#45799
Mon Apr 10 2006 06:12 PM
Posts: 2,094 Likes: 4
Posts: 2,094 Likes: 4 |
I went checking out paint today for my f 1st resto on my wayne 80.The price the guy quoted me about made me fall off my chair.the paint is mobil red in single stage w/hardners.It's called del fleet esentials paint code 75570. The price quoted was $243.43 for 3 quarts.That seems expensive I was guessing about 100-$125.The white in the same type of paint is $79.20 for 3 quarts that seems reasonable.Paint code 8321 Am i way out of touch or was this guy on crack?
I haven't painted in about 15 years but wow.What do you all pay for your paint?What type do you use?The last time I painted I used Dupont's centari is that still available?Please help.Thanks, Tom
Got Socony???
Tom
#45800
Mon Apr 10 2006 06:46 PM
Posts: 269 |
Tom, I just got done painting two gargoyle mobiloil oil cabinets. I used mobil red in PPG american finishes single stage, $140 a gallon. A better paint is PPG concept, about $200 a gallon.For some reason reds are alot more $ then other colors. Jim
#45801
Mon Apr 10 2006 07:10 PM
Posts: 1,808 |
since I retired I have opened a paint/powdercoating business. Red is your most expensive color because it has the most pigment in it....folowed by yellow and orange...try a dupont/omni...in base / clear coat same color but alot cheaper. I would only use this if you plan on displaying your pump inside. Price is about $17-$25 a quart thats more than enough for the base......with hardner / reducer etc...about $65 a quart...one quart is more than enough for a pump....don't forget the clear!!
#45802
Mon Apr 10 2006 07:34 PM
Posts: 8,513 Likes: 293
Posts: 8,513 Likes: 293 |
Reds always cost more and the worst part is some of them hide poorly so they need more coats. A quart should do it if you don't spray too much inside the pump or out into the air. It's expensive enough, so don't buy 3 quarts unless you need it. But if you ever need 3 quarts, check to see if a gallon might be around the same price. It is possible that was the correct price for that paint. But that guy could be on crack, too.
------------------ Jim "Oldgas" Potts Your host and moderator
#45803
Mon Apr 10 2006 07:51 PM
Posts: 529 |
Tom, I've been selling PPG paint for 23 years and we've had some of the highest percentage price increases and more frequent than I've ever seen. Pretty much all automotive and fleet paints are petroleum based and packaged in steel cans(double digit price increases for both over the last 1-1/2yrs.) DelFleet Essentials is a high solids low voc polyurethane enamel designed for fleet applications. It covers better than most conventional paints,but also dries slowly. Yes,reds are nearly always more expensive than whites.I believe what Jim is calling PPG's American finishes is like or is the same as the Omni line of PPG paint. It is an acrylic urethane and is more cost effective. It doesn't cover as fast,hence a lower cost. Jim is right about the Concept acrylic urethane. It's one of the best finishes for single stage solid colors, but it is more expensive. I guess that everyone has their own personal preference for brand,type and quality of paint that they prefer to use. Centari is Dupont's acrylic enamel. It is slower drying than acrylic urethanes.Some people are use to spraying acrylic enamels though and prefer to use them. PPG increased their Delstar acrylic enamel by 15% last price increase because they want it to go away like straight enamel did years ago. I know that a lot of people like to use base coat/clear coat paint on pumps, but I personally don't see the need. A high quality single stage paint has just as good of gloss as bc/cc. All you accomplish(in my opinion) is make us paint jobbers more money as bc/cc is more expensive to shoot.If you are shooting a metallic color, by all means you should spray bc/cc,but not on solid colors. Pat
#45805
Mon Apr 10 2006 11:17 PM
Posts: 538 |
To save some materials look in to a tintable sealer which is what I use you can get close to youre color and then wont need as many coats of the color. I use base clear on all of mine and I use omine base its cheap and does good. It takes not quite a quart to do inside and out. I have a red I had mixed I use for mobile, some red seems quite orange when yo spray it. do the inside first to make sure you like the color. If its going to sit outside I would consider base clear, red seems to oxidise faster than any color. the clear will last longer and you can buff it more times. This is just what works for me, and I am no paint expert. the only color I prefer not to clear is black it is much deeper in a single stage. Laquer black is the best but getting harder to find. Good luck you will enjoy it. Brandon
#45806
Tue Apr 11 2006 12:12 AM
Posts: 761 |
Peter Niessen, are you talking about the Tremclad system?
