How I found my Shell Scheid & Bachmann from 1962 #686102
Thu May 04 2017 09:40 PM
Germany, Kaiserslautern
GermanPetroRookie Offline OP
Hi Petros
Here are the Pix how I get my Shell Pump .....
It was advertised in a german Classifiedsforum similar to your Craigslist....
The Pump was used to fill up the Little Tractors that work for a big Hothousecompany at the araea of Cologne, Germany ....
I bought it right out of its original Place.
The Pump was fully complete only the key for the case was missing ...
I had to replace one Screen . did alot of cleaning and covered a part of one sidedoor with foil because this door seems to be replaced from another Pump out of the same series but with different stripecolours ( The Super-pumps had different Striping than the Diesel-Ones at this Kind of Shell-Pumps )
Greetings
Andy
Re: How I found my Shell Scheid & Bachmann from 1962 [Re: GermanPetroRookie] #686104
Thu May 04 2017 09:53 PM
Cameron Park,Ca.
MATT ALVAREZ Offline
Cameron Park,Ca.
Nice pump. You did a great job on it. It looks a lot like a Southwest Model 45 gas pump that were made in the United States.
Re: How I found my Shell Scheid & Bachmann from 1962 [Re: MATT ALVAREZ] #686105
Fri May 05 2017 02:20 AM
Cleveland,Ohio U.S.A.
JimT Offline
JimT  Offline
Nice!
Re: How I found my Shell Scheid & Bachmann from 1962 [Re: GermanPetroRookie] #686107
Fri May 05 2017 03:36 AM
Western, IA
Stu K. Offline
Stu K.  Offline
Western, IA
That turned out really well!
Re: How I found my Shell Scheid & Bachmann from 1962 [Re: GermanPetroRookie] #686109
Fri May 05 2017 05:52 AM
Michigan, Union Pier
Done4 Offline
Done4  Offline
Very nice, cool globe.
Re: How I found my Shell Scheid & Bachmann from 1962 [Re: GermanPetroRookie] #686110
MICHIGAN
Steven C. Offline
Steven C.  Offline
MICHIGAN
I'm I correct in that that is original paint? You only cleaned it?
If I'm understanding that correctly, WOW, beautiful survivor!!!
Re: How I found my Shell Scheid & Bachmann from 1962 [Re: Steven C.] #686113
Fri May 05 2017 07:07 AM
Hi Steve
There were only a few damaged small spots that i fixed with enamel paint and this particular spot that had to be changed in Color but yes its now 95 % Original like it was made in 1962...
The Globe is a( quite cheap )gift from a friend of mine because it makes no sense to me purchasing a glassreproduction for the same amount I spent on the whole pump 4 years ago......
Some more Pix of the Procedure attached
Greetings
Re: How I found my Shell Scheid & Bachmann from 1962 [Re: GermanPetroRookie] #686114
Fri May 05 2017 07:21 AM
One more of the other side :
( BTW : even the Bulbs are Original that give better light than aftermarkettubes )
Re: How I found my Shell Scheid & Bachmann from 1962 [Re: GermanPetroRookie] #686116
Fri May 05 2017 07:32 AM
Northern California
pickurt Offline
pickurt  Offline
Northern California
Sharp, looks great.
__________________
Kurt
Re: How I found my Shell Scheid & Bachmann from 1962 [Re: GermanPetroRookie] #686119
Fri May 05 2017 07:46 AM
Plano TX
SandPCollector Offline
Plano TX
That looks gorgeous, colors really vibrant!
Regards, Jim
and the plastic coin banks both made by AVSCO.
Re: How I found my Shell Scheid & Bachmann from 1962 [Re: GermanPetroRookie] #686127
Fri May 05 2017 09:44 AM
Dave's Garage Offline
Nice gas pump!
Dave GILL,
Re: How I found my Shell Scheid & Bachmann from 1962 [Re: GermanPetroRookie] #686151
Fri May 05 2017 05:07 PM
Cameron Park,Ca.
Cameron Park,Ca.
Is it porcelain? It looks like it where there is chips.
Re: How I found my Shell Scheid & Bachmann from 1962 [Re: GermanPetroRookie] #686221
Sun May 07 2017 08:23 AM
Maryland
Nicole Offline
Nicole  Offline
Maryland
Est ist sehr schön...
Actually both your pumps are wonderful--with original colors in such good condition. I couldn't imagine this pump would look so good in a greenhouse/hothouse with such high humidity. Even the inside metal seems to have very little corrosion.
Re: How I found my Shell Scheid & Bachmann from 1962 [Re: GermanPetroRookie] #686232
Sun May 07 2017 12:18 PM
Midland, Michigan
BrianH Offline
BrianH  Offline
Midland, Michigan
Wow Andy, that pump looks so good that at first I was afraid you repainted it! Now that I know you just cleaned it up, WOW. That pump is in fabulous condition for it's age. Great pump and nice score for you.
Brian H
Re: How I found my Shell Scheid & Bachmann from 1962 [Re: GermanPetroRookie] #686235
Sun May 07 2017 01:32 PM
Peotone Illinois U.S.A
Bass Master Offline
Bass Master  Offline
Andy, Very nice pump, globe is perfect for that pump.
Page Time: 0.027s Queries: 17 (0.006s) Memory: 1.9208 MB (Peak: 2.0722 MB) Zlib disabled. Server Time: 2018-02-20 09:48:18 UTC
