#516391 Mon Feb 24 2014 06:37 PM
Novaman Offline OP
Picked up this oil can cabinet the other day. It is missing the front and back doors, but should make a good display rack. Was hoping to get some info on this unit. It appears the company is Dispay Service Cabinet? Also, appears that a display of some sort may have been attached to the top. Any info and pictures would be appreciated. In the market for the lower side door also. Thanks,
Novaman #516394 Mon Feb 24 2014 06:48 PM
Sel-Oil made a lot of these cabinets. More photos would help.
here's one I have
Mike M. #516453 Mon Feb 24 2014 08:42 PM
Novaman Offline OP
Nice Cabinet. Having issues posting additional pictures. Emailed you addtional pictures. Thanks,
Novaman #516466 Mon Feb 24 2014 10:16 PM
Novaman Offline OP
Addtional photos.
Novaman #516477 Mon Feb 24 2014 11:11 PM
Not a Seloil (Modern Metal). Much smaller company, I have an ad from them somewhere.
http://petrolianacollectibles.com/modern%20metals.htm
Novaman #516479 Mon Feb 24 2014 11:11 PM
Clean the rest and see if its A SelOil
Mike M. #516503 Tue Feb 25 2014 07:50 AM
Novaman Offline OP
Any recommendations on how to clean off the paint layers without damaging the original paint on the tag?
Novaman #516513 Tue Feb 25 2014 08:21 AM
Easy. use a couple layers of tape on the tag.
Mike M. #516613 Tue Feb 25 2014 05:39 PM
This is a link to an older thread. This guy makes parts for oil cabinets and I'm pretty sure he can help you out
JimT #516639 Tue Feb 25 2014 07:04 PM
...I'm going to wager that the tag DOES say 'Modern Metal Products' when you get the overpaint off of it...some of the patent numbers match, and the type along the bottom edge seems to match the Sel-Oil tag shown...perhaps it was made before they named the product line 'Sel-Oil'?
gulfiend! #516648 Tue Feb 25 2014 07:33 PM
Novaman Offline OP
Thanks for the input. Haven't had a chance to take the overpaint off yet to determine. Jim T. could you repost the link to the thread, the link is not showing. Thanks
Novaman #516668 Tue Feb 25 2014 08:46 PM
Novaman Offline OP
Thanks Dick!
Novaman #516689 Wed Feb 26 2014 12:03 AM
My mistake, it a Seloil. It is a model 72 because it holds 72 cans.
A couple of pictures of it are shown on the web address above.
Jack Sim #516896 Wed Feb 26 2014 08:08 PM
Novaman Offline OP
Thanks Jack! Looks like a tent shaped advertsing sign was an option for the top of the model 72. Any close-up pictures on how it was attached?
Novaman #572762 Sun Oct 05 2014 10:30 PM
Dean,
Not sure if your still following this thread or still looking for info, but I have the same display cabinet. It is made by Modern Metal Products of Greensboro, NC. The door your missing lifts up then pulls out. There is a large bin which collects the leftover oil from the empty cans which are placed in the top door at an upside-down angle. The top of the cabinet does have a display. I believe it holds two flat advertisements. You may be missing the top bracket for the display. You place the advertisements in the top groove at an angle towards the two bumps on the top of the cabinet. Once in, you screw the top bracket tight with the long screw, which applies pressure and holds the advertisements in place. I just threw a box in there to show you the bracket in the up position. Hope this helps.
-Steve
Sent you a PM
Oil can display rack
top bracket
I am still reproducing the side access doors for the Seloil cabinets. Please PM me for information on these.
Novaman Offline OP
Thanks Steve, Your pictures are very helpful!
ABCTrip #573029 Tue Oct 07 2014 12:28 PM
Novaman Offline OP
PM Sent
Novaman #573228 Wed Oct 08 2014 01:15 PM
Dean, Here are some of the pictures you asked about. This is a pic of the top rail for the advertisement display. It is basically a 1/2" x 1/2" x 12 1/2" long U-channel placed in the center of a larger 3/4" wide x 1/2" tall x 17 1/2" long U-channel (probably spot welded together). This leaves a 1/8" groove for a sign on both sides.
Then there is a screw hole drilled through the center. The screw is 11 1/2" long with 1 1/2" of thread on the end. On the underside of the cabinet there is a washer and a wing nut, which is easily accessible through the top door on the side.
The sign would measure anywhere from 9 1/2" high to 10 1/2" high depending on how far you screw the wing nut down. And the sign would be approximately 17 1/2" wide.
Advertisement top rail
Now on to the door.... The door is flat. It measures 23 3/8" tall x 16 3/4" wide at the bottom (widest point on outside of radius) x 12" wide at the top (widest point on outside of radius). The tape measure appears to be 17", but its just an illusion from the way it sits.
You can see all of the channels on the back and side view pictures. Basically you lift the door up and pull the bottom out to remove it. There is a deep channel on the top in order to do this and to keep the door in place.
Once the door is on, there is a 17 1/2" bar that slides through the body of the cabinet and into the channel on the back. The bar is 17 1/2" long with the last 1/2" slightly bent, so it will not slide into the cabinet.
back
side
front
Ok, that was a little bit of homework, so if you do decide to restore it. I want to see some pictures. LOL. If you want to drive to Michigan you can buy mine too. Hope this helps. -Steve
Oh, one last thing, my serial number tag is the same as yours. It does not have "Sel-oil" printed at the top.
Novaman Offline OP
Steve, Thanks for taking the time to measure and post the pictures! Very helpful. Who knows, if I ever get to Michigan I may need to pick up its mate. smile
Novaman #574014 Sun Oct 12 2014 05:48 PM
No problem. If you need anything else, let me know.
One other thing I wanted to mention.... You could put a cool modern twist on this old cabinet. Run an extension cord up through the cabinet to the top. Then you can run two rounds of rope lighting under that lip at the top. It will light up the cabinet and your oil cans real nice, and you will not be able to see it at all, unless you bend down and look up at it.
-Steve
Novaman Offline OP
Thanks Steve, cool idea.
