#493079
Wed Nov 20 2013 06:30 AM
Posts: 890 |
......John fanfan75601@yahoo.com
Posts: 1,145 Likes: 1
Posts: 1,145 Likes: 1 |
Follow the Red Indian Trail
Posts: 890 |
A bit of trivia: Can anyone tell me what's wrong with the twin pump? and it's not because it doesn't have a globe... look closely.......
Posts: 1,023 |
My first thought on the twin was wow, that looks great...but seems like it should have the smaller size pump plates...was not going to mention it but since you asked that's my guess.
Posts: 1,391 Likes: 4
Posts: 1,391 Likes: 4 |
They all look great! Very nice! On the trivia question is it the price per gallon difference , between the two brands?
Posts: 890 |
My first thought on the twin was wow, that looks great...but seems like it should have the smaller size pump plates...was not going to mention it but since you asked that's my guess. That was a very good guess and although you are correct ( I couldn't find any other pump plates) that is not the mistake I was looking for....
Posts: 890 |
They all look great! Very nice! On the trivia question is it the price per gallon difference , between the two brands? yes, Travis!!!! If I'm not mistaken, the Sky Chief should be priced higher than the Fire Chief.......Sorry, no prizes for this contest!!!
If you get a little free time just swap out the computers, or better yet find how to change / reset the pricing . Might be a little informational for people like myself. Mr. Sim I bet has a book on the methods to do that.
Biggest Mistake I see is they are in SOMEONE ELSE GARAGE!
Posts: 5,980 Likes: 24
Posts: 5,980 Likes: 24 |
Pump plates seem a little large, also the ad glass does not seem centered or something. I had the larger version of this pump and those signs worked well on that, but this I believe needs the smaller version of signs. That paint job on the lower section of the Gilmore visible pump is just great. Nice idea on the placement of the lines.
Posts: 19,464 Likes: 1017
Posts: 19,464 Likes: 1017 |
which globe lens's would this pump take or would you use 1 of each?..
Posts: 890 |
which globe lens's would this pump take or would you use 1 of each?.. I was just going to use a plain Texaco with the black outlined green "T" that appears on each pump plate. I'm sending the metal globe body to be painted to match the pump....
Posts: 890 |
Pump plates seem a little large, also the ad glass does not seem centered or something. I had the larger version of this pump and those signs worked well on that, but this I believe needs the smaller version of signs. That paint job on the lower section of the Gilmore visible pump is just great. Nice idea on the placement of the lines. You're right Craig. The pump plates are large. I looked for smaller before the restoration, but I couldn't find any. It's a little late now because holes have already been drilled in the pump.. The ad glass was too big and had to be cut down so I'm looking for smaller ad glass that will look better...
Posts: 890 |
Biggest Mistake I see is they are in SOMEONE ELSE GARAGE! I was waitin on you to chime in....
Posts: 3,255 Likes: 13
Posts: 3,255 Likes: 13 |
Thanks Mike
