#51286
Mon Mar 19 2007 07:38 PM
Posts: 32 |
I just bought a Bennett 132 clockface pump to restore. The problem is that it is too tall for my home interior when a globe is on it. How much will it hurt the value to cut it down 5"?? I hate to do it, but it is the only way other than moving........
#51287
Mon Mar 19 2007 07:41 PM
Posts: 1,782 |
cut it down and ruin it... NEVER... IF YOU CAN'T LIVE WITH IT THE WAY IT IS... SELL IT...
#51288
Mon Mar 19 2007 07:43 PM
Posts: 3,050 |
CHEAT..... Use a 13" globe, and assemble it wihtout the base. DONT CUT IT!!!!! CHOP CARS.... NOT GAS PUMPS!!!!!
[This message has been edited by Thunder II (edited 03-19-2007).]
#51289
Mon Mar 19 2007 08:00 PM
Posts: 243 |
not like its super rare 132 s and 150s are every were chop it !man id like to see it done ..
#51290
Mon Mar 19 2007 08:02 PM
I would CUT 3 1/2" off the bottom sheetmetal & frame, & Not more than 2" off the upper [below the face] sheetmetal & frame. IT'S YOUR PUMP, if this is what has to be done for you to enjoy it inside the house, DO IT. It can always be resurected at a latter time. db
#51291
Mon Mar 19 2007 08:04 PM
Posts: 1,306 Likes: 32
Posts: 1,306 Likes: 32 |
#51292
Mon Mar 19 2007 08:07 PM
Posts: 32 |
Thanks for the replies. I am going to go for it. Dick, I was thinking the same way, cutting most of it on the bottom piece and only 2" on the top portion below the face. I will let you know how it turns out. thanks much.
#51293
Mon Mar 19 2007 08:14 PM
Posts: 1,782 |
big mistake but its your pump...
#51294
Mon Mar 19 2007 08:15 PM
Posts: 464 |
Don't dare cut the pump. Its a piece of history, regardless if its rare or common.....use a original 12.5" globe.....or cut down a plastic capco globe body to work......or just don't use a globe. I know if I was a future buyer, I would not pay much for a cut pump.
#51295
Mon Mar 19 2007 08:16 PM
AquaElvis had 1 @ Reeds Gas Bash a couple of years ago that had been CUT DOWN many years before. It was right at 5' to the globe holder. I also know where there is a HAYES [looks similar to the 132. DON'T TELL Jeff] that is about the same size. IF they were mine, I would leave them that size. db
#51296
Mon Mar 19 2007 08:51 PM
Posts: 356 |
Got a Wayne 515 in my garage that just barely stood up with a 9ft. ceiling. Couldn't stand it without a globe, so in went the skylight. Neighbors know when I'm in the garage by the glow of light from the globe in the skylight. Kent.
#51297
Tue Mar 20 2007 04:44 AM
Posts: 3,739 Likes: 87
Posts: 3,739 Likes: 87 |
Gasteek: Exactly how much too tall is it? I ask because you can cut quite a bit of overall height out of a 15" globe assembly by using a low-profile body. The body itself is about 2.5" shorter than a high-profile - and you can remove the base and reattach it 'higher' up in the body to gain another inch or so. There is also a bit of 'extra' at the bottom of the globe base that can be trimmed off. With all the modifications to the body, you can get the overall height of the body down 4" - 5". That just might be enough to make everything fit when the pump's assembled. Of course, you would have to mount the body on the pump and then lift the pump up to verticle in your house as you won't have clearence to lift the globe off the pump. Later . . . Jim
#51298
Tue Mar 20 2007 06:17 AM
Maybe it would be a lot easier to raise the cieling between two joists.
#51299
Tue Mar 20 2007 09:30 AM
...gasteek...before you start hacking away at an antique , you should SERIOUSLY consider selling your original pump to someone who is able to appreciate it for what it is - then you can use the proceeds to buy a repro pump - or even a repro pump kit (then you could 'restore' it yourself, if it's important that you D.I.Y.)...look here: http://www.bobs-garage.com/pumps/repro.htm ...scroll down, this guy's got a pump that looks JUST LIKE your Bennett...heck, you might even be able to get one shortened when you order it...the last thing I'd do is ruin an original pump because my ceilings are too low to display it with a globe... ...has no one watched Antiques Roadshow lately? Has anyone ever seen the appraisers tell someone it's a GOOD thing Great Aunt Flossie cut the legs off of her Federal china cupboard?...c'mon, folks, let's at least TRY to keep it real...
#51300
Tue Mar 20 2007 11:48 AM
Posts: 1,672 Likes: 13
Posts: 1,672 Likes: 13 |
Listen to the ones who said NO!! I would never do it. It will hurt the value. If I was a buyer I would have to pass on it or it would have to be real cheap if it had been cut down that much. You're losing some of the pumps identity by cutting, please don't do it. If you do please don't show us later.
KJV Psalms 16:11
#51301
Tue Mar 20 2007 12:09 PM
Posts: 892 |
Is that the only pump you wanted to restore? If not, how about trading it to someone that wants it and getting a pump that will fit in your home without cutting it up? Just trying to find a way!
Mick
#51302
Tue Mar 20 2007 12:28 PM
Posts: 1,808 |
#51303
Tue Mar 20 2007 12:32 PM
Posts: 772 |
It's yours and you can do whatever you want with it. You are the only one it has to please. I restored a Milwaukee clockface and put it in my screen porch but had to redo my ceiling to get it to fit, between the rafters. It was easier to do this than cut the pump down.If you are going to keep it in a certain place and don't have a lot of other options do want ever you want with it. It's only a gas pump. You'll never sell for enough to balance the national budget.
