#693544
Thu Aug 31 2017 01:29 PM
Posts: 19 |
Hello, My name is Jay. I am new to this forum. I just bought my first porcelain sign because I wanted one for a long time and the price was right. I collect other things and know the rules of restoration on them. I don't know about signs. Should they be cleaned as close to original condition as possible or left as found? I wiped it down with soap and water but there is a lot of tough stuff that stayed on.
Posts: 2,785 Likes: 165
Posts: 2,785 Likes: 165 |
As long as you don't damage sign absolutely clean it. And being porcelain you can't hurt it.
Posts: 1,165 Likes: 46
Posts: 1,165 Likes: 46 |
Welcome to Oldgas. Most like to clean a sign as well as possible without compromising it's integrity as far as paint or finish goes. Since porcelain is essentially glass it is pretty impervious to cleaners and the finish won't come off by simply washing it. A lot of old signs will have paint overspray or other things built up on them that won't just wash off with soap and water so you will have to use something that will remove those things like thinners or rubbing compound. Mild abrasive cleaners like Barkeepers Friend work pretty well to removed rust stains and heavier contaminants and even fine grade steel wool will work to remove old paint overspray. If it has been painted over or is covered with a lot of paint you can use paint remover without harming the porcelain....GB
Posts: 8,513 Likes: 293
Posts: 8,513 Likes: 293 |
Welcome to Oldgas.com
Use the "Google Custom Search" form on the top right corner of this page to search for:
Cleaning porcelain signs
You'll see a number of past topics on this forum on that subject with the experience of knowledgeable members.
Posts: 1,764 Likes: 88
Posts: 1,764 Likes: 88 |
Welcome to Oldgas. Best of luck with your sign!
Regards, Jim
I usually clean our signs-especially porcelain. I just want to say though, some signs that are a bit off condition look better (to me )When they have the original "look". When they are displayed together they have an old time feel. Sometimes they just dont look right all cleaned up with a bunch of clean chips and scratches.
Posts: 19 |
Thank you everybody! Once I figure this site out I will post some photos so you can see the condition.
Posts: 19 |
Another question about my Skelly sign. This sign measures 5x5 diagonal and has its original frame. It has two eyes welded to the frame, so I am guessing it was a hanging sign not one mounted solid to the top of a post. My question is does the frame add value. Most of these signs I see do not have a frame. I don't know if this is because people think they display better that way, of it they simply do not have a frame. Thanks again, Jay
Posts: 2,085 Likes: 11
Posts: 2,085 Likes: 11 |
original frame adds value. 200.00
Posts: 19 |
Posts: 19 |
I finally got some pictures uploaded of my Skelly sign. does it look like a good quality sign? Does anyone have an opinion as to weather or not I should leave it looking like this or clean it up? The dirtiest parts in the corners and at the edges actually have a shine or gloss to them which makes me wonder if there might be a clear finish over them. if this is the case I may to need to use some kind of a harsh stripper. thanks, Jay
Posts: 19 |
These four pictures show the only damage to the signs porcelain between both sides. is there likely to be damage hidden beneath the frame? I am afraid to try to take it out of the frame.
Posts: 2,737 Likes: 61
Posts: 2,737 Likes: 61 |
That sign is definitely of "clean it!" quality.....so yes, clean 'er up! Darin
Posts: 19 |
I got it hung up yesterday. this is how it displays on its best side.
Would look nicer to me if you cleaned it up. But if you like the patina, that's all that matters. Seriously doubt that it has ever been cleared.
