#592905 Sun Jan 18 2015 08:32 PM
Hi
Can some one confirm what model of Wayne pump this is ? Is it a 505 ?
This is all new to me.
Thank you
Jeff
Sarman47 #592911 Sun Jan 18 2015 08:38 PM
Yep, Wayne 505.
Rabbitman #592921 Sun Jan 18 2015 09:33 PM
Correct, the 505 is described as a "Extended Hose", the 500 was a "Concealed Hose."
For more information see: http://petrolianacollectibles.com/wayne%20500-505-1950.htm
But if I were you I wouldn't lay the pump down on the ground, they scratch easily.
Jack Sim #592924 Sun Jan 18 2015 10:03 PM
Appears to be a 605 to me....faceplates and one sight glass?
keithia #592942 Mon Jan 19 2015 05:56 AM
I agree with Keith, it looks like a Wayne 605
Hardy's Garage #592962 Mon Jan 19 2015 07:41 AM
The 605 has one sight glass down on the side opposite the nozzle, not two in the top like the 505. Also has the auto reset handle for the VR on the same side as the nozzle, not the manual crank on the opposite side. At least that's the way mine is. All models came with or without ad glass...GB
Hardy's Garage #592963 Mon Jan 19 2015 07:41 AM
There is a sight glass on the other side , if this helps identify which model of pump.
Thank everybody for their help.
Jeff
Sarman47 #592968 Mon Jan 19 2015 07:56 AM
Here is a 500 that I just finished for a customer. It was designed the same time as the 505 but had the retractable hose as Jack said earlier. The 605 was a later model version of the same design. I just finished this pump for a museum and did a lot of research on them. I was able to get a nos users manual and a bunch of original advertising from Jack for the project that showed all the model information on the 500 series pumps and included the info in a notebook for them. They wanted the pump restored to look exactly as the advertising portrayed it, hence the special ad glass with the model of the pump instead of a brand. The art exhibit that this pump will be a part of is commemorating the designer of the pump. He designed numerous industrial and art objects back in the early fifties and sixties and the pump is only one of several objects he designed in the exhibit. I am supposed to get more information from them on the particulars of the exhibit and when I do I plan to post a little story on the whole project....
Rabbitman #593017 Mon Jan 19 2015 12:06 PM
Hi Gary
Beautiful pump, from what I can see in your photo you have done an excellent job.
I think by looking at your pump and referencing the pictures on Jacks site (plan on buying a Wayne manual from Jack), it is a 505 with the two sight glass in the top and the manual crank on the opposite side. The only difference I see, is as Jack mentioned, mine has the set up for the retractable cable that attaches on the hose as opposed to your 500 Gary, with the "Concealed Hose”.
I have learned a lot today.
Thank you to all for your help.
Jeff
Sarman47 #593036 Mon Jan 19 2015 02:16 PM
One of the best gas pumps ever made.
Collecting Vintage Sunoco
Cold Pizza #593080 Mon Jan 19 2015 06:25 PM
For sure a 605. I don't know why but I love the 505 and 605 pumps
Thanks, Phil
Cold Pizza #593081 Mon Jan 19 2015 06:25 PM
1
It looks like a 505 with 605 faces. The 505's that I have seen uses the flat face and uses a computer and the number wheels are set "level". The 605's that I have seen uses the faces that point upward and the wheels on the computer face slightly upward as well to match the contour of he face. Brady
1PetroFan #593143 Tue Jan 20 2015 05:36 AM
Noticed the difference from some pictures I researched today. My two theories are 1 it is a combination of the two pumps to make one. Or 2 it could be a transitional pump or converted to the 605 face and pump during a repair / update to the 505.
Will have to look at maybe converting it back to the proper face and computer.
Do you think that would be money well spent or leave as is ?
Thank you for the input and information.
Jeff
Sarman47 #593188 Tue Jan 20 2015 10:06 AM
1
I wouldn't touch it, it looks great the way it is. Brady
1PetroFan #593457 Wed Jan 21 2015 05:04 PM
Thank you Brady
I think I will leave as is for now and enjoy.
Jeff
Rabbitman #593696 Thu Jan 22 2015 07:56 PM
Gary, On this Wayne 500 that you restored where did you get the rubber trim that goes between the top ad glass metal front and the top of the main body?
