Re: My first gas pump restoration- glad it's done [Re: wangdango] #248229
Sun Apr 17 2011 07:52 AM
Oneida IL USA
gasoildude Offline
gasoildude  Offline
Oneida IL USA
Those look great. Very nicely done smile
Brad Ralston & my website is
www.petrobarn.com
Re: My first gas pump restoration- glad it's done [Re: gasoildude] #248231
Sun Apr 17 2011 07:59 AM
Evansville, In
Jarvis Offline
Jarvis  Offline
Evansville, In
Where did you get the rubber that goes around the outlet hose?
Pump looks great!!!! Glad to see you used original globe and signs!
Re: My first gas pump restoration- glad it's done [Re: wangdango] #248334
Sun Apr 17 2011 04:49 PM
West Michigan
jackofalltrades Offline OP
West Michigan
I believe the silver rod you mentioned is the push/pull switch for the light manifold. www.thepumpdump.com might have a door. Hope this helps.
Re: My first gas pump restoration- glad it's done [Re: jackofalltrades] #248338
Sun Apr 17 2011 04:50 PM
West Michigan
West Michigan
Jarvis, the rubber around the outlet hose is the original. It is torn a little, but I still used it because I could not find a replacement.
Re: My first gas pump restoration- glad it's done [Re: jackofalltrades] #248499
Mon Apr 18 2011 07:39 AM
Kearney, NE
DasFast1 Offline
DasFast1  Offline
Kearney, NE
Gas Pump Heaven or any place that has window rubber for 1/8 inch glass/ad glass. It is the same as the trim around the hose outlet.
http://www.gaspumpheaven.com/shop/product.php?productid=16727&cat=363&page=1
Re: My first gas pump restoration- glad it's done [Re: DasFast1] #248517
Mon Apr 18 2011 09:31 AM
U.S.A.
strnge Offline
strnge  Offline
U.S.A.
Great pump restoration!
Re: My first gas pump restoration- glad it's done [Re: wangdango] #249037
Tue Apr 19 2011 09:44 PM
Montana
hotrodfun1 Offline
hotrodfun1  Offline
Montana
SUPER JOB VERY VERY WELL DONE THANKS FOR SHARING.KEEP UP THE GOOD WORK
Re: My first gas pump restoration- glad it's done [Re: hotrodfun1] #249074
Wed Apr 20 2011 05:53 AM
garrison ny
W
wangdango Offline
wangdango  Offline
W
garrison ny
Turned out great! How did you make the sight glass look like it was filled w/gas? It has a gold glow..... Do you know what year your 766 is?
Re: My first gas pump restoration- glad it's done [Re: wangdango] #251709
Sun May 01 2011 05:43 AM
West Michigan
West Michigan
Thank you. I cleaned the sight glass, but it still had a slight yellow tint to it perhaps from the gas staining it over the years it was in use. The inside bulb then gives it a gold glow. This pump was born in April 1954.
Page Time: 0.019s Queries: 14 (0.004s) Memory: 1.8832 MB (Peak: 1.9964 MB) Zlib disabled. Server Time: 2018-02-24 04:30:26 UTC
