#595120
Thu Jan 29 2015 05:03 PM
Posts: 251 |
I am looking for advice on hauling a Tokheim visible with the original cylinder. We are needing pointers on any way that may prevent damage to the glass. This is the first visible we have found with the cylinder intact. Any ideas would be greatly appreciated. I have searched and haven't really found much, but may be putting in the wrong search words. Thank you in advance for any help in getting this home in one piece.
Posts: 1,705 |
We have always hauled them laying down on car tires which act as shock absorbers and tied down to prevent movement. The tires are placed under "hard" sections and no stress is placed on the cylinder. Be careful and use common sense and you should be OK. Dave
Posts: 2,004 Likes: 58
Posts: 2,004 Likes: 58 |
I have no personal knowledge but a "funny" sight was seeing the Hops bring their load of pumps laying flat on old mattresses. Best rested pumps in Iowa. Lonnie said to me that he gets laughs and more importantly no damage!
Posts: 4,005 Likes: 7
Posts: 4,005 Likes: 7 |
Well said above, either way I have used.
Posts: 244 Likes: 49
Posts: 244 Likes: 49 |
Lay it down with the tire placed just below the cylinder area so the pump rides on the cast piece below the glass and cylinder rods. And yes as Dave said tie it down so it doesn't shift off the tire. Taken many coast to coast and never had a problem.
Good Luck
Posts: 1,055 |
I've always used an old couch cushion under the cylinder and have never lost one.
Posts: 131 |
I used the tire method described in above posts, drove home 180 miles, no problems.
Ed from South Jersey
Here is how to transport gas pumps. Jack Sim
Posts: 4,293 Likes: 27
Posts: 4,293 Likes: 27 |
Every visible I have ever had I have laid down on a tire on a trailer. They ride really well.
Posts: 733 Likes: 1
Posts: 733 Likes: 1 |
i sold 2 restored pumps and ask on best way to transport---we warp them in alot of moving blankets-and then use sleeping bags under the cylinder and just below laying down and tie them off from moving they made it with no problems
un restored we transported a couple--the way i did it using 4x4 x 8 ft post in front of each pump --then with nail gun cross way use short 2x4 to pinch them in off --tied them off -- standing up- sight to see going down the road
looking for spanish gas signs
Posts: 251 |
Thanks for all the excellent advice guys. Definately a new use for old matresses. Never thought id be needing to keep one, but my mind is changed. The tire seems to be the winner though. I really appreciate all of the input and will let everyone know how we make out with it.
Posts: 1,705 |
Here is the last Fry that I helped a friend move. It was a 17 with a 10 gal Wayne conversion. He tied it down after the photo and got it home safely. Good luck...Dave
Posts: 5,980 Likes: 24
Posts: 5,980 Likes: 24 |
Have done the hauling all three ways, Standing up in our truck because of the rack we have is the easy way for me because I do not need anyones help. IT also squeezes them so they do not move. Can't lift a heavy one when laying down anymore. The tire one is great also, but mattress work great because you can haul all sorts of things and they move. Trailers do not have much shock absorbing to them thus bumper ride, where the truck has the shocks and new ones are like cars.
Posts: 2,085 Likes: 11
Posts: 2,085 Likes: 11 |
Do a goggle search for Severngaspumps. On main page under other you will see the word blog. click on it and go to second page. You will see a fry crated. Little extreme if your not going far,but what is the cost of a glass cylinder. I hauled this pump laying down 700 miles.
Posts: 572 Likes: 1
Posts: 572 Likes: 1 |
another vote for tires here! I have moved a couple dozen visibles on tires (leaving the glass in the pump) with no issues.
Always looking for Red Indian Tins, McColl Frontenac, McColl Bros., Buffalo (prarie cities oil co), Stellarene and other western canadian tins.
Posts: 2,459 Likes: 24
Posts: 2,459 Likes: 24 |
I have hauled an awful lot of visibles. The only thing I do, with unrestored units, is lay them down and chock the base and top just below the cylinder with wood blocks screwed to the trailer floor. No need to strap them down unless you are going off roading as gravity will keep them in place. I've moved stuff from Arizona back to the shop in this manner with no issues. If you will observe, in most cases, the cylinder does not come into contact with the base? If it does, then simply place blankets below the lower cylinder mount area to lift the whole end and eliminate a problem. I find that the closer to the trailer the pump is, the less opportunity for damage. As Loyd pointed out above, when they are restored, I get very creative to protect them. Paul www.severngaspumps.com
Posts: 2,702 |
What Dave Jones said, "Common Sense" and you'll be fine.
Posts: 3,184 Likes: 4
Posts: 3,184 Likes: 4 |
If you are going to continue to be serious about hauling pumps of any kind, invest in a proper trailer design. You can use ANY trailer, just set it up with high sides and stand your pumps up. You will never damage a pump and you can haul a lot more at one time. Cover up good cylinders. A single road stone can be a very expensive lesson. I know someone that happened to.
Posts: 1,705 |
Nice setup. You guys have got it going on "rasslin" with those visibles. Back in the day I could manhandle one, but that was the day before yesterday. Keep up the good work ! Dave
