#523655
Wed Mar 26 2014 06:59 PM
Posts: 210 |
Just picked up a Sky Chief globe from a collector that has had it for over 20 years. The seller purchased the globe as an original, but could not 100% confirm it's authenticity. The Capco housing is indeed original. Are there any markings to look for on the lens that would confirm whether they are original?
Thanks, Clayton
Posts: 2,194 |
shouldnt say reproduction or have a date at the bottom . If i remember correctly these do not have makers markings. The back of the lenses should tell the story the most.
If you can't tell if the lenses are real, how were you able to determine if the Capco body was real??
No markings on the lenses but if you provide a picture of the back of the lenses, we can probably tell you. The old lenses were made with a different process that left a different look to the backs of the lenses.
Posts: 210 |
The body is obviously old and has Capco markings near base.
CAPCO are still being made from Original Molds
Posts: 4,880 Likes: 50
Posts: 4,880 Likes: 50 |
If it can be put into words, what is it on the backs that should be looked for to help prove authenticity?
Posts: 2,460 Likes: 24
Posts: 2,460 Likes: 24 |
The back of original lenses were manufactured at a time when the process was less refined. Usually the finish is rough to the touch. Repro lenses have a smooth feel. Although this is not always 100% accurate, it has proven to be very helpful in determining correctness in most cases. Paul www.severngaspumps.com
Original capcos have 2 alignment humps on each half, while the repops will only have one per each half.
Posts: 1,369 Likes: 1
Posts: 1,369 Likes: 1 |
Here is a side by side shot of the Capco bodies... Reproduction Skychief lenses the green is a different shade than the originals most of the time. The green is a bit darker . At least on the 1984 dated repro I have. Also most repros have black around the T in the Texaco emblem.
1 member likes this:
Mamakat |
Iceman. You had seven replies to your request, but you never supplied any pictures???
Here is a side by side shot of the Capco bodies... Reproduction Skychief lenses the green is a different shade than the originals most of the time. The green is a bit darker . At least on the 1984 dated repro I have. Also most repros have black around the T in the Texaco emblem. Just so I understand this. The original will have tabs at both 3 & 9 o'clock on both sides and the repop only a tab at 9 o'clock? And of course the lenses will have this same configuration?
The repro lenses also have cut outs at 3 and 9 just like originals ....the repro bodies only have one notch per side. As seen in the photo....... I agree with Jack, Posting photos of the globe in question would help.
Posts: 210 |
Sorry guys, I have been out of town for a couple of days, I will post some pics of the globe very soon.
Posts: 210 |
Well this is interesting...There is actually NO tabs at all on this body. It also has an unusual "lip" near the bottom on one side. The inside of the lens feels a bit textured or rough. There is also a couple of tiny "pimples" in the glass. Hope this helps!
Posts: 2,738 Likes: 62
Posts: 2,738 Likes: 62 |
Lenses look original to me...... Darin
I agree with Darin, Lenses are real... Body also looks old but no notches?.
Posts: 210 |
Anyone seen a body with this "dip" at bottom before? Original or repop?
Looks like it got warm/hot. Is it the same on other side?
Looks like someone used a large wattage light bulb. Heat from the bulb caused the plastic to get soft and gravity caused it to sag like that.
Posts: 3,940 |
Also, original globes are a little rough on the back side, and repro's have decals.
Posts: 2,250 |
Posts: 1,906 Likes: 50
Posts: 1,906 Likes: 50 |
Isn't there a quote that kind of fits this and other situations that gas globe guy seems to get himself into?
I think it ends something like this "speak out and remove all doubt".
Posts: 5,105 Likes: 20
Posts: 5,105 Likes: 20 |
Noah, repops are fired frit like the originals.
Posts: 210 |
The "lip" is only on one side....
I agree w/ Dave about to big of bulb. I would replace instead of trying to straighten [place against wall for displaying a globe].
Posts: 210 |
After further inspection, I believe the dip was indeed caused by a hot light bulb. This was sitting on a Fry Mae West that I purchased last week, and from where the light socket was located, it placed the bulb very near base of globe bottom.
Thanks for all the help!
