#591232
Thu Jan 08 2015 10:05 PM
Posts: 41 |
Getting ready to paint the skins for my pump. One of the doors has some waves in the sheet metal that would take a lot of body filler, more than one should use. I am planning a 2 tone paint job, Red and White. What I would like to know is which would be the best to color for the door. I know a dark color will hid some imperfections so I was thinking about the Doors Red and the body White. Anyone have a suggestion other that buying a new door skin.
Posts: 19,471 Likes: 1022
Posts: 19,471 Likes: 1022 |
I know a dark color will hid some imperfections IMO- the opposite, a lighter color will hide the imperfections...
Personally, I like to use darker colors on the body and the lighter color on the doors.
Posts: 1,841 |
Yeah the lighter colors hide the bad stuff.
Posts: 41 |
Thanks, I guess I had it wrong on the color. Its nice to be able to ask people who know and have done what you are trying.
What make/ model pump are you working on?
Posts: 102 |
Dark colors will definitely show more imperfection.So I would highly recommend using colors such as white expecially if metal work not great. May be possible use large decal, sign etc if possible.
Posts: 2,460 Likes: 24
Posts: 2,460 Likes: 24 |
All of the above answers are correct. It might be advantageous to take a little more time to correct the imperfections on the door? I find that I "always" see the bad body work. If it takes a gallon of mud to correct the door, so be it. I think you'll be much happier in the future, instead of being disturbed by the final finish? Paul www.severngaspumps.com
Posts: 41 |
Posts: 41 |
Paul, You are right. I went back and started filling in and it does "feel better" knowing that I am doing as good as I can. In my old age I guess I am starting to get the attitude faster not better.
Posts: 128 |
I just restored a wayne 100 that had some filler in the doors and isn't noticeable at all. I had the doors painted white which helped also. Hope this helps your decision, Tim
Posts: 1,351 Likes: 62
Posts: 1,351 Likes: 62 |
Black is the worst color for hiding bad body work, light is the best. You see almost every imperfection on gloss black. It's not a small difference either it is pretty dramatic, although I agree with gasman, if your looking you can see bad bodywork on any color, but with dark colors it just jumps out at you!
Posts: 142 |
Buy a quart of Slick Sand through your local auto paint supplier or a online place like Eastwood. Slick Sand is a HEAVY primer/filler. Apply as per the tech sheet. Only spray it on the bad areas, then block sand it smooth. This will help to level out the waves. Once its to your liking, prime again with a normal primer or sealer, then your favorite paint.
-Dave- Collects Dino era Sinclair & Mopar items
Posts: 41 |
Did a lot of sanding and filler. Now going to epoxy primer and a single stage auto paint. Doors white remainder of the body in bright red Mobil globe and decal on doors. Just waiting till it warms up more outside so my heater does not have run constantly. Forecast looking better late next week. Would like to THANK everybody for your help and suggestions on my first pump.
Posts: 2,995 Likes: 110
Posts: 2,995 Likes: 110 |
Post a picture when it's done please. Would like to see it.