Brian
Always looking for SKELLY items.
#45807
Tue Apr 11 2006 01:06 AM
Posts: 647 |
I always primer and sealer with a grey color.Sealing with a color that is close to what you are spraying does not always cover faster,its something about the neutral color of grey that covers faster,Jim might be better to explain this?For my personal pumps I found a brand called american finishes,cheapest paint I have ever found and lays down slicker than sikkins.About 40 a gallon and they have a very bright red.
#45808
Tue Apr 11 2006 04:30 AM
Posts: 3,739 Likes: 87
Posts: 3,739 Likes: 87 |
Tom: Save your $$'s and only get a quart of the red and the white. You'll have a bunch left if you're using a HVLP gun (and you should be!). I personally don't shoot the inside with the expensive paint. If you have a steady hand and can control your 'wet' edge - you can get away with using Rustoleum in a spray can. At $7 or $8 a can, you can keep it in stock and ready to go. Just use a complimentary color or black/white. You will have to mask off the outside of your panels - but it's still way cheaper than shooting $100/quart paint on something hardly anyone will ever see. Later . . . Jim ------------------ www.T-waysGraphics.com Always buying Ethyl Globes, Ethyl Single Lenses & Misc Ethyl Items.
#45809
Tue Apr 11 2006 06:58 PM
I just wanted to thank everyone for their advice and opinions on this topic it is greatly appreciated.thank you.
Got Socony???
Tom
#45810
Tue Apr 11 2006 08:17 PM
Posts: 69 |
Yep, Tremclad. I guess I should've been more clear. I'll post some pics of the car (and eventually the pump) when I'm done. Just waiting for a little warmer weather. After going through the checkout at Home Depot I was only $60 poorer! It might not win me any awards...
#45811
Tue Apr 11 2006 09:06 PM
Posts: 761 |
Tremclad is found in Canada, is there another name for it down here in the states. I would like to try it on a pump that I'm keeping out side.
Brian
#45812
Wed Apr 12 2006 05:53 AM
Posts: 1,253 Likes: 12
Posts: 1,253 Likes: 12 |
I looked at that post above about the tremclad. VERY interesting. Actually printed off a bunch of it for closer reading. I have an old refrigerator that I want to redo and think I will try this out. What the heck, it doesn't cost hardly anything. The American version is rust oleum.
I'll keep everyone updated as I try this out.
#45813
Wed Apr 12 2006 07:27 AM
Posts: 2,055 |
BIG CHEESE HAS PUT A PAINT LINE OUT [NASTALGIA COLOR] IT IS A ACRYLIC URETHANE ENAMEL ..... and the prices are rightous, a 1qt kit in red is 40.00 and that inc. 1qt red . hardner, reducer, mixing cup ,strainers ,and a paint stick. we also carry the big cheese clear coat,. call for more info. cheese 810 225 1886
#45814
Wed Apr 12 2006 10:53 AM
Posts: 858 |
#45815
Thu Apr 13 2006 12:04 PM
Posts: 124 |
For simple colors like black, red, white..ect I use Rustoleum (don't use XO Rust, doesn't shine very good). If you use hardner and a good reducer like dupont or even dupont's Nason, your finnish will look as good as Duponts single stage. For mixed colors, I use Nason about $50 qt.
#45816
Sat Apr 15 2006 07:54 AM
Posts: 36 |
FYI- I get all my paint and supplies from Smart shoppers in Kentucky; they have acrylic enamels, urethanes and all the other goodies.....killer prices and most of the time you have your stuff in 2 days...website is smartshoppersinc.com...good luck and happy motoring!!
gaspumpchas
#45817
Sun Apr 16 2006 01:16 AM
Posts: 11 |
That Tremclad (Rustoleum in the U.S.) system is fascinating reading. After I read about it I went down to the local auto body paint and supply store and asked about rolling on primer for the Dupont Centari, and found out I could roll it on as well!! I think I am going to try this. I am getting the paint matched right now, and will ask a lot more questions before I do it, but I am much more inclined to roll or brush rather than use the air gun if possible. This is a little different than the tremclad system, as I guess it wouldn't be so many coats. I have to try it! Ed
