Help needed ID'ing mystery mechanic's work station #559070
Thu Aug 07 2014 09:18 PM
Minneapolis
Alienbaby17 Offline OP
Minneapolis
I stopped at an estate sale last week. The estate belonged to a man that had been a Ford dealership mechanic since the mid 1950's.
I found lots of irresistible items while there and probably spent more money than I should have. But, I did get some good stuff so I guess it was OK.
The one thing I am most puzzled about is this item which was simply labeled, "work station" on the tag. When I showed up it was all full of old nuts, bolts and misc. Junk car parts. By the time I returned for it they had cleaned it out and I was actually a bit disappointed.
Here are some more details:
All metal construction with rounded corners. Approximately 42" wide, 30" tall and 20" deep. Despite looking like it is sitting flat on the ground it is actually mounted on four casters and has a small amount of ground clearance. The casters say "USA" on them. Two doors with full length piano hinges. Spot for lock in upper right door. Cabinets inside are separated and there is a small short step in the very back of each cabinet. Curious amount of wasted space on both sides between cabinet area exterior side walls. Has been brush painted blue but original color was white. Inside is smooth white. Outside is kind of a slightly textured speckle white. Had a thin (3/8") plywood top on it which is clearly not original. When top is off there is full access to the inside of the cabinet.
I've been racking my brain for almost a week trying to figure out what it is/was.
I assumed it was automotive given the previous owners career with Ford and many of the other vintage items he had saved from the dealership. I even thought it might have been the base cabinet for something like an old Gravo or Alemite mechanic's work station from the 1940's but I can't find any examples exactly like this. For all I know it's maybe not even automotive. I've searched many other areas from medical to kitchen but with no luck. I am really puzzled by the two brackets at the top back in each cabinet compartment. We had wondered if some part of a top might have dropped into those?
Hopefully someone here will recognize it and can fill me in.
Thanks in advance,
Jay
With top removed.
Paint removal in process.
And finally while doing a a Google image search of 'Alemite cabinet' I found this picture which looks kind of close. The link for the website the photo was taken from was dead so I have no other information or a confirmation the one in this photo was actually an Alemite.
Re: Help needed ID'ing mystery mechanic's work station [Re: Alienbaby17] #559075
Thu Aug 07 2014 09:37 PM
Santa Paula, Calif
Dick Bennett Offline
Santa Paula, Calif
Possibly at one time had 1 of these sitting on top
Re: Help needed ID'ing mystery mechanic's work station [Re: Dick Bennett] #559088
Thu Aug 07 2014 11:21 PM
Minneapolis
Minneapolis
What is that? It looks like the top for a soda fountain.
Re: Help needed ID'ing mystery mechanic's work station [Re: Alienbaby17] #559095
Fri Aug 08 2014 12:16 AM
Dave's Garage Offline
I have one slightly different then yours, but very similar. Mine is built of heavy gauge steel at least 3/16 inch thick. It has a crank handle that retracts a power cord. It has a built in power outlet and a clock.
I was told by an old timer; that, this is what bottom roller chests for tool boxes looked like back in the day.
Maybe others older then me can confirm this.
Dave GILL,
Re: Help needed ID'ing mystery mechanic's work station [Re: Alienbaby17] #559099
Fri Aug 08 2014 12:33 AM
Santa Paula, Calif
Santa Paula, Calif
ALEMITE OIL BAR approx 1928-1930
Re: Help needed ID'ing mystery mechanic's work station [Re: Dick Bennett] #559109
Fri Aug 08 2014 04:57 AM
Humble, TX
SKomatinsky Offline
SKomatinsky  Offline
Humble, TX
I own the cabinet which you found a picture of and it did have one of those oil bars on top. I am not sure if it was original or made locally by the station. The lube bar could be mounted on a cabinet or on a wall with lines going to oil tanks.
Re: Help needed ID'ing mystery mechanic's work station [Re: SKomatinsky] #559280
Fri Aug 08 2014 10:12 PM
Minneapolis
Minneapolis
Wow! Cool. Does yours have the white, textured, speckley exterior?
