diesel pumps vs. gas pumps question... #694123
Sun Sep 10 2017 04:30 AM
austin, tx
tred Offline OP
tred  Offline OP
austin, tx
did diesel pumps have a larger diameter hose and/or nozzle than gasoline pumps had?
i picked up a nice, N.O.S. brass nozzle, cheap, that was apparently meant for a diesel pump, and the inside diameter of the fitting is slightly larger than one and a half inches. i don't have a hose on my M & S 80, but i assume a one inch hose would not fit(?)
if not, is there a reducer fitting available to marry these two sizes together? i can do the research on the fitting, but i thought i'd ask while i'm asking my other question.
if not, i think i will be posting a nice, N.O.S. brass nozzle, cheap, in the classifieds section, ha aha.
thank you in advance,
tred
Re: diesel pumps vs. gas pumps question... [Re: tred] #694182
Sun Sep 10 2017 05:36 PM
austin, tx
tred Offline OP
tred  Offline OP
austin, tx
ok, so, apparently i like to leap before i look.
there IS a reducer fitting on my nozzle which is what makes it a diesel nozzle, it would allow an inch and a half hose fit into a nozzle which is meant for a one inch hose.
i removed that, it's a two-piece which i have NO idea how it would come apart, nor do i need to know. i simply removed it from the nozzle and now the same hose that fits into the outlet on the pump fits into my nozzle.
does anyone need this fitting? it's chrome like the standard fittings but then the larger, lower portion of it is brass.
FREE to a good home.
Re: diesel pumps vs. gas pumps question... [Re: tred] #694183
Sun Sep 10 2017 05:38 PM
austin, tx
tred Offline OP
tred  Offline OP
austin, tx
can't believe i posted a thread before i tried to remove the fitting...
Re: diesel pumps vs. gas pumps question... [Re: tred] #694185
Sun Sep 10 2017 05:44 PM
austin, tx
tred Offline OP
tred  Offline OP
austin, tx
i find that odd, that this is really the only difference between diesel and gasoline. haven't researched it yet.
diesel flowing through an inch and a half hose would bottle neck when it hit the nozzle itself, so why bother?
anyone?...
Re: diesel pumps vs. gas pumps question... [Re: tred] #694192
Sun Sep 10 2017 06:39 PM
Cameron Park,Ca.
MATT ALVAREZ Offline
Cameron Park,Ca.
Not all diesel pumps had the 1 inch fittings and some gasoline pumps used the one inch fittings. Some nozzles have a larger spout so there would be a faster flow.
Re: diesel pumps vs. gas pumps question... [Re: tred] #694297
Tue Sep 12 2017 06:31 AM
austin, tx
tred Offline OP
tred  Offline OP
austin, tx
well of course, i'm trying to learn which one had which
Re: diesel pumps vs. gas pumps question... [Re: tred] #694306
Tue Sep 12 2017 10:41 AM
Wisconsin (South Central)
RandyM Offline
RandyM  Offline
As Matt described, there is no set rule.
Randy
Re: diesel pumps vs. gas pumps question... [Re: tred] #694310
Tue Sep 12 2017 12:46 PM
Devils Lake, ND---USA
K W FRITH Offline
K W FRITH  Offline
Tred--I could use the fitting if you want to send it to me?
Kevin W Frith
804 Lakeview Drive
Devils Lake, ND--58301
Re: diesel pumps vs. gas pumps question... [Re: RandyM] #694317
Tue Sep 12 2017 03:59 PM
citrus heights ca.95610
hawkike Offline
hawkike  Offline
Quite a no.of years ago when diesel started showing up in service stations some used LARGER nozzles that would not fit into a cars GAS fill pipe,you would be surprised at the amount of drivers that mistakenly put diesel in their gas tank! Saw it first hand!
Re: diesel pumps vs. gas pumps question... [Re: tred] #694321
Tue Sep 12 2017 04:22 PM
Mt. Juliet, Tenn.
L
Loyd Pierce Offline
Loyd Pierce  Offline
L
Mt. Juliet, Tenn.
I have a 80 gallon tank in the bed of my diesel pickup. It and the factory tank will hold 110 gallon. So I go to the truck stops which has the large hose and nozzle for tractors trailers.
You don't find the big nozzle at the car bays.You have to knock out the flapper valve in the stock tank or it won't fit. Had a friend who put diesel in his motorcycle that didn't work well,but it was really clean when we torn it down.
Re: diesel pumps vs. gas pumps question... [Re: hawkike] #694322
Tue Sep 12 2017 04:24 PM
Texas
L
ldj Offline
ldj  Offline
L
Texas
Putting diesel in a gas vehicle isn't good thing but on the other hand it isn't bad. Putting gas in a diesel vehicle is a bad thing, no doubt about it.
Re: diesel pumps vs. gas pumps question... [Re: ldj] #694337
Tue Sep 12 2017 06:08 PM
hawkike Offline
hawkike  Offline
Are you suggesting that gasoline engines run well on diesel?
Re: diesel pumps vs. gas pumps question... [Re: hawkike] #694347
Tue Sep 12 2017 08:20 PM
Texas
L
ldj Offline
ldj  Offline
L
Texas
No,not today's modern computer controlled ones. Actually the computer might make enough changes that they might run pretty good. Diesel engines will run off kerosene or diesel and so will jet engines. I've had old tractors that you start on gas and after they warm up you turn off the gas and turn on the kerosene and they run good on it. When we were kids in early 50's and didn't have much money and gas was .25 gal and kerosene was .10 we would put kerosene in our old cars and they run well but smoked some. Next day when engine was cold you had to rig up a gas can direct to car. to get it started.
what I suggested was if you put diesel in a gas engine you will have problems but not harm the engine but if you put gas in a diesel engine you may blow up the engine.
Re: diesel pumps vs. gas pumps question... [Re: tred] #694415
Wed Sep 13 2017 06:11 PM
austin, tx
tred Offline OP
tred  Offline OP
austin, tx
cool, we're SO FAR off topic now i think i'll give up and just go turn my car on in the garage with the door shut and the car windows down!
damnit!!!
i drive a prius...
Re: diesel pumps vs. gas pumps question... [Re: tred] #694422
Wed Sep 13 2017 06:56 PM
Parkersburg, WV 26101
Keystone Gas Man Offline
And....No Contains Lead signs on the pump.
Page Time: 0.025s Queries: 14 (0.005s) Memory: 1.9185 MB (Peak: 2.0714 MB) Zlib disabled. Server Time: 2018-06-25 08:27:56 UTC
