#688218 Thu Jun 08 2017 09:56 PM
I just got this pump today. What is the sign for? On the other side of the sign it has 100
hotrodfun1 #688226 Fri Jun 09 2017 03:14 AM
I would say octane rating.
hotrodfun1 #688227 Fri Jun 09 2017 03:23 AM
Here's another one like it.
hotrodfun1 #688231 Fri Jun 09 2017 05:23 AM
I'm sure Octane rating !!! Notice a newer pump a lower rating !!
hotrodfun1 #688235 Fri Jun 09 2017 06:26 AM
N
N
Probably came from airport 80/87 and 100/130 are grades of avgas
I collect Phillips 66 and globes pumps & signs esp Iowa co.
hotrodfun1 #688239 Fri Jun 09 2017 08:31 AM
Great Pump and I'll go with avgas also
hotrodfun1 #688249 Fri Jun 09 2017 11:32 AM
Thanks for the help that explains why the other side of the sign only has 100 so they must flip the sign when it is only 100 avgas. He did say he got the pump from a airport.
hotrodfun1 #688252 Fri Jun 09 2017 11:55 AM
Well I am thinking about it would you restore it or leave as is? I know it is my pump but if you had it what would you do the only reason I ask is it was green originally.
hotrodfun1 #688269 Fri Jun 09 2017 02:10 PM
Clean and let it be. Looks good to me.
hotrodfun1 #688271 Fri Jun 09 2017 02:20 PM
...um, have you looked to see if it's green porcelain underneath the red paint?...even if it isn't, I'd remove the pump signs...they're not particularly interesting, and not original to the pump...
hotrodfun1 #688273 Fri Jun 09 2017 02:49 PM
Yes I have it is not porcelain. you wood remove the stickers also or just the avgas sign on one side?
hotrodfun1 #688331 Sat Jun 10 2017 09:12 PM
O
O
Very nice National Scott. Looks excellent. Yes, I would remove that 100/130 sign also.
hotrodfun1 #701795 Wed Jan 03 2018 11:47 PM
So I pulled the sign off and cleaned and wired up the lights. I am now thinking about putting a globe top on it and putting on a flying a globe what do you think?
hotrodfun1 #701796 Thu Jan 04 2018 12:27 AM
Also how do I tell if I have the right top that takes the globe holder? I think there is two tops but not sure thanks for the help.
hotrodfun1 #701802 Thu Jan 04 2018 05:55 AM
If it doesn’t already have a globe holder then it’s not a globe top. Chris
