cleaning rust off computer Evaporust #684776
Sat Apr 15 2017 11:17 AM
dunnville, ontario
crxnug Offline OP
crxnug  Offline OP
dunnville, ontario
I was decided to try evaporust on my Gilbarco 906 Computer, I tested one of the numbered pieces to see if it would affect paint, no effect at all. so i left Computer over night soaking inn evaporust, it came out looking great , all rust , oxidation, was removed, was very happy with the results
Re: cleaning rust off computer Evaporust [Re: crxnug] #684778
Sat Apr 15 2017 11:48 AM
hamilton
gasgeezer Offline
gasgeezer  Offline
hamilton
where do you get it at?
Re: cleaning rust off computer Evaporust [Re: crxnug] #684779
Sat Apr 15 2017 12:57 PM
Missouri,USA
Rabbitman Offline
Rabbitman  Offline
Missouri,USA
If it's the stuff they have at Harbor Freight I tried it a couple of times and did't have too great of results but maybe it was just the things I tried it on. It would take quite a bit of it to soak an entire computer, did you dilute it?...GB
Re: cleaning rust off computer Evaporust [Re: crxnug] #684780
Sat Apr 15 2017 02:10 PM
Michigan
buzzy56 Offline
buzzy56  Offline
Michigan
any pictures before and after ?
Re: cleaning rust off computer Evaporust [Re: crxnug] #684793
Sat Apr 15 2017 06:13 PM
dunnville, ontario
crxnug Offline OP
crxnug  Offline OP
dunnville, ontario
it took my 3 gallons at $25 Canadian each. i did not dilute it, i separated the bottom half and top half , the bottom half was totally covered, top half was 3/4 so i had to flip it to do both sides, let them soak for 24 hours, halfway through i got a small screw driver and scraped off any flaking rust , which took a few minutes. i,ll post some pics tomorrow
in the US you can get it here
http://www.evapo-rust.com/buy/
Re: cleaning rust off computer Evaporust [Re: crxnug] #684803
Sat Apr 15 2017 10:06 PM
Speedracer Offline
Speedracer  Offline
I use that stuff for parts all the time. I have some soaking the interior of a motorcycle gas tank as we speak. It is expensive though. $27.99/gallon at Harbor Freight in the US and you only get two maybe three uses with it. Sandblasting is a lot cheaper for simple parts and Evaporust for the complicated assemblies.
One tip I have: use the name brand Evaporust, I tried some from Home Depot called Metal Rescue and it was nowhere near the quality of Evaporust. And another good thing about Evaporust - no noxious smell and you can dump it down the drain.
Re: cleaning rust off computer Evaporust [Re: crxnug] #684809
Sun Apr 16 2017 03:21 AM
MICHIGAN
Steven C. Online content
Steven C.  Online Content
MICHIGAN
Re: cleaning rust off computer Evaporust [Re: crxnug] #684813
Sun Apr 16 2017 05:59 AM
dunnville, ontario
crxnug Offline OP
crxnug  Offline OP
dunnville, ontario
here are some before and after.
Re: cleaning rust off computer Evaporust [Re: crxnug] #684821
Sun Apr 16 2017 06:46 AM
Michigan, Union Pier
Done4 Offline
Done4  Offline
Nice job, thanks for the pics.
Re: cleaning rust off computer Evaporust [Re: crxnug] #684889
Sun Apr 16 2017 10:44 PM
Dave's Garage Offline
Turned out really good.
Dave GILL,
Re: cleaning rust off computer Evaporust [Re: crxnug] #684894
Mon Apr 17 2017 01:16 AM
MICHIGAN
MICHIGAN
I was going to try this when the time came, now there is no doubt about it!!
Thanks for the pics!! Looks awesome!!
Re: cleaning rust off computer Evaporust [Re: Steven C.] #684899
Mon Apr 17 2017 04:35 AM
Wisconsin (South Central)
RandyM Offline
RandyM  Offline
That makes two of us. Now it won't be an experiment. I have computers in far worse condition than what is shown here.
Randy
Re: cleaning rust off computer Evaporust [Re: crxnug] #685030
Wed Apr 19 2017 04:05 AM
Stockholm, Sweden
fast66 Offline
fast66  Offline
Stockholm, Sweden
As I understand it is not cheap so you need to fix a container that fit your computer well so it doesn't take too much fluid.
Some guys in the car hobby uses a tight tube to clean drive shafts...
//Claes
Re: cleaning rust off computer Evaporust [Re: crxnug] #686179
Sat May 06 2017 11:49 AM
New Jersey USA
scott1964 Offline
scott1964  Offline
New Jersey USA
Damn That's impressive.. Going to give it shot for sure..
Scott
_________________
Scott R.
Re: cleaning rust off computer Evaporust [Re: crxnug] #686570
Fri May 12 2017 04:33 PM
GA
jkyocom Offline
jkyocom  Offline
GA
Acids work better when there is no oil or grease on the object.
Veeder Root Identification CD
Gas Pump Clock Repair
jkyocom@bellsouth.net
Page Time: 0.025s Queries: 14 (0.005s) Memory: 1.9183 MB (Peak: 2.0684 MB) Zlib disabled. Server Time: 2018-06-25 10:28:12 UTC
