Page 2 of 3 1 2 3
Re: Mohawk tires sign is on the ground. woo hoo [Re: THE AMERICAN GARAGE] #249732
Fri Apr 22 2011 01:25 PM
Pa.
always lookin Offline OP
Pa.
The bulbs look like this and the one end is spring loaded so you push the bulb toward one side so it pops out.... info ???
Re: Mohawk tires sign is on the ground. woo hoo [Re: always lookin] #249740
Fri Apr 22 2011 02:08 PM
Longview, WA
Bob Richards Offline
Longview, WA
T-12 lamp. Still available at Lowes, Home Depot for a while yet. The ballasts on the lamp will be noisy but that is okay.
Re: Mohawk tires sign is on the ground. woo hoo [Re: Bob Richards] #249745
Fri Apr 22 2011 02:17 PM
Pa.
Pa.
I called my electrical buddy. He said put a cord on it and plug it in, I just did, no noise no nothing...
Re: Mohawk tires sign is on the ground. woo hoo [Re: always lookin] #249746
Fri Apr 22 2011 02:20 PM
Pa.
Pa.
I took the panel of the ballast s sssss and the wiring looks good, but no noise from them at all.
Re: Mohawk tires sign is on the ground. woo hoo [Re: always lookin] #249756
Fri Apr 22 2011 02:33 PM
PECONIC BAY, L.I., NY, USA
THE AMERICAN GARAGE Offline
Hmmmm to me the bulbs look shorter than 4' which means 2 pins on each end. 5, 6 and 8' bulbs have single pins. Didn't think they would be that long. Do the bulbs have a Brand and ordering code on them at one end on the glass? That would tell you what size you need to get as replacements.
Also check the wiring to the ballasts if you can. How long did you leave it plugged in? Did any bulbs light up? or attempt to?
Re: Mohawk tires sign is on the ground. woo hoo [Re: THE AMERICAN GARAGE] #249759
Fri Apr 22 2011 02:42 PM
clio, michigan usa
r49th Offline
r49th  Offline
clio, michigan usa
You'll need to go to a commercial electrical supply for sign ballasts. (or a sign supply place) Take what you have or write the numbers for correct replacements. Looks like there may three. Replace the lamps while your at it. If these are the originals they are probably junk. Are any leaking tar? That is a sure sign of a bad ballast.
ROD [Mich.]
Re: Mohawk tires sign is on the ground. woo hoo [Re: r49th] #249766
Fri Apr 22 2011 03:08 PM
Pa.
Pa.
NO tar, no cracks in wires, 4 ballastsss, bulbs are 42 inch and smaller, all single pin, I left it in for 5 minutes, no flicker, no noise no nuttin.
Re: Mohawk tires sign is on the ground. woo hoo [Re: always lookin] #249767
Fri Apr 22 2011 03:11 PM
Are you sure your wall outlet or extension cord are both good? LOL!
stranger things have happened! smile
Re: Mohawk tires sign is on the ground. woo hoo [Re: THE AMERICAN GARAGE] #249768
Fri Apr 22 2011 03:13 PM
Pa.
Pa.
yep, tested both
Re: Mohawk tires sign is on the ground. woo hoo [Re: always lookin] #249794
Fri Apr 22 2011 04:54 PM
Sunbury, PA, USA
lordparaffin Offline
Sunbury, PA, USA
C'mon, stay with it! I've been waitin' to see that puppy lit up!! That's one sweet piece and I'll bet looks kick'butt cool in a dark room.
........Dave
Re: Mohawk tires sign is on the ground. woo hoo [Re: lordparaffin] #249795
Fri Apr 22 2011 04:58 PM
Waterville,Ohio
Hy-Flash 72 Offline
Hy-Flash 72  Offline
Waterville,Ohio
This might sound dumb..Does it have any type of fuses???
Randy
Re: Mohawk tires sign is on the ground. woo hoo [Re: Hy-Flash 72] #249802
Fri Apr 22 2011 05:17 PM
Minot,ND USA
porcelain-neon Offline
Minot,ND USA
I have several lighted signs and have never had any luck plugging them in and having them work. I don't think too many shop owners spent any money on maintaining them. Anymore the first thing I do is replace the bulbs and ballasts, if you go that route, replace with t8 stuff, uses less power and is still readily available.
Still looking for that Union 76 ball
And I collect big old porcelain neon signs
Re: Mohawk tires sign is on the ground. woo hoo [Re: porcelain-neon] #249815
Fri Apr 22 2011 05:46 PM
Lynn, NC USA
grabber Offline
grabber  Offline
Lynn, NC USA
Killer sign!!!
Wanted: Husky Cans/Signs, Interesting Pump Plates and NC Road Signage
Website www.petrojoe.com
Re: Mohawk tires sign is on the ground. woo hoo [Re: GILMORE] #249817
Fri Apr 22 2011 05:48 PM
West Lafayette, Ohio
TerryL Offline
TerryL  Offline
Don't get much better than that. What a sweet sign
Re: Mohawk tires sign is on the ground. woo hoo [Re: TerryL] #249819
Fri Apr 22 2011 05:59 PM
Pa.
Pa.
The kid that works at the electric/lighting shop, where I take all my signs and clocks, said he would come out and fix it. I think I will have him come out. I think it will add value if its working !!
Page 2 of 3 1 2 3
Page Time: 0.032s Queries: 15 (0.007s) Memory: 1.9193 MB (Peak: 2.0714 MB) Zlib disabled. Server Time: 2018-10-20 09:27:27 UTC