Any manufacturer brand on yours?
Great info so far guys. Thanks for all of the help.
Re: Help needed ID'ing mystery mechanic's work station [Re: Alienbaby17] #559464
Sat Aug 09 2014 11:50 PM
White Deer, Tx. USA
rd_signs Offline
rd_signs  Offline
White Deer, Tx. USA
Looks like the "GRACO" I have, except the top and side cabinets are missing.
R D
Re: Help needed ID'ing mystery mechanic's work station [Re: rd_signs] #559465
Sun Aug 10 2014 12:49 AM
Minneapolis
Minneapolis
Hmmm...now that you mention it there are three holes on each side near the back running vertically and spaced pretty evenly. I assumed something was mounted to each side.
I will have to research GRACO pretty hard now.
Here is a picture from earlier this evening. I finally got 98% of the old blue paint off of it,
Re: Help needed ID'ing mystery mechanic's work station [Re: Alienbaby17] #559736
Mon Aug 11 2014 05:07 AM
Illinois
Cold Pizza Online content
Cold Pizza  Online Content
Illinois
I don't think GRACO mounted the pull handles horizontally.
I've only seen vertically so far.
Re: Help needed ID'ing mystery mechanic's work station [Re: Cold Pizza] #559941
Mon Aug 11 2014 06:47 PM
Midwest
Signs&Neons Offline
Signs&Neons  Offline
Midwest
I've cross referenced your picture against photos I have of at least five different brands of work benches and can't find a good match. The horizontal handles are unique as mentioned above. The brackets on back wall are also confusing! Not sure what it is? Keep us posted if you figure it out please.
Re: Help needed ID'ing mystery mechanic's work station [Re: Signs&Neons] #559962
Mon Aug 11 2014 07:59 PM
Minneapolis
Minneapolis
Thanks again for the time and effort fellas. I do appreciate your expertise and experience in this matter.
Yes, the horizontal handles and the fact that the doors meet in the middle without a panel in between combined with the full length piano hinges all seem to be unique characteristics to this cabinet.
The last picture in my first post (incidentally apparently owned by SKomatinsky on here) is the closest one I could find. It has the horizontal door handles and both doors meet in the middle like mine. I believe I found his while searching "Alemite cabinet" although I don't know that it was ever for sure confirmed to be that manufacturer and I haven't seen another like it by that brand.
Weird, but I'm no longer losing sleep over it. I've almost resolved to live with the mystery. If I do ever find a definite answer I will let you all know.
Thanks.
Re: Help needed ID'ing mystery mechanic's work station [Re: Alienbaby17] #578988
Fri Nov 07 2014 09:44 PM
hays, kansas
johnnyreb Offline
johnnyreb  Offline
hays, kansas
it's from an old bear alignment machine. i have a pic of one on my cell phone that i'm looking at buying. i'd post the pic on here, but i'm technologically retarded!:) but it is IDENTICAL to the one in my pic. the alignment "eyes" were ina box that was mounted on top. The same manufacturer could have made it for other products too i suppose...
Re: Help needed ID'ing mystery mechanic's work station [Re: johnnyreb] #682969
Wed Mar 22 2017 12:11 PM
Minneapolis
Minneapolis
I know it's been about 2.5 years but I still don't have a 100% positive identification of this cabinet. (At least one with photos to support it.)
After a long winter away from the garage I'm finally getting back out there and doing some reorganizing. I've been looking at this cabinet again and wanted to just bump this thread back up to the top in the hopes some fresh eyes might read this and have some help for me.
Thanks,
Jay
Re: Help needed ID'ing mystery mechanic's work station [Re: Alienbaby17] #682972
Wed Mar 22 2017 12:27 PM
Amarillo, TX
Unicorn1 Offline
Unicorn1  Offline
Amarillo, TX
I can't see any of the pics, can you post one? This is the Lincoln Engineering I picked up two weeks ago.
Page Time: 0.030s Queries: 15 (0.007s) Memory: 1.9258 MB (Peak: 2.0866 MB) Zlib disabled. Server Time: 2019-01-23 00:11:25 UTC
