#356626
Tue Sep 18 2012 08:28 AM
Posts: 1,559 Likes: 43
Posts: 1,559 Likes: 43 |
Just got a beautiful 3'x5' NOS Marfak sign that was packed in bubble wrap. Now I've got circles in the red area. Before I destroy this trying to remove them any suggestions? My experience says the are there to stay. HELP!!!
Posts: 2,085 Likes: 11
Posts: 2,085 Likes: 11 |
If it has a shine ,good old fashion cream wax would be my first try.
Posts: 850 |
I've had good luck with Meguir's fine scratch remover also.
Posts: 4,643 Likes: 42
Posts: 4,643 Likes: 42 |
Do it soon. The longer you wait,the harder to get em out.
THANK YOU ALL! I'm on it. I have Meguires cleaning wax and it's working!!! This sign is going to shine now!
Posts: 2,702 |
I always wrap my stuff with paper towels (before any kind of wrap) because of this. I'd try a wax, lightly. Don't think you'll hurt a thing that way. If they're on the red, they're on the white, black and green ?
Posts: 731 |
X2 on the fine cut... It works wonders!
Posts: 382 |
This is why we are supposed to wrap with the circles to the outside. Best of luck!
Eddy Smith Call or Text: 678-232-4637 E-mail: eddysmithjr@gmail.com Always looking for pump plates or small signs!
Posts: 2,702 |
This is why we are supposed to wrap with the circles to the outside. Best of luck! Does the same thing ? Wrap with paper towels, not news print either.
Posts: 382 |
I've never had it happen as long as I wrap with the circles pointing out. I also use a water based bubble wrap which helps. It's actually semi-organic and turns to water if exposed to heat and direct sunlight.
I don't doubt the paper towels would help too.
Posts: 2,702 |
I treated my cans the same way when shipping. I always treated everything like a cars finish. Would you put bubble wrap (either side on your car ?) or news print ?
Just saying....
Sign is looking great. Will post in BOTW. Paper towel works great for smaller signs. This thing really needed a sheet. I wouldn't put any bubble wrap, either side, against a painted surface. Thanks Again!
Posts: 19,470 Likes: 1022
Posts: 19,470 Likes: 1022 |
a good heads up on the use of bubble wrap..
Posts: 850 |
I agree- I NEVER bubble wrap a painted sign- the oil in the plastic will bleed every time - I've even had it damage a powder coated surface. Should be ok with porcelain. I've never tried the "green" bubble wrap?
Posts: 382 |
I've never had an issue with a sign shipped to or from me but I can see the point.
I just started using the green wrap last year. Had no issues so far and used it on everything I have shipped, painted metal, tin, porcelain, you name it. It's water based so I doubt it has any oils to leave a mark.
