#576206
Thu Oct 23 2014 10:32 AM
Posts: 3,423 Likes: 19
Posts: 3,423 Likes: 19 |
I picked up a decent United Motors Service 48" porcelain neon skin. It is the version that has 6 holes for neon because the tubing all came out of the face. (unlike others with 2-holes in which the outside neon ring would have originally surrounded the can & not border the sign)
My question... I've never had a neon completely redone, what can a person expect to pay for a sign like this to be redone & have a can made, tubing redone, insulators, transformers, etc?
And along with that, does anyone have a good contact for that kind of work in around central IL?
not my sign - but same version
Posts: 1,154 Likes: 1
Posts: 1,154 Likes: 1 |
ask john mancino he had one of these done for a cust while I was at his show this year I would say $800-1000 all said and done but I would do a lot of the work my self just based on othe projects ive done for myself and other people
collect jenney, independent oil co. , underhay oil co , valora motor oil and other massachusetts brands.
by the way nice sign its on my list of things to own
Posts: 986 Likes: 37
Posts: 986 Likes: 37 |
Time they build the can, add transformers, glass, wire, insulators, etc., $1200+.
Posts: 1,005 |
Seeking Knowledge and a Good Deal. Always looking for neon signs and skins , Flying A ,& Wayne 60s.
thanks everyone... debating on trying to tackle making the can myself. havent done too much metal fab in my life, so there will be a learning curve.
I had a metal shop make me a can, it comes out a lot better than a sign shop had all the seams welded then grinded came out amazing gonna have it powdercoated in wrinckle finish here is a pic of the can I will post a pic when I get it back
I would make the can myself for sure if it was rectangular... as I think all I would need is a band saw & use someones brake. but since the can is oval shaped, its not quite as simple unfortunately.
Posts: 1,348 Likes: 61
Posts: 1,348 Likes: 61 |
Hi Bryce, we just did a round can (my avatar), we don't have a band saw or brake and it came out nice. Pretty easy to use a piece of plywood as a temporary jig to hold the supports and then wrap sheet metal in a circle (or oval) around the supports. You,ll probably want to flange the sheet metal, you'll need to make triangle cuts in the flange so you can bend it in a circle, no biggie.
Posts: 151 |
You could just give me the sign and all your troubles would be over
Posts: 1,145 Likes: 1
Posts: 1,145 Likes: 1 |
do you guys know what gauge is good for the can ?? I have a sheet metal shop but have never made a can before . Have a 9' Pontiac can that needs one . Thinking 20 gauge ???
Follow the Red Indian Trail
Posts: 1,516 |
Posts: 5,980 Likes: 24
Posts: 5,980 Likes: 24 |
16-18 at least, Hang mine from the back with j mounts that attach to the metal. Hangs well and strong.
Posts: 1,005 |
I do mine in 080 routable aluminum then wire weld seams. Very strong can. Craig I do like the j mount idea.
