#317757
Sun Apr 08 2012 06:50 PM
Posts: 17 |
Stuart here from sunny South Australia. I need parts for my wayne roman 492 petrol pump. i need original(the valves & levers that bolt up under the neck)below where the glass bowl sits. Also need the three original base plates that bolt into the base.Any help or leads would be greatly appreciated.Regards Stuart
Posts: 2,313 Likes: 86
Posts: 2,313 Likes: 86 |
If you cannot find originals you can contact Ron Scobie Enterprises for nice repro base access doors (they fit nicely)made of cast iron. Rob
Posts: 17 |
yes, thanks for that, i know Ron makes the base plates and the levers but he doesnt make the valves the levers go on so i need some original valves. Someone had some on us ebay about 12 months ago(i missed them as wasnt watching that week) a friend contacted me after they had sold on ebay to tell me,i could have killed him for not letting me know when they were on there.Regards Stuart
#328408
Sat May 26 2012 04:42 PM
Posts: 17 |
Stuart here from Australia. I Still Desperately need the valves and levers that bolt up under the neck of my wayne roman 492 petrol pump. No-one makes these valves & their mountings so i need originals. Contact me on kingtut1@bigpond.com
Hope this helps in your quest for parts & how the valves work. The Ball valve handle next to Fig. 2[in drawing] is only on the 491 Air Operated pumps. Roman Patent Valves your looking for are 1 1/4" quick-shutoff.
Posts: 5,980 Likes: 24
Posts: 5,980 Likes: 24 |
Yea, that is an easy diagram to read.
Posts: 1,730 Likes: 19
Posts: 1,730 Likes: 19 |
Stuart, As we discussed on the phone this is the part that I make. Ron Uploaded with ImageShack.us
#352320
Thu Aug 30 2012 05:19 PM
Posts: 17 |
i need the fittings that bolt up underneath the glass bowl with the valves & the fill bowl lever & release lever that hide behind the scrolls on my Wayne Roman 492 petrol pump. Also need an original set of three covers that sit in the base on pump.Someone must be able to help. Contact Stuart(from sunny South Australia) here or email me on kingtut1@bigpond.com
#369108
Sat Nov 10 2012 01:24 AM
Posts: 17 |
i still need the fittings & valves that bolt up under the neck of my wayne roman 492 petrol pump. also need the levers that bolt to the valves. one with original lock.also need the three original base plates.Contact Stuart here or email me in australia at kingtut1@bigpond.com
Posts: 17 |
#413111
Mon Apr 29 2013 05:07 PM
Posts: 17 |
Stuart here from south australia. Im still looking to buy the fittings that bolt up under the neck & the valves that screw onto them & the release handles,especially the one with the lock in it for my Wayne Roman 492 petrol pump. Also need an original set of Base Doors with locks.Ive Been Trying To Get These For a few years Now & cant Finish Rebuilding My Pump Till i find Some. Please Help Me. Regards Stuart
IF some one has a picture, I might have something.
Gas Pump Heaven sells valves that will work.
Rob
#523164
Tue Mar 25 2014 03:10 AM
Posts: 17 |
Stuart Here from south Australia. I Am Still Trying to get The Fittings that bolt up under the neck of my wayne 492 roman & the valves & Levers that go on them.There are 3 Fittings,one has the Pump Hose fitting on it,one has the release valve and the other has the other valve go on it. Any Help Appreciated as i want to finish this pump but cant until i source these items.Also looking to buy a Set of 3 Original base fittings with the writing on & Locks.Contact me here.
#570875
Sat Sep 27 2014 02:55 AM
Posts: 17 |
Hi Guys, Im Still Needing the Original Fittings, Levers & The Valves That Bolt up Under The Neck Behind The Scroles On My Wayne Roman 492 Petrol Pump. Also Looking For The 3 original Base Plates for The pump as well.
#603993
Wed Mar 18 2015 03:45 AM
Posts: 17 |
Stuart Here From Australia, Three Years Ive been Trying To Find The 2 Valves,2 Levers(one with key lock) & The Fittings That Bolt Up Under The Neck(one has 3 bolt holes,one has 4) Of My Wayne Roman 492 Pump.Also Looking For The 3 Original Base Plates For The Petrol Pump. Please Help.
