANY globe
Re: Rotating Globe [Re: Dick Bennett] #243968
Mon Mar 28 2011 09:38 PM
Destin, Fl
Miken Offline OP
Miken  Offline OP
Destin, Fl
Well what im doing is putting the globe on a wall sconce that will mounted on the wall. I thought it would be cool if I could come up with a way for it to rotate.
Re: Rotating Globe [Re: Miken] #243969
Mon Mar 28 2011 09:48 PM
Santa Paula, Calif
Santa Paula, Calif
Maybe add a Final [ball] under neath to hide motor & balance out? Spin the ball in opposite direction?
Re: Rotating Globe [Re: Dick Bennett] #243971
Mon Mar 28 2011 10:08 PM
Destin, Fl
Miken Offline OP
Miken  Offline OP
Destin, Fl
It may take some time but I will find a way to do it. I just think this would be something cool that others on here would want to do as well.
Re: Rotating Globe [Re: Miken] #243972
Mon Mar 28 2011 10:11 PM
Santa Paula, Calif
Santa Paula, Calif
With the use of a Micro motor, anything is possible.
Re: Rotating Globe [Re: Dick Bennett] #243974
Mon Mar 28 2011 10:17 PM
Destin, Fl
Miken Offline OP
Miken  Offline OP
Destin, Fl
I have some stuff on order so when it gets here ill be taking it apart to see what I can come up with. I'll have to go to Radio shack and see about the micro motor.
Re: Rotating Globe [Re: Miken] #243977
Mon Mar 28 2011 10:24 PM
Destin, Fl
Miken Offline OP
Miken  Offline OP
Destin, Fl
In the mean time I found this if someone just wants to put the globe on the shelf and have it rotate. ebay 260749268301
Re: Rotating Globe [Re: Miken] #243983
Mon Mar 28 2011 11:33 PM
Gualala, CA
Scott Baselt Offline
Gualala, CA
You could buy this and adapt it to your purpose.... http://www.gaspumpheaven.com/shop/product.php?productid=16700&cat=367&page=2
Re: Rotating Globe [Re: Scott Baselt] #243988
Tue Mar 29 2011 04:16 AM
Saline, Mi USA
blacktee Offline
blacktee  Offline
Saline, Mi USA
Sent you a PM this morning.
Doug
Re: Rotating Globe [Re: Miken] #243992
Tue Mar 29 2011 04:47 AM
Central , MN USA
SuperAmerica Man Offline
Central , MN USA
Just have to search the site, alot of ideas on how to do it.
http://www.oldgas.com/forum/ubbthreads.php?ubb=showflat&Number=127056#Post127056
Wanted
*SuperAmerica SA, Holiday or Erickson
*Loxtercamp, Greenwald Service, Greenwald Standard Oil.
*Grey Crown Globe, Standard Oil Signs, Posters
Re: Rotating Globe [Re: SuperAmerica Man] #244025
Tue Mar 29 2011 07:20 AM
Riley, MI, USA
T-way Offline
T-way  Offline
Riley, MI, USA
No one has mentioned this yet, so I'm gonna. LOL
I don't think the sconces available from the major restoration houses have enough distance from the wall to the 'cup' for the globe to rotate. I do beleive you will hit the wall first.
This one from Vic's 66 MAY work: http://www.vics66.com/store/gas-pumps/ga...num-wall-sconce
But I would not plan on using a glass body. That's an awful lot of weight hanging way off the wall by two mounting screws. Toss in the vibration of the motor and (to me) that's a receipe for disaster.
You will shave at least 6# of weight by using a CAPCO body.
Re: Rotating Globe [Re: T-way] #244030
Tue Mar 29 2011 07:47 AM
Destin, Fl
Miken Offline OP
Miken  Offline OP
Destin, Fl
Scott
I never saw that. I'll have to get one of those.
T-Way
Thats the sconce im going to use. To make it sturdy I was going to attach a back plate so it would have more screws in the wall. I did think about a Capco body to save on weight, but I dont think it has the same appeal as a glass body one.
Re: Rotating Globe [Re: Miken] #244215
Tue Mar 29 2011 09:30 PM
Destin, Fl
Miken Offline OP
Miken  Offline OP
Destin, Fl
This is what i've come up with. Going to cut off the base were the globe mounts to the wall sconce and then tack weld the rotating globe base on it that gas pump heaven sells.
Re: Rotating Globe [Re: Miken] #244399
Wed Mar 30 2011 07:23 PM
K W FRITH Offline
K W FRITH  Offline
Keep us posted as to how it works out!
Re: Rotating Globe [Re: Dick Bennett] #244486
Thu Mar 31 2011 07:16 AM
Wisconsin
Mr.Wadhams Offline
Mr.Wadhams  Offline
Wisconsin
Just a note on this Standard Oil rotator posted by Dick. The rotating wheel is in the wrong spot...it actually should be running on the OUTSIDE of the inner circle, not the inside like this one shows. Plug had an adapter to screw into the light socket that illuminated the globe. Small ball bearings run under the outer circle ....like a lazy susan.
Re: Rotating Globe [Re: Mr.Wadhams] #244489
Thu Mar 31 2011 07:37 AM
Duluth, MN U.S.A
Ryan Underthun Offline
Duluth, MN U.S.A
Yeah, but if you put the wheel on the inside, the globe spins way faster! LOL
visit my website for original gas pumps and parts
www.thepumpdump.com
Re: Rotating Globe [Re: Ryan Underthun] #244495
Thu Mar 31 2011 07:54 AM
Santa Paula, Calif
Santa Paula, Calif
Quickie picture.
I keep it in a box in shed so it don't matter!
Re: Rotating Globe [Re: Dick Bennett] #244525
Thu Mar 31 2011 11:55 AM
Wisconsin
Mr.Wadhams Offline
Mr.Wadhams  Offline
Wisconsin
I just thought that little trivia might help if someone wanted to copy it...it would not work the way it is. Never know...more info might help someone?
Page Time: 0.030s Queries: 16 (0.005s) Memory: 1.9661 MB (Peak: 2.1599 MB) Zlib disabled. Server Time: 2018-04-22 16:30:34 UTC
