#59843
Thu Jan 04 2007 08:50 PM
Posts: 1,479 |
Here is the Hayes... I have found some VERY COOL info by searching this site...
http://www.google.com/patents?vid=USPAT1711783&id=fShUAAAAEBAJ&pg=PP1&dq=wichita+hayes+pump&as_drrb_ap=q&as_minm_ap=1&as_miny_ap=2007&as_maxm_ap=1&as_maxy_ap=2007&as_drrb_is=b&as_m
Travis E. Towle Topeka, Kansas
785-357-1004
[This message has been edited by travis_towle (edited 01-05-2007).]
#59844
Thu Jan 04 2007 09:05 PM
Posts: 1,479 |
FORGET the hayes - do a search for
LIQUID DISPENSING APPARATUS
Man - I always woundered what some of the things inside these pumps did! I just found the Tokheim 36 pump drawings and prints.
Very cool
Travis E. Towle Topeka Kansas
785-357-1004
#59845
Fri Jan 05 2007 01:00 PM
Posts: 1,479 |
Here is the Greek Column pump...
Very cool what all it did! Heck I have found all kinds of info about things on these pumps that I always woundered what they did. I was looking at the Fry SpeedBoys and they were pretty hi-tech for there time.
http://www.google.com/patents?vid=USPAT1674940&id=gHZ5AAAAEBAJ&pg=PP1&dq=DISPENSING+APPARATUS+OF+THE+VISIBLE+TYPE&num=100#PPP1,M1
785-357-1004
#59846
Fri Jan 05 2007 01:42 PM
Posts: 1,479 |
This kinda looks like the Mae West - kinda cool... http://www.google.com/patents?vid=USPAT1...num=100#PPP1,M1 But so does this: http://www.google.com/patents?vid=USPAT1715539&id=JoZeAAAAEBAJ&dq=DISPENSING+APPARATUS+OF+THE+VISIBLE+TYPE&num=100&jtp=1#PPP1,M1 Travis E. Towle Topeka, Kansas 785-357-1004 [This message has been edited by travis_towle (edited 01-05-2007).]
#59847
Fri Jan 05 2007 01:59 PM
Posts: 1,479 |
This is kinda cool too - the drawings for the Tokheim 39 tall - look at their original plans for a car window meter that the drivers could look at. Can you just think how many pumps would have been tore up by cars driving off with that attached? >> Not all ideas are great huh? http://www.google.com/patents?vid=USPAT2348769&id=Em5NAAAAEBAJ&pg=PA16-IA1&dq=DISPENSING+APPARATUS+OF+THE+VISIBLE+TYPE&num=100#PPA16-IA1,M1
785-357-1004
#59848
Fri Jan 05 2007 04:17 PM
You should see the inside of an 850 Tok. with original guts........chain drive???? The meter was the Volumeter it looked like an engine on the inside, pistons , rocker arms and adjustable valves. Joe
#59849
Fri Jan 05 2007 04:37 PM
Posts: 1,479 |
I just found the prints for that - it is strange.
I also find it strange and new to me that the Wayne company did the majoroity of the desings for ALL of the other companies. Most Frys and Bowser pumps as well as the tokheims were designed under commission of Wayne.
785-357-1004
#59850
Fri Jan 05 2007 06:34 PM
I restored the insides of a 950-A, for a freind to use on his farm. I used the origional tok. pumping unit, a later 898 meter and restored the clock . It pumped 9 1/2 GPM, it was something to see that dinosaur breathing again. I got chills.... Joe
#59851
Fri Jan 05 2007 09:41 PM
I have the original sales brochure for the chain diven 850, it will be pictured in my Gas Pump book revision. Jack Sim Author, Gas Pump Identificaiton book and Air Meter Identificaion book
#59852
Sat Jan 06 2007 01:44 PM
Posts: 2,772 Likes: 3
Posts: 2,772 Likes: 3 |
Jack, Still waiting to hear from you on a maintenance manual for an 850.
Larry
#59853
Sat Jan 06 2007 09:38 PM
Have you found anything for the first Veeder-Root or gasoline pump computer???? I would like to know what the actual # the early computers names were. I know Veeder Root had the 2002 e, 2000, 56, 58, etc...I don't know much about the old ones.....anyone got any lit.? Thanks Joe
#59854
Sat Jan 06 2007 09:49 PM
Posts: 1,479 |
YES I did find the computer patents both standard and clock works styles - lots of different ideas on them - but I can not remember what there numbers were - if I run into them again I will post them here.
I have found patents for almost everything on the pumps down to the gallon indicaters.
785-357-1004
#59855
Sat Jan 06 2007 09:53 PM
Posts: 1,479 |
Here is one that was made for Bowser -
Scroll down for the computer patent... http://www.google.com/patents?vid=USPAT2199480&id=4gJSAAAAEBAJ&dq=register+or+clock+assembly+of+the+computing+type&num=100&jtp=1#PPA5,M1
785-357-1004
#59856
Sat Jan 06 2007 09:57 PM
Posts: 1,479 |
Hey Joe
Search in the lines of this
register or clock assembly of the computing type
Try to very the details and add the names of the pump compaines and then the date ranges they would have been made - 1928-1940 era.
Good Luck - show me what you find! If you come across any Bowser C-110 styles or Fry Speedboy prints let me know.
785-357-1004
#59857
Sat Jan 06 2007 10:51 PM
I had a feeling about this......guess who has the patent for the odometer...V/R
I bet they have the one for the air meter counter as well.
joe
[This message has been edited by jkyocom (edited 01-07-2007).]
