"Contains lead" sign for Tokheim 39 tall. #363968
Thu Oct 18 2012 02:58 AM
MICHIGAN
Steven C. Online content OP
Steven C.  Online Content OP
MICHIGAN
If you were trying to do a period correct pump, which sign would be correct for a Tokheim 39 tall?? Or would either fall into the years of the 39 tall?
Any other info on the why the two different versions of this would also be appreciated.
Re: "Contains lead" sign for Tokheim 39 tall. [Re: Steven C.] #363970
Thu Oct 18 2012 03:22 AM
Carthage, IN USA
tbuckles Offline
tbuckles  Offline
Carthage, IN USA
The Tetraethyl sign would be correct for your pump. Somebody on here may know the year that the Antiknock started, the earliest I have seen the Antiknock is on early sixties Sunoco blend pumps.
Tom
Carthage Indiana
Re: "Contains lead" sign for Tokheim 39 tall. [Re: tbuckles] #363982
Thu Oct 18 2012 06:16 AM
MICHIGAN
MICHIGAN
Thanks tbuckles. Hopefully someone can expand on this.
Re: "Contains lead" sign for Tokheim 39 tall. [Re: Steven C.] #364165
Thu Oct 18 2012 10:20 PM
St. Louis, MO, USA
Jack Sim Offline
Jack Sim  Offline
St. Louis, MO, USA
Antiknock was used by the Ethyl Corp. in the 1920s when they first came out with their product. I have many ads with that in big letters.
Re: "Contains lead" sign for Tokheim 39 tall. [Re: Jack Sim] #364171
Fri Oct 19 2012 02:31 AM
MICHIGAN
MICHIGAN
Jack, Thank you very much for your response. So just to clarify, if the antiknock goes back as far as the 20's, is it correct to say that either sign would then span the years of the 39 tall?
Re: "Contains lead" sign for Tokheim 39 tall. [Re: Steven C.] #364260
Fri Oct 19 2012 03:31 PM
USA
keithia Offline
keithia  Offline
USA
No. I have only seen the anti-knock version on newer 60's pumps as said before and I would not put one on a tall 39. The anti-knock slogan may have been used in other contexts but not on the lead signs until the 60's or so.
Re: "Contains lead" sign for Tokheim 39 tall. [Re: keithia] #364261
Fri Oct 19 2012 03:42 PM
MICHIGAN
MICHIGAN
Thanks for the clarification Keithia. I'm not sure I understand then what Jack was saying. Unless someone says otherwise, I'm going to shop for the second one.
Re: "Contains lead" sign for Tokheim 39 tall. [Re: keithia] #364263
Fri Oct 19 2012 03:57 PM
Longview, WA
Bob Richards Offline
Longview, WA
I'm not sure about when the "Contains Lead" signage.... First was used....
But "Anti-Knock" Properties of Ethyl Gasoline touted just that... "Anti-Knock"..... back in the 20s... As Jack, said....
Here are a few of those magazine ads from the late 20s and 1930/31:
As to the "Contains Lead" signage... For me the older (IMO) "Tetraethyl" signage as below would be correct on the older Visibles and Electrics......
Re: "Contains lead" sign for Tokheim 39 tall. [Re: Bob Richards] #364297
Fri Oct 19 2012 07:58 PM
texas
cosdencop Offline
cosdencop  Offline
texas
In Check The oil it says tetraethyl is the older of the 2 dont remember the dates though .
Re: "Contains lead" sign for Tokheim 39 tall. [Re: cosdencop] #364302
Fri Oct 19 2012 08:26 PM
Edgewater, Colorful Colorado
st.rod Offline
st.rod  Offline
Back to the original question about what would be right on a '39'
Answer is!
Tetraethyl
The later signage said 'antiknock'
as said before late 60's
Larry
Re: "Contains lead" sign for Tokheim 39 tall. [Re: st.rod] #364310
Fri Oct 19 2012 09:59 PM
St. Louis, MO, USA
Jack Sim Offline
Jack Sim  Offline
St. Louis, MO, USA
I only know literature, these guys know more than I do about signs.
Re: "Contains lead" sign for Tokheim 39 tall. [Re: Jack Sim] #364326
Sat Oct 20 2012 05:16 AM
MICHIGAN
MICHIGAN
Thanks to all for your help!!
Using only the data presented in this thread, it seems to me that although "Ethyl" advertised their product as an antiknock product, the actual "contains lead" warning signage in the earlier period did not use the word "antiknock".
I'm going to do my best to search out as many vintage pics of 39 talls that I can and see if I can confirm this for myself.
I did learn something else big in this though. Being very green to the hobby, I didn't know that Ethyl was an actual gasoline brand unto itself. I thought that they were only an additive that sold to gasoline manufactures. I need to also check this out more for myself.
Again thanks to all!!!!
Re: "Contains lead" sign for Tokheim 39 tall. [Re: Steven C.] #364359
Sat Oct 20 2012 09:05 AM
New Mexico
Old Iron Offline
Old Iron  Offline
New Mexico
I agree with the other guys;tetraethyl.As you begin looking at pics of old pumps I think you will notice that on many tall 39's the signs are mounted on the doors rather than on the sides of the pump.I mention it because on my tall 39 they were mounted on the doors.When I restored it,I put them back on the doors where they had them.Good luck.
Re: "Contains lead" sign for Tokheim 39 tall. [Re: Old Iron] #364426
Sat Oct 20 2012 06:43 PM
St. Louis, MO, USA
Jack Sim Offline
Jack Sim  Offline
St. Louis, MO, USA
Bob Richards may correct me on this, but I do not believe that gas was sold under the brand name of Ethyl, I believe it has always been an additive available to any company.
Also, if I remember correctly, Ethyl was owned by General Motors, but used Dayton, Ohio as its address, because it was devoloped there.
Re: "Contains lead" sign for Tokheim 39 tall. [Re: Jack Sim] #364430
Sat Oct 20 2012 07:13 PM
USA
keithia Offline
keithia  Offline
USA
I agree with Old Iron and Jack on their above comments.
Page Time: 0.028s Queries: 15 (0.007s) Memory: 1.9212 MB (Peak: 2.0772 MB) Zlib disabled. Server Time: 2018-10-20 09:35:15 UTC
