#299205
Sun Jan 22 2012 05:41 PM
Posts: 1,452 |
What's the best way to remove a stuck cylinder. I know there was a thread a couple weeks ago but after 30 minutes of searching I give up. I know it was recommend to use a chemical but I just cant remember what. I must be using the wrong key words for the search. Thanks, Lee
Wd40 ,let soak,use thin strong screwdriver around edge,very carefully!soak again.patience works!
Posts: 1,627 |
DB?? NO WONDER YOU HAVE NO EXTRA CYLINDERS ??LOL
I think I have heard brake cleaner also.
Large clean Container,
Bigger Hammer is for Crushing Ice, Fresh Orange Juice is for Mixing w/ Favorite Liquor, Ya have to have something enjoyable to do while the Brake Cleaner/Fluid is DOING IT'S JOB!
Posts: 4,006 Likes: 7
Posts: 4,006 Likes: 7 |
I have used brake fluid with success. Soak for a day, then pick, soak another day and keep repeating til you get it loose.
Since I have never been there, what is the cylinder "STUCK" to?
Posts: 1,452 |
THANKS GUY'S I APPRECIATE IT.
DB I'M OUT OF FRESH OJ, I LIKE IT FRESH SQUEEZED.
DOC, THE GLASS IS FROZEN TO THE PUMP AT THE BOTTOM WHERE THEY SEAL THE CYLINDER.
The original, pasty, fibre type caulking that seals the cylinder. Pretty tuff stuff, even when its all dried out!
Posts: 4,962 Likes: 17
Posts: 4,962 Likes: 17 |
The best thing I have used is oven cleaner.
Removing old caulk takes time and tenacity. You have to pick at the stuff with the thoroughness of a tooth-cleaning dental hygienist. You need a putty knife, a razor-blade utility knife, a flat-blade screwdriver, maybe even some of those same dental tools used by the hygienist.
Posts: 1,705 |
And you are not guaranteed success after you get it off. Those cylinders have been under stress for many years. You relieve that stress and you MAY hear a disheartening sound that you will never forget. You don't really have a choice though.Like you have been told...go slow and just be careful. Temperature change can be a factor also. How many of the readers here have heard that sound...like a metallic "tink"! I have heard it twice. Dave
Posts: 1,705 |
Spoken like a "veteran". Dave
