 Re: Help identify Visible Gas Pump Gallon Markers
Posts: 1,074 Likes: 21
Posts: 1,074 Likes: 21 |
Interesting!... I hadn't seen that thread. I searched a bit for that patent on Google but didn't see it yet. Do you remember what it was listed under?
I collect Gilmore Oil Co. stuff, and other west coast brands...
Tim and anyone else who have contributed to this thread... Thank you very much!
I've owned a few visibles, but do I admit that they pretty much looked the same to me... Thanks to all that have contributed. I can now see some of the different nuances that "jump out" to you that are Pump Collectors....
I've learned quite a bit by following along.... Of course, I have so much more to learn...
Posts: 508 Likes: 5
Posts: 508 Likes: 5 |
Patent # US 1908202 assigned to the American Liquid Meter Company in Alhambra California.
Where did you find the photo's at?
Posts: 508 Likes: 5
The illustration on the right shows an indicator shaped exactly like the real photos on the right. The real photos were previously listed as an unidentified cast indicator. I can't say for sure that they are from a Progress pump but until someone steps up with a real photo of their Progress indicator this is the best I can do.
Posts: 508 Likes: 5
Butler is very simple in the fact that most of the pumps used only one style of indicator. It is belle shaped like so many other pump use but has a unique opening right below the stamped number. It's shaped like a flying saucer with an additional two small holes in the fold close to the edge.
Posts: 508 Likes: 5
I could not find any Real photo's of an Erie Indicator so you'll have to settle on an illustration, which we have learned are not always accurate. In fact sometimes they aren't even close. From the illustration they look like the indicator commonly found in a G&B T-176 but with a more rounded top.
Posts: 508 Likes: 5
I couldn't find any real photos of Lancer indicators and the illustration is almost useless. Hopefully a Lancer owner will step forward and provide a picture.
Posts: 508 Likes: 5
National Stores. It's hard to tell from the illustration whether the pump has an indicator or an etched cylinder.
Posts: 508 Likes: 5
Rheem. Only one model is known. The indicator looks like the indicator commonly found in a G&B T-176.
Rheem
Posts: 508 Likes: 5
Used on all Safety Steel models.
Safety Steel
Patent # US 1908202 assigned to the American Liquid Meter Company in Alhambra California. Thanks, found the patent file. I wondered why it had all the adjustable grooves on the one side. Now I know the reason. Wonder how well it worked?
Posts: 508 Likes: 5
Dayton Indicators. I could not find an actual photo of a 400 or 450 pump to confirm that this is the correct indicator.
Posts: 508 Likes: 5
At least four companies used the shield shaped indicators; American, Boyle-Dayton, Doty and Milwaukee. American, Doty and Milwaukee all used the same style with two rivets through the face holding on the tension clamp and meniscus line which were all one piece.
American used it on several of it's models.
Doty sales literature only showed etched cylinders but almost all photos I've seen of Doty's have the shield. This doesn't mean they were original to the pump.
Milwaukee had it's own unique shaped indicator but for some reason used the shield on it's 297 & 299 model.
Boyle Dayton used the shield but did not use the spring tension to hold the indicator to the rod. It had its own style of clamp, tightened by a screw to the rod. It's design eliminated the need for rivets through the face.
Posts: 508 Likes: 5
Hawkeye-Dart. This is the best I could come up with.
Posts: 508 Likes: 5
Below are two pictures. One features Keesee and the other shows an indicator previously identified as a Keesee. I'm convinced now that the second set are actually Boyle-Dayton indicators as shown in my post #401924
The Keesee factory and the Boyle-Dayton factory were both located in southern California. Because of the similarity in the clock style arrow indicators I'm assuming some Keesee pump owners in need of a replacement indicator used the Boyle-Dayton indicators which would have been readily available in the market areas.
