#401765 Fri Mar 15 2013 02:58 PM
l've got a spare repop 13.5" lens. Would like to turn it into a clock by drilling a hole in the center of the lens, then attach the clock mechanism to the back with the hands in the front, then hang on the wall. Has anybody done this and if so, what guidance might they give on drilling the hole? Thanks in advance!
Take it to a glass shop and see if they can do it.they have a better chance of success than you do.
All I can recommend is grit your teeth, hold your breath and pucker them cheeks and wait for the crack.
Yea... I'm assuming it's a long shot, but the glass shop is a great idea, thanks!
take it a place that has a waterjet , They might be able to do it
Sid
www.trifivechevys.com
www.knifegates.com
It's not impossible at all.i have gotten several flat pieces of glass drilled.but the guy always tells me, he's not responsible if it cracks.hasent cracked one yet.a curved lens may be a little different though.
A friend of mine makes holes in flat glass using a Dremel tool. Keep in mind that is flat glass. I like the glass shop idea. If they break it then I guess you would have as well.
If you decide to do it yourself, remember, glass bit, low pressure and lots of lubrication. I make a dam with plumbers putty and use soapy water. Save some, break some. I'm at aabout 70% good.
Dremel Drill sounds like your best bet, lubrication and RPMs mentioned... Practice first on something... I think it can be done. What size hole do you need done ?
There are diamond drill bits made just for drilling glass.
Get ya one and have at it! You might want to practice on a bottle or jar first to get the hang of it.
I bought a set of small glass bits at I think loews or Home depot. Drilled a couple holes in a regular pane no problem at all. They walked a bit at first. They sell them on ebay also.#360615532853 The water dam idea sounds good. Do it yourself,I say!
This would be different then drilling normal plate glass.
Something, to bear in mind is that when the logo's are baked on; it tempers/hardens the glass. This in turn makes it more prone to cracking.
Dave GILL,
Y
Y
I have done it with a dremel with a glass bit they have, wasn't in the center of lens but it worked good for me, I had to try for myself , I'd rather break it than somebody else.
Isnt glass melted sand.? seems to me it would be heated WAY more in the initial process than later in some oven at a few hundred degrees.
Support the back side w/ a sand bag.
Dave,
IF the baking of FRIT in the making of lenses had Tempered the glass, WE would never be finding Cracked lenses. Tempered Glass SHATTERS like side windows in cars/trucks & shower doors.