#51304
Tue Mar 20 2007 02:25 PM
Posts: 356 |
I put in a 4ft x 4ft skylight, very cool at night! I see I'm not the only roof modifier here! Kent.
#51305
Tue Mar 20 2007 02:36 PM
Posts: 3,550 Likes: 20
Posts: 3,550 Likes: 20 |
I would, respectfully, encourage you to not cut it. Yes, it is yours. But, you have been given some good options. Sell it, etc. I hate to see any antique 'modified.' Cars are one thing as people chopped them to make hotrods. I don't forsee a large market for a "HotRod" gaspump. But, who knows, it may the wave of the future. I know a large number of people who criticize the reproduction pumps, so I don't thing a cut pump is a good idea. Good luck with your choice.
Alex
#51306
Tue Mar 20 2007 02:48 PM
Cut out and box the sheetrock ceiling...if you move it will be easier to fix the sheetrock than regretting cutting the pump.
#51307
Tue Mar 20 2007 03:15 PM
What he is doing is NO WORSE than removing the computer & installing a dummy clockface because you can't find one or step up when you do. When it's time too sell it, WILL you return it to a computer pump. I DOUBT IT. OR, cutting the original door to make a showcase in the lower part. db
#51308
Tue Mar 20 2007 03:30 PM
Dick, I see yoru point. However, I think this is a little different. I disagree with puttingin a clock face if it never had one. but, if it had one and you cant get or afford an original, then a reproduction is OK. Cutting the door to make a display case, to me, falls in a gray area. Yes, one is changing the pump's original look, but you are doing it to create a display case which makes it functional. Somehow, cutting down the size of it (again, only my opinion) crosses the line of modifying something for function. But, dicespumpandpaint also has a good pont, it is not rare, so this may be less of an issue.
Would you cut a roman pump??? Don't think so. Anyway.....always a fun place to discuss ideas.
#51309
Tue Mar 20 2007 04:24 PM
Posts: 389 |
At one time I had 3 pumps in my house 2 were Bennett 150's and they fit my 8' ceilings.It was snug but they fit.I used the plastic globe bodied globe.You may be able to squeezeee the new metal 13.5 body into it also. jim
leonardoil
#51310
Tue Mar 20 2007 08:13 PM
Posts: 53 |
I will trade you a Tokiem 300, then we will both be happy. Les Warner
Les's Shell
#51311
Fri Mar 23 2007 08:09 PM
This was Jeff Houston's [aquaelvis] 150 [he sold it]. It had 1 SSE & 1 RHEEM face. Forgot to ask how tall it was, but approx. 5'. db
#51312
Fri Mar 23 2007 08:31 PM
Posts: 3,352 |
I mean no disrespect but have to call Dick on his last post.
There is a big difference in cutting a pump all around in 2 places and changing the mech inside the window face. Unless you want to slather on the bondo it is a bit of work,much more than cutting a bump into the ceiling...(easier to reverse as well) Maybe I am wrong and you would just be trimming the upper and or lower edge??
At any rate it is his pump but I would only do it as a last resort. How about a Gargoyle or other oval globe, are they not lower??
#51313
Fri Mar 23 2007 09:01 PM
Posts: 6,772 Likes: 1
Posts: 6,772 Likes: 1 |
I'm a purest so I say don't cut it....BUT.... I have a 5' tall Wayne 70. The ID tag is from a pump rebuilder that cut it down to make it appear more modern. Its unlikely that a Bennett 132 would have ever been modified like that but you never know.
What brand are you going to restore it in? Gulf used 12 1/2" globes as far back as the mid 1930's. Using a 12 1/2" globe just might get you the clearance you need.
#51314
Fri Mar 23 2007 09:56 PM
Posts: 2,443 |
T-Way is right on with this, you can shave a lot just in the globe body give it a look and take a measurement , You don't want to saw off part of your punp but if you can lower the globe body thats the way to go. I'm not an expert but I know T-Way has done it with great resultsand it looks great
Chris Holt
#51315
Sat Mar 24 2007 06:53 AM
Posts: 1,206 Likes: 13
Posts: 1,206 Likes: 13 |
I have to go with those that say "it's your pump do as you want" I would only cut the bottom section because it would be easy to raise it back up at a later date and if done correctly it would never hurt the value of the pump. I have run across alot of pumps that were cut down back in the good `ol days. I once had a Wayne 60 that was cut down 2 feet, the work was done many, many years ago. It was really a neat looking pump. I have a Tokheim 850 in the lower level of my house that I cut several inches off the bottom to get it to fit. You can't really tell. I have several original 850's and they line up at different heights. I again say do what makes you happy, to each his own. Tom.
#51316
Sat Mar 24 2007 08:28 AM
#51317
Wed Mar 28 2007 05:53 AM
Posts: 124 |
I am in the same boat. I have a wayne 60 I have finished restoring for my rec room down stairs. But it is too tall. I would no way in hell cut on this pump, so I will cut on my ceiling. I need about 5" also and it will be alot easier and cheaper to fix the drywall than to fix that pump!
My suggestion, don't do it!!!
#51318
Wed Mar 28 2007 02:52 PM
Posts: 269 |
I ran into the same problem with my gargoyle oil cabinet. I cut the sheetrock inbetween the rafters and raised it up about 4in. and framed it out with molding. You can see it in my last post. It was either that or cut the legs off the cabinet, and there was no way I was going to do that. So my 2 cents would be not to chop it up. Jim
#51319
Wed Mar 28 2007 07:27 PM
Posts: 120 |
Since it wont fit in your house,now would be the perfect time to build that service station replica in the back yard,since you already have the pump for the island.Hehe
