Page 1 of 3 1 2 3
Eco 97 (1948) restoration #683242
Sun Mar 26 2017 02:13 PM
Dayton
Mockingbird812 Offline OP
Dayton
I got this meter a couple years ago and finally had time to break it down and put it back to new. Although it looks rough on the outside the internals were really in good shape with minimal corrosion (except the insides of the lower cast plenum that houses the diaphragm (pix to follow). Jack Sim has provided the necessary pieces to make it operate and look new again. His book has been invaluable. Thanks Jack (and Cindy too!)
Before:
Sam
Re: Eco 97 (1948) restoration [Re: Mockingbird812] #683245
Sun Mar 26 2017 02:41 PM
Dayton
Dayton
This is a 1948 model according to Jack and is the 2nd year for this model (Eco 97). There are a few features on this model (according to Jack) that are not found on later models. I'll point them out as I go on.
Here are the guts broken down for mechanical and cosmetic restoration (notice the original brass bell after a bit of elbow grease and quad ought steel wool):
Sam
Re: Eco 97 (1948) restoration [Re: Mockingbird812] #683246
Sun Mar 26 2017 02:54 PM
Dayton
Dayton
This pin is located at the top of the mechanism box and holds the top geared wheel in place. It is wire-tied to a small boss near it. I believe this pin went away in later models.
Sam
Re: Eco 97 (1948) restoration [Re: Mockingbird812] #683247
Sun Mar 26 2017 02:58 PM
Dayton
Dayton
This copper "drain tube" which is behind the main valve is supposedly not found on new versions of the tireflators....
Sam
Re: Eco 97 (1948) restoration [Re: Mockingbird812] #683248
Sun Mar 26 2017 03:05 PM
Dayton
Dayton
This is a "felt oiler" at the end of the tireflator spring that Jack has stated were removed from future designs or during maintenance....
Sam
Re: Eco 97 (1948) restoration [Re: Mockingbird812] #683252
Sun Mar 26 2017 04:45 PM
Dayton
Dayton
Here is what was found in the diaphragm plenum. I'm thinking that the system missed a daily moisture purge, or two over the years! I used a strong concentration of muriatic acid to eradicate the rust on the inside of the cast iron diaphragm housing......
Sam
Re: Eco 97 (1948) restoration [Re: Mockingbird812] #683254
Sun Mar 26 2017 05:05 PM
Dayton
Dayton
Parts ready for reassembly following mechanical and cosmetic restoration....
I wanted to use the original face as the reproduction faces have a different message. The few "warts" on the face are acceptable to me....
Sam
Re: Eco 97 (1948) restoration [Re: Mockingbird812] #683262
Sun Mar 26 2017 05:44 PM
Dayton
Dayton
Insides getting put back together. I'm waiting on frame, shroud pieces, and base mount at the powder coaters for final assembly....
Sam
Re: Eco 97 (1948) restoration [Re: Mockingbird812] #683265
Sun Mar 26 2017 06:20 PM
Dayton
Dayton
https://youtu.be/e3lAMWORJsY
Not so good at embedding a video, but this link is a quick test to ensure the systems work. Surprisingly it was only off by one psi prior to calibration.
Sam
Re: Eco 97 (1948) restoration [Re: Mockingbird812] #683272
Sun Mar 26 2017 07:03 PM
Hays, Kansas
bsplichal95 Offline
bsplichal95  Offline
Hays, Kansas
Looks really good!
Re: Eco 97 (1948) restoration [Re: Mockingbird812] #683279
Sun Mar 26 2017 07:42 PM
Midland, Michigan
BrianH Offline
BrianH  Offline
Midland, Michigan
Nice progress update. The restoration looks like a first-class job. Make sure to post pics when the bodywork gets back from the powder coating place.
BrianH
Re: Eco 97 (1948) restoration [Re: Mockingbird812] #683280
Sun Mar 26 2017 07:46 PM
Plano TX
SandPCollector Online content
SandPCollector  Online Content
Plano TX
Neat to see the before and after pictures. Really nice workmanship.
Regards, Jim
and the plastic coin banks both made by AVSCO.
Re: Eco 97 (1948) restoration [Re: Mockingbird812] #683285
Sun Mar 26 2017 08:12 PM
Dave's Garage Offline
Nice work, you went the extra mile.
Dave GILL,
Re: Eco 97 (1948) restoration [Re: Mockingbird812] #683299
Sun Mar 26 2017 11:27 PM
Montana
hotrodfun1 Offline
hotrodfun1  Offline
Montana
Looks great.
Re: Eco 97 (1948) restoration [Re: hotrodfun1] #683318
Mon Mar 27 2017 07:02 AM
Dayton
Dayton
Thanks guys. Have really enjoyed working on this. The design is quite impressive and robust. Very few pieces needed to be replaced. I will have to leave the back end of the tireflator open to show off the mechanical visual features when its operating and in my shop. BTW, I am finishing up a refurb of my detached garage and the air meter will mount in this area....
Sam
Page 1 of 3 1 2 3
Page Time: 0.038s Queries: 14 (0.008s) Memory: 1.9217 MB (Peak: 2.0752 MB) Zlib disabled. Server Time: 2019-02-19 15:43:36 UTC
