Mobil /Fort Richie Sign #248570
Mon Apr 18 2011 02:26 PM
TEXAS
DIESEL Offline OP
DIESEL  Offline OP
TEXAS
pretty cool find i thought i would share,wow its a pain to get the paint off ,but rewarding! the frame is porcelain up top "blue porcelain" i thought that was different! i will post a pic when finished ,but at this rate, it will probably bee a few weeks!
CHRIS
Re: Mobil /Fort Richie Sign [Re: DIESEL] #248572
Mon Apr 18 2011 02:36 PM
Ottawa Ontario, Canada
1970mach Offline
1970mach  Offline
Is the sign porcelain as well? if not how are you removing the paint Chris?
Colin Latreille
Always looking for Quality Canadian Oil & Gas & Ford Signs
Re: Mobil /Fort Richie Sign [Re: 1970mach] #248581
Mon Apr 18 2011 02:56 PM
DFW Texas USA
marxmobilgas Offline
DFW Texas USA
Chris
Citristrip worked well for my coke sign with house paint on it.
pleasant smell, apply and wait for it to fall off
Re: Mobil /Fort Richie Sign [Re: marxmobilgas] #248586
Mon Apr 18 2011 03:21 PM
TEXAS
DIESEL Offline OP
DIESEL  Offline OP
TEXAS
Yea Colin the sign is DSP porcelain & the whole frame is porcelain too,i have never seen that before-
mark i will have to try that,i went & bought paint thinner & have used a razor blade ,but its some work,hopefully that will be a easier way "using citristrip" i was also thinking about using a paint stripper "wipe on/wipe off action"
CHRIS
Re: Mobil /Fort Richie Sign [Re: DIESEL] #248627
Mon Apr 18 2011 05:11 PM
PECONIC BAY, L.I., NY, USA
THE AMERICAN GARAGE Offline
Great Results from using "Citri-strip!"
BEFORE:
AFTER:
Took less than an hour to clean 'er up! smile
Re: Mobil /Fort Richie Sign [Re: THE AMERICAN GARAGE] #248674
Mon Apr 18 2011 06:44 PM
Santa Paula, Calif
Dick Bennett Offline
Santa Paula, Calif
POUR the paint stripper on & move around w/ a brush. Keep out of direct sun as it will flash off before lifting paint, better yet pour on in evening & let sit overnight.
Re: Mobil /Fort Richie Sign [Re: Dick Bennett] #248682
Mon Apr 18 2011 06:59 PM
1970mach Offline
1970mach  Offline
I agree with DB. I thought maybe the sign was painted. If both are porcelain it will not take too long with paint stripper. You can be done in an hour!
Colin Latreille
Re: Mobil /Fort Richie Sign [Re: 1970mach] #248685
Mon Apr 18 2011 07:06 PM
Paint thinner isn't going to do too much. It's Lacquer thinner you want and can use on Porcelain. With Citri-strip, You spray it on and let it sit for 30-40 minutes and then wipe it off with rags and use a razor blade for the tough spots. Use the lacquer thinner to clean the sign off from the stripper residue. I wipe it down twice.
Re: Mobil /Fort Richie Sign [Re: THE AMERICAN GARAGE] #248702
Mon Apr 18 2011 07:28 PM
Osage County Oklahoma
moore798 Offline
moore798  Offline
WHERE CAN THIS CITRI-STRIP BE FOUND.I AM UNFAMILIAR.LACQUER THINNER AND RAZOR BLADE HAS ALWAYS WORKED PRETTY WELL FOR ME.
Robert
Re: Mobil /Fort Richie Sign [Re: moore798] #248713
Mon Apr 18 2011 07:38 PM
Santa Paula, Calif
Santa Paula, Calif
In the last 10+ years most house paints are Vinyl Base, Paint Thinner is a waste of time & Lacquer Thinner will flash off too soon to be of any good
Re: Mobil /Fort Richie Sign [Re: Dick Bennett] #248772
Tue Apr 19 2011 03:35 AM
Mass
KZ1000 Offline
KZ1000  Offline
Mass
Easy Off oven cleaner will work too, spray it on, wait 10-20 minutes, hose it off or wipe with steel mool
Re: Mobil /Fort Richie Sign [Re: KZ1000] #248785
Tue Apr 19 2011 05:11 AM
HOME DEPOT AND LOWE'S SHOULD HAVE THE "CITRI-STRIP." ABOUT $8-9 A CAN.
*It's aerosol BTW....not brush on!
Re: Mobil /Fort Richie Sign [Re: THE AMERICAN GARAGE] #248815
Tue Apr 19 2011 07:23 AM
West Michigan
jackofalltrades Offline
West Michigan
Doc, that Coke sign is awesome. A nice find for sure.
Re: Mobil /Fort Richie Sign [Re: THE AMERICAN GARAGE] #248833
Tue Apr 19 2011 09:26 AM
Clay Center, KS
BIGTOM Offline
BIGTOM  Offline
Clay Center, KS
BEFORE:
AFTER:
UNBELIEVEABLE!!! Even more incredible - that someone would do that to a sign like that. I guess it pretty much preserved the Coke artwork. GREAT results!!! The best thing about Citrus Strip is that it doesn't burn your hands, and the smell is great!!!
Re: Mobil /Fort Richie Sign [Re: DIESEL] #248848
Tue Apr 19 2011 10:27 AM
TEXAS
DIESEL Offline OP
DIESEL  Offline OP
TEXAS
Heres 1 side ,looks as if sign was used as target practice lol! "WHO CAN HIT THE HORSEY", the other side looks alot nicer ,i will post a pic when completely finished! the stripper worked wonders & thanks again!
CHRIS
Page Time: 0.028s Queries: 16 (0.007s) Memory: 1.9212 MB (Peak: 2.0764 MB) Zlib disabled. Server Time: 2019-01-20 20:18:31 UTC
