#253024
Sat May 07 2011 12:17 PM
Posts: 1,979 Likes: 1
Posts: 1,979 Likes: 1 |
i plucked this porcelain thermometer from ebay about 2 weeks ago. the seller advertised it as having a curve to it. so i am not dissapointed. anyway, has anyone ever had any luck taking a warped sign and making it straight again. the face of the thermometer is mint and i am afraid to screw it tight to the wall as the porcelain may chip away. i thought about putting it in the oven on high with some pressure on the sign??? think this might work??
TBA Feature Host
TBA Feature Host
Posts: 2,357 |
I have some signs with curves. I would think if I tried to bend it the porcelain may crack or chip. I would be interested if anyone has a successful method without causing any damage.
Posts: 369 |
The mobilgas shield i had was warped horribly. So we put it across the opening of our basement door and stepped on it and it straightened out perfect with no chips. I don't recommend doing that to this thermometer though lol
Posts: 517 |
What you could do is heat it up in the oven and then clamp it to flat surface and then put it back into the oven for awhile and then take it out and let it cool in still air before unclamping.
Might work?
Randy
I understand that the metal and porcelain win expand and contract at different rates and a household oven will not provide the temps nessacary to melt the metal or porcelain. I talked to restoration guy a couple years ago about some techniques. He told me he used a bottle jack and a 4x4 piece of wood jammed under a beam in his garage. He said it would take a month, just a little bit at a time?? I am worried about the cookie cutter edge on the thermometer!
Posts: 629 |
are there holes around it so you can screw it to a piece of plywood? I have taken a sled sign and gradually screwed it to a piece of wood a little at a time until straight.
I should think flexing any thermometer in an opposite direction to fix the bend would break the glass tube. Same with putting it in an oven...they are fragile and I wouldn't recommend it.
Posts: 126 Likes: 2
Posts: 126 Likes: 2 |
please remember the metal is streached if u want to unbend u should releave by cutting edge by cracks with saw saw mybe die grinder it may flaten out without u bending it is this high dallor piece?
Posts: 145 |
I would put the thermometer on the wall (or board), hold/press on it in the middle to let it have the banana shape - then sink screws in the holes but only to the point of contact with the thermometer (don't screw the thermometer flush at either end). Looks like you would be about an inch or less from flush on each end. Gradually, equally tighten the screws over time maybe a turn or two ever other day. I would put a stack of wide fiber or leather washers under a wide steel washer at each screw in order to prevent stress chips at the holes. I would remove the glass thermometer from the body before doing anything - most seem to come out via tiny wires or clips, or are set in a wood block that is glued, screwed or wired to the tin.
Good luck.
Posts: 1,262 Likes: 1
Posts: 1,262 Likes: 1 |
_________________________ I might be stepping on my *&*& here, but I'm going to say it anyhow. If members here continue to snip at each other and acknowledge what one person might feel is a slam with a slam right back and/or chastise and correct other adults, then this forum will eventually go straight to hell. I may be one of the least active and vocal members here, but I do NOT want to see this happen. I thoroughly enjoy my few minutes each day I spend here. And that's all I'm saying about the subject.
Last edited by Oldgas; Sun May 08 2011 07:27 PM. Reason: Use the "Notify" button to report a troublesome post
Posts: 1,187 |
I would, take therm tube out, take 2 2x6s, lay one on the floor and lay therm on it, lay a rag on therm face, lay other 2 x 6 on top of therm, put a screw in top and bottom, from top board to bottom board, tighten a tad more every day. Sounds like it should work.
Posts: 629 |
Posts: 2,242 |
Since metal and porcelain do not "creep" like plastic or rubber, I don't se a benefit to doing this slowly over multiple days. Also, heating it in the oven will not help much, as the benefit you're looking for would only come from heating above the recrystalization temperature of the steel, which it's unlikely your oven can achieve. The only way I know of to straighten the sign is to bend it further than flat, causing yielding, and then let it spring back to (near) flat. Because that involves bending it further than just flat, it might be safer to just screw it to the wall or mount it to a frame to hold it flat.
Posts: 436 |
When I tried to flatten a warp all it did was chip the sign, sometimes better to leave it as is or risk losing more porcelain especially if the porcelain is all there with no chips it would ruin a great sign.
Posts: 649 |
You didn't give measurements,but it looks like 6"-8" X 36"??The warp looks like about 1"-2"??That is not a flat sign from what I can see.I wouldn't try it.
I'm with Thermactor on the idea of mounting it to a frame,but I would go a little further.You might build a "shadow box"frame for it that would hide the warp when looking at it from the side and mount it as.I do a lot with wood framing around my place and it has worked for me.I've never "shadow boxed"a thermometer before,but I think it would Work.Good luck.
Posts: 950 |
Wes is right on this. I've worked with a lot of metal over the years and heat is tricky thing to manipulate on metal and could have an even worse effect than what you current;y have. A reverse bend carefully done over the length is the best solution although as evidenced by the chipping along the edges from the first bend, you most likely can expect more chipping. The biggest problem with this type of bend is it isn't a flat piece of metal but a shaped piece with dimension or depth. When the metal was bent the first time, the back edge (where the porcelain chipped the most) is where the metal actually stretched and this is where it is at it's worst. Trying to straighten it would require shrinking the metal back to original length which isn't going to happen. Instead, there will be deflecting of the metal to accomodate the flattening and most likely it will be in the form of some kind of edge wave or bulging of the sides. I guess it comes down to, can you live with the bend, or how much more damage can I accept. Wish I had better advice.
I have come to the realization that I don't have much spare time anymore to fiddle around with anything. Thanks for everyones input. I just screwed it to the wall using some plastic washers at the holes. It snugged down 99% flat and only one chip came off at the top of the tube between the words "liver" and "ills". Thanks again everyone
Posts: 950 |
Looks like a perfect solution!
Posts: 1,550 |
It looks great. Unfortunately, I have that type of personality that would cause me to look at it and decide to give the screw one more turn every time I looked at it. By the time I am done, it would be totally straight, but the porcelain would be all chipped. John
