Cities Service Curb Sign base warning #354933
Mon Sep 10 2012 05:36 PM
Devils Lake, ND---USA
K W FRITH Offline OP
I bought this curb sign base on ebay and the ad specifically said "no cracks, breaks or welds". Well, when I received it, the center pipe was welded in place and that wouldn't be so bad but it wasn't welded straight! I asked the seller if he would pay to fix it and he just said to send it back because there was a guy there in Missouri that wanted it!
Fine by me as he was willing to pay return freight too but I just want you Missouri guys to know what you're getting from this seller and I don't think you'll be happy! This is just a heads up so that you know what you're getting! The seller is Michael Hutchison and uses "f12packard" on ebay.
As for me, I'm on the hunt for one again!
Re: Cities Service Curb Sign base warning [Re: K W FRITH] #354938
Mon Sep 10 2012 05:49 PM
Minot,ND USA
porcelain-neon Offline
Minot,ND USA
What would be so tough about cutting the pipe out and cleaning it up with a grinder?
Still looking for that Union 76 ball
And I collect big old porcelain neon signs
Re: Cities Service Curb Sign base warning [Re: porcelain-neon] #354940
Mon Sep 10 2012 05:54 PM
I'm pretty sure the threads are probably shot and was the reason for welding it and I didn't pay for something that needed work!
Re: Cities Service Curb Sign base warning [Re: K W FRITH] #354946
Mon Sep 10 2012 06:13 PM
NY
57tbirdkid Offline
TBA Feature Host
57tbirdkid  Offline
TBA Feature Host
NY
You could always put a insert in..,come on kevin your a handy guy wink
Re: Cities Service Curb Sign base warning [Re: 57tbirdkid] #354974
Mon Sep 10 2012 07:30 PM
Santa Paula, Calif
Dick Bennett Offline
Santa Paula, Calif
Looks to me like the farmer wanted a larger pipe to hold his Vise or grinder!
Flip it over & check for threads.
& it would still be crooked & off center!
Re: Cities Service Curb Sign base warning [Re: Dick Bennett] #354984
Mon Sep 10 2012 07:49 PM
Threads don't look good underneath at all. I figure it will take a machine shop to get it right again.
Re: Cities Service Curb Sign base warning [Re: K W FRITH] #354990
Mon Sep 10 2012 08:09 PM
So. Ca.
advertologist Offline
So. Ca.
that would be a killer base detailed green & black.. cool
Re: Cities Service Curb Sign base warning [Re: advertologist] #355034
Tue Sep 11 2012 12:21 AM
Dave's Garage Offline
Kevin, I think a machine shop could mill the pipe down and then cut new threads in it.
Dave GILL,
Re: Cities Service Curb Sign base warning [Re: Dave's Garage] #355046
Tue Sep 11 2012 03:21 AM
smyrna, de USA
THERMOMAN Offline
THERMOMAN  Offline
smyrna, de USA
I just rethreaded the bung on my compressor to run 1" ridgid around my shop. (I know its overkill, the 1" is t-tapped for 3/8 drops). It can be done, not sure if final product would leave evidence of earlier problem. The internal pipe taps or bolt taps are all over the swap meets, as they are used 1000 times less than there counteparts. No one ever thinks that they will have a use for them.
Re: Cities Service Curb Sign base warning [Re: Dick Bennett] #355053
Tue Sep 11 2012 04:22 AM
NY
57tbirdkid Offline
TBA Feature Host
57tbirdkid  Offline
TBA Feature Host
NY
I meant After the pipe was cut an base was drilled out Dick. Some of the signs look wrong with a wide pole:)
Re: Cities Service Curb Sign base warning [Re: 57tbirdkid] #355056
Tue Sep 11 2012 04:55 AM
Mass
KZ1000 Offline
KZ1000  Offline
Mass
I'm with Kevin on this one, It is not what he was led to believe. It is not an easy or cheap fix if you can't do it yourself, when you have to fix something the original price should reflect that.
Re: Cities Service Curb Sign base warning [Re: KZ1000] #355152
Tue Sep 11 2012 01:41 PM
Santa Paula, Calif
Santa Paula, Calif
Re: Cities Service Curb Sign base warning [Re: Dick Bennett] #355198
Tue Sep 11 2012 04:47 PM
The seller was real nice about it and even said he would refund the return postage, which most will NEVER do, but I thought I was buying an original base with "NO CRACKS, BREAKS, OR WELDS" and thats what I should have gotten.
I have no problem with it but he's passing it on to another buyer in Missouri and if its a member here, I wanted them to know about the problem.
Maybe they won't care and the problem is resolved! LOL
Re: Cities Service Curb Sign base warning [Re: K W FRITH] #355308
Wed Sep 12 2012 03:54 AM
canada
W
Wes Hague Offline
Wes Hague  Offline
W
canada
Kevin, I think your being tough on the seller as he will refund your money and all of it,,,no other guestions asked,, I think you need to give the guy credit not negative feedback... JMO.,
Wes.......
Re: Cities Service Curb Sign base warning [Re: K W FRITH] #355327
Wed Sep 12 2012 06:15 AM
Cataula, Georgia, USA
Catauladave Offline
Catauladave  Offline
Kevin...
None of my business, but why not repair the item? There doesn't seem to be many around or you would have several by now. Nice looking piece anyhow...
Dave
Dave Jones
It's All Just Stuff
Page Time: 0.027s Queries: 15 (0.006s) Memory: 1.9190 MB (Peak: 2.0602 MB) Zlib disabled. Server Time: 2018-09-20 21:15:21 UTC
