#386331
Tue Jan 15 2013 03:29 PM
Posts: 508 Likes: 5
Posts: 508 Likes: 5 |
If some of you would be willing to take some detailed photos of you gallon markers, I would be willing to put them together for input into the gallery so that everyone could benefit.
Ideally it would be nice to have a full length photo front and back and a close up of a single marker both front and back.
This may be overkill but feel free to provide information such as:
Overall length: Is the supporting rod square, flat, round or other Mounting method: Screw, spring clip or other Marker Material: Brass, Aluminum or SS Rod Material: Brass, Aluminum, steel or other Are number Embossed or Painted if embossed - Raised embossed or depressed embossing If Embossed is it also painted # required for a pump How is it attached to upper and lower plate: Where is it located - Inside/outside
Posts: 8,513 Likes: 293
Posts: 8,513 Likes: 293 |
Thanks, Tim. That would be a great resource for collectors and restorers. Those that got 'em, lets post 'em.
#386450
Tue Jan 15 2013 10:19 PM
Posts: 508 Likes: 5
Great picture Dick and thanks for the extra information added at the bottom. This should be a great help to someone restoring a Groetken,
I'm NOT so sure! After looking in other thread you ID them as FLECKENSTEIN!
Calling on Doc Fortin for Positive ID!
#386452
Tue Jan 15 2013 10:32 PM
Posts: 508 Likes: 5
Thanks DB. Hopefully you will inspire some other oldgassers to get their camera and tape measure out to document their sets.
Posts: 508 Likes: 5
This is a picture of what I believe to be a Fleckenstein 100A that I took at Iowa Gas in 2008. The picture of the markers came from this pump. However that doesn't mean they were correct. Any ideas?
That would be very useful and time saving information.
Posts: 508 Likes: 5
At a distance a Wayne marker and a Butler marker may seem the same, but when seen up close there are quite a few differences.
Posts: 508 Likes: 5
After further consideration Dick has decided these are for a Fleckenstein 10 gallon Visible. My earlier pictures were for as Fleckenstein 5 gallon visible.
I've had that stick Many years & never really looked at how the number plates were attached. Look at 3 pic's on right side, they could actually screw into each other. Center pic, right side I pulled the rod up a little to show it wasn't all 1 pc. Each rod section is approx. 2 1/2" & threaded each end.
Over the years many service companies have changed out the indicators for one reason or another & installed what ever they had on hand that would work. Tim & I are working w/ the best knowledge & Information we have to get each correctly ID. There is bound to be some mistakes. In this thread below there are several UN-Known indicators that WE need an ID for; http://oldgas.com/forum/ubbthreads.php?ubb=showflat&Number=385362&page=1
Posts: 343 |
After further consideration Dick has decided these are for a Fleckenstein 10 gallon Visible. My earlier pictures were for as Fleckenstein 5 gallon visible. I just picked up a Groetken (5 gallon) and will get pics of the indicators if that will help. Thanks, Steve Z
Posts: 2,131 Likes: 76
Posts: 2,131 Likes: 76 |
Every time I work on a visible I will take pictures and measurments and get them to you. Richard
Posts: 508 Likes: 5
According to Greg Fortin: "They (Fleckensteins) were made originally out of both brass(rare) and pot metal. They where used on both 5 and 10 gallon pumps. There is also a stamped steel diamond shaped marker used on some 5 gallon pump
Posts: 508 Likes: 5
Dick Bennett did a good job on this picture and information. Surely someone has an original pump with this set and will identify it.
Posts: 508 Likes: 5
Dicks last unknown set appears to be the same as the ones in this photo but he has additional information to help identify it.
I would assume the cylinder must be under 22" and hold 10 gallons which leaves only Fleckenstein and National. Since Fleckenstein had cast markers my vote would be National. How about it National owners, can you confirm this?
Come On guys, Tim is trying hard to make this happen for Future References, BUT HE NEEDS MORE HELP. ANYONE can email me pictures & info & I will set it up as I have above. Credit will be given if so desired [it's Better for you to be blamed than me for miss info! :D]
Posts: 758 |
Regarding the set of unknown gallon markers. I, personaly took a set out of a Mae West. I might go with generic replacement as I used to think they were only used on the converted Fry's with 12 by 27 cylinders.
Posts: 508 Likes: 5
Thanks Dick. Those are a good looking set of markers
Posts: 508 Likes: 5
Another marker set. Thanks Dick Bennett & Dennis Maier.
Posts: 508 Likes: 5
Another marker set from Dick Bennett & Dennis Maier with an addition by myself.
