Natinal A-B 38 enigma.....anyone know this? #29542
Sat Nov 24 2007 08:45 AM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
I am designing a frame for a clock to fit into an A-38.
The computer is 12" long.
The clock body is 12 3/4" long.w/o hand shaft
The specs on the faces are the same.
So how is a unit 3/4 " longer than the computer, with the same dimension faces, fitting into the same cabinet????????????
I have decided to make the unit 12" long just for the fact that I know a 12" computer will fit.
Gator......???? anyone?????
Veeder Root Identification CD
Gas Pump Clock Repair
jkyocom@bellsouth.net
Re: Natinal A-B 38 enigma.....anyone know this? #29543
Sat Nov 24 2007 11:14 AM
On the plains of Colorado
Thunder II Offline
Thunder II  Offline
Define your dimensions. What exactly do you mean by "long"?
Anything Chevron
[Linked Image]
I'd rather be flying.....
Re: Natinal A-B 38 enigma.....anyone know this? #29544
Sat Nov 24 2007 02:31 PM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
Long = end to end, as in length.
A standard computer is 12' long , end to end ,inside face to inside face.A small computer is 8" end to end.
Re: Natinal A-B 38 enigma.....anyone know this? #29545
Sat Nov 24 2007 03:18 PM
Thunder II Offline
Thunder II  Offline
Simple..... Wasn't the clock face mechanism a pump manufacturers part, and the VR computer a universal component? The face plates on the clock face pump, don't dish as much as the computer pump. Obviously, they didn't need to. Extend the length of the clock face shafts....
Anything Chevron
[Linked Image]
Re: Natinal A-B 38 enigma.....anyone know this? #29546
Sat Nov 24 2007 03:56 PM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
As I stated, Specs on faceplates are the same.
Actually more room is needed for hands, they protrude from face....computer wheels are behind the face.
That would mean the faces would need to be inset, and deeper, by logic anyway....less than or equal to the length of a computer.
The Bennett 77 is shorter than a computer
If the hand shaft is too long it will hit the glass
[This message has been edited by jkyocom (edited 11-24-2007).]
Re: Natinal A-B 38 enigma.....anyone know this? #29547
Sat Nov 24 2007 04:15 PM
Thunder II Offline
Thunder II  Offline
Hence my request that you define your dimensions! Its funny how you try to bring logic into one of your discussions.
Anything Chevron
[Linked Image]
Re: Natinal A-B 38 enigma.....anyone know this? #29548
Sat Nov 24 2007 04:18 PM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
Re: Natinal A-B 38 enigma.....anyone know this? #29549
Sat Nov 24 2007 04:22 PM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
And so far you have not been able to answer my question, mearly digging at my request.
Do you know anything about or have you ever owned a B-38???? Or are you just harrasing me
Re: Natinal A-B 38 enigma.....anyone know this? #29550
Sat Nov 24 2007 04:30 PM
Thunder II Offline
Thunder II  Offline
Simple.... Look at the relief of the faceplates. If you are trying to make a VR computer, at 12 inches, work in the place of a clock mechanism, at 12 3/4 inches,(which by the way you dont have) then you need to change something by 3/8 of an inch on each side! Simple. Reduce the dimension of the relief, on the faceplate.... So helping you is now harassing you? Have a nice day!
Anything Chevron
[Linked Image]
Re: Natinal A-B 38 enigma.....anyone know this? #29551
Sat Nov 24 2007 04:49 PM
Santa Paula, Calif
Dick Bennett Offline
Santa Paula, Calif
Are you trying to use a VR frame to hold the new clock mech. ?
Re: Natinal A-B 38 enigma.....anyone know this? #29552
Sat Nov 24 2007 05:25 PM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
This is the frame I designed and is similar to the 77 I made. It will mount similar to the way a B-38 clock mounts, since the original clock reset shaft comes out at a different place than the computer, I designed a gear train to drive/reset the unit to be able to utilize the computer reset hole, in case the pump had aready been restored.
I realize there is a weird offset to the original hands..that tucks the hand collars almost inside the face.But Ron's face do not allow that to be done, and actually is easier this way .does the 12 3/4" length of the original clock put the hands right up next to the glass???
leaving maybe 1/4" between face and glass?
I made this frame 12" so it should fit , right???It has been years since I have had an A-38
Re: Natinal A-B 38 enigma.....anyone know this? #29553
Sat Nov 24 2007 05:36 PM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
Here it is finished with faces on.
There is 1/4 " from the outer face of the outer hand to the outer edge of the face.
Think it will fit without hitting any glass????
Re: Natinal A-B 38 enigma.....anyone know this? #29554
Sat Nov 24 2007 08:37 PM
New Berlin,WI USA
Petroholic Offline
Petroholic  Offline
New Berlin,WI USA
Man you must have had a erector set as a kid.LOL That is some nice work you have done there,I can't imagine the time that goes into all of that.I can't help with your problem,but wanted to say thats some nice craftmanship.
Joe
Re: Natinal A-B 38 enigma.....anyone know this? #29555
Sun Nov 25 2007 07:33 AM
montrose mi
dice. Offline
dice.  Offline
montrose mi
how are they?
Re: Natinal A-B 38 enigma.....anyone know this? #29556
Sun Nov 25 2007 07:45 AM
GA
jkyocom Offline OP
jkyocom  Offline OP
GA
Thanks.....just like the computers, I have more time in them than anything else.
Yes ...I had a hand me down Erector set that was my brothers.....I used to take my mechanical toys apart to see how they worked.
Telephones , calculators, appliances,
I got my a** tore up several times by DAD for doing stuff like that!!!!!
I like a challenge....each new clock is another challenge.
For instance , the faces on the national are set up at 5 gallons per 1 revolution of the outer hand.... I had to design a pentagonal bell trip cam......to get the bell to ring 5 times per revolution.
Neccessity....what a MOTHER!!!!!!
Page Time: 0.028s Queries: 13 (0.008s) Memory: 1.9192 MB (Peak: 2.0670 MB) Zlib disabled. Server Time: 2018-07-19 10:03:53 UTC
