Page 1 of 7 1 2 3 4 5 6 7
A novice rebuilds a Fry 117. #561820
Tue Aug 19 2014 06:29 AM
Mississippi
F
F40LM Offline OP
F40LM  Offline OP
F
Mississippi
Hello guys,
After many months of planning my house build is finally in full swing. Since the Fry 117 I have will serve as one of the lights on the deck I have started the process of bringing it back to at least some of it's prior glory.
I am a complete novice at doing gas pumps, but I know enough from doing car wrenching to be dangerous.
If you would like to add CONSTRUCTIVE advice please do so, non-constrcutive advice shall be ignored.
This will not be a full blown rebuild, I do not plan to take it back to 100% perfection. This will be a well intentioned but cost effective rebuild.
Do not misunderstand, I think old gas pumps are very cool. But they are gas pumps, not holy relics.
Michael
Re: A novice rebuilds a Fry 117. [Re: F40LM] #561825
Tue Aug 19 2014 07:16 AM
MICHIGAN
Steven C. Offline
Steven C.  Offline
MICHIGAN
One word:
Rustoration.
Good luck and I can't wait to see the result.
Re: A novice rebuilds a Fry 117. [Re: F40LM] #561828
Tue Aug 19 2014 07:48 AM
Mississippi
F
F40LM Offline OP
F40LM  Offline OP
F
Mississippi
The glass was removed last year. So this weekend I removed the number rods from the top of the pump.
Here are some 'before and after' pics. Using CLR on the numbers, put the 4" grinder with a steel brush cone on the rods.
Re: A novice rebuilds a Fry 117. [Re: Steven C.] #561832
Tue Aug 19 2014 07:58 AM
Mississippi
F
F40LM Offline OP
F40LM  Offline OP
F
Mississippi
Originally Posted By: Steve C.
One word:
Rustoration.
Thanks Steve.
Sadly the pump was face down in a ditch for MANY years. The front is in worse shape than the back. I need to decide if I will try to fill the rust dimples in before prime and paint. The wife says I should leave it, will give it more of a authentic look.
Re: A novice rebuilds a Fry 117. [Re: F40LM] #561833
Tue Aug 19 2014 07:59 AM
Hays, Kansas
bsplichal95 Offline
bsplichal95  Offline
Hays, Kansas
Honestly I'd leave it, and go for a Rustoration. It'll look good I'm sure when its done!
Re: A novice rebuilds a Fry 117. [Re: bsplichal95] #561835
Tue Aug 19 2014 08:08 AM
MICHIGAN
Steven C. Offline
Steven C.  Offline
MICHIGAN
Check these out and get in touch with Matt. Hopefully, he can give you a couple tips.
I look very forward to your results as I hope to also be doing this in the next year or so and I'll be coming into it with the same experience, none!
BTW, it looks like that pump has great bones. Very nice example it appears!!
http://www.oldgas.com/forum/ubbthreads.p...true#Post530199
http://www.oldgas.com/forum/ubbthreads.p...true#Post525717
Re: A novice rebuilds a Fry 117. [Re: bsplichal95] #561839
Tue Aug 19 2014 08:14 AM
Mississippi
F
F40LM Offline OP
F40LM  Offline OP
F
Mississippi
That's what I will probably do.
The rods can be seen (barely) in the upper right corner of this pic. The wire brush cup did a great job cleaning them up.
The ten long bolts that circle the outside of the glass are toast though. I hope to find them local this week. But if anyone has a source for them online cheap let me know. Worse comes to worse, will add them to the 'Vics66' list of things to buy.
Re: A novice rebuilds a Fry 117. [Re: F40LM] #561897
Tue Aug 19 2014 02:22 PM
Louisville, Ohio
Goober's Station Offline
Louisville, Ohio
I can't believe there's not more rot out, you got lucky, its in pretty decent condition still. They are right, try to keep it as original as you can. Find an old brass nozzle and old hose for it. Just try & wire it for a globe which sits in the cup on top and your good. Good luck Bud.
Goober
Re: A novice rebuilds a Fry 117. [Re: F40LM] #561914
Tue Aug 19 2014 03:44 PM
Cataula, Georgia, USA
Catauladave Offline
Catauladave  Offline
Do not under any circumstances try to remove the rings from the cylinder. Wire brush, steel wool, Ospho and paint them. Tape off the glass.
Dave
Dave Jones
It's All Just Stuff
Re: A novice rebuilds a Fry 117. [Re: Catauladave] #561924
Tue Aug 19 2014 05:22 PM
Mississippi
F
F40LM Offline OP
F40LM  Offline OP
F
Mississippi
Dave
No worries Dave, I remember that was the first piece of advice I got about the cylinder. It was removed with rings, just dusted off, and wrapped in about 4 layers of bubble wrap for storage. Will get it out soon for the steel wool etc cleaning.
Re: A novice rebuilds a Fry 117. [Re: Goober's Station] #561925
Tue Aug 19 2014 05:25 PM
Mississippi
F
F40LM Offline OP
F40LM  Offline OP
F
Mississippi
Goober
Would love to find an old brass nozzle and hose, just afraid if I do it will be outside my budget. But going to give it a good try. If I still don't have one by the completion I have a hose and semi-modern nozzle that can go on it as a temp.
Re: A novice rebuilds a Fry 117. [Re: F40LM] #561935
Tue Aug 19 2014 06:07 PM
Mississippi
F
F40LM Offline OP
F40LM  Offline OP
F
Mississippi
So after checking with the guys at Ace Bolt and Screw today I decided I had three options on the exterior cylinder bolts:
1. buy them from a online supplier, about $65 to $70 for 10 with shipping
2. buy threaded rods from lowes or home depot, much cheaper (about $16 with 20 nuts), but wouldn't look the same.
3. buy cold roll steel and make my own rods
So being a self-helper and a little hard-headed I of course decided on number 3.
Picked up 5 48" rods from Lowes for $20.65 and 10 1/4-20 nuts (same size and thread count as original rods) for $1.40. Will swing by Harbour Freight for a basic tap and die set for $10. Already have an idea how to round the top of the rods...will just have to see how these turn out. The good news is that the original bolts are a little under 24" each, so will have some extra length to try a couple techniques to round the tops.
Re: A novice rebuilds a Fry 117. [Re: F40LM] #561940
Tue Aug 19 2014 06:18 PM
Santa Paula, Calif
Dick Bennett Offline
Santa Paula, Calif
Fun to watch Grasshoppers save $!
Re: A novice rebuilds a Fry 117. [Re: F40LM] #561946
Tue Aug 19 2014 06:23 PM
Warsaw,Il.62379
oilmanpat Offline
oilmanpat  Offline
Warsaw,Il.62379
Use lots of oil. You may have to replace the die with a better quality one, like from Ace hardware or somewhere of that caliber. If you have never used a die before, once you get it started straight go about a half turn at a time and back up each time to break the chips.
Re: A novice rebuilds a Fry 117. [Re: Dick Bennett] #561949
Tue Aug 19 2014 06:27 PM
Dave's Garage Offline
Do you have a mig welder? I would cut the heads off about an inch down off of the original rods and splice them onto the new rods. Taper the piece you cut off and taper the end on the new rod. Weld the two pieces together. Then carefully grind and finish the rod shank or turn on a lathe.
Dave GILL,
Page Time: 0.029s Queries: 20 (0.008s) Memory: 1.9285 MB (Peak: 2.0887 MB) Zlib disabled. Server Time: 2018-07-22 05:19:17 UTC
