Page 1 of 4 1 2 3 4
Anyone converted Wayne 70 to a Wayne 71 showcase? #594701
Tue Jan 27 2015 06:01 PM
Indiana
bagged1961 Offline OP
Indiana
Just curious if anyone has used the aftermarket Wayne 71 showcase parts to convert a Wayne 70 to a display pump? I noticed the bases the main piece that they do not produce.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #594702
Tue Jan 27 2015 06:03 PM
Devils Lake, ND---USA
K W FRITH Online content
K W FRITH  Online Content
I don't think it would be possible.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: K W FRITH] #594726
Tue Jan 27 2015 07:23 PM
Humble, TX
SKomatinsky Offline
SKomatinsky  Offline
Humble, TX
Could be done but you have to really be top notch with metal fabrication to pull it off. Craig said it was a pain to get an original aligned when putting back together, so I can only imagine how hard it is to fabricate
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: SKomatinsky] #594771
Wed Jan 28 2015 12:41 AM
St. Louis, MO, USA
Jack Sim Offline
Jack Sim  Offline
St. Louis, MO, USA
Seriously, the 70 is about 24" wide, the 71 is about 36" wide. Enough said.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: Jack Sim] #594831
Wed Jan 28 2015 09:35 AM
Alabama, USA
Dale Stephens Offline
Alabama, USA
PM sent...
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: Dale Stephens] #594989
Wed Jan 28 2015 08:04 PM
Portland Oregon
Craig Osbeck Offline
Portland Oregon
It is difficult, but possible with the middle and bottom doors. Good metal body man can make that happen, but the top door would require metal to be taken off both sides in order to fit. Could be wrong also, but think the sight glass is different also.
If they could make a Wayne 50 then anything is possible.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #703997
Tue Feb 06 2018 06:13 PM
Indiana
Indiana
Finally progress on our wayne 70 to 71 showcase conversion. Got 1 door hinged and internal structure braced and upper panels are mounted. Been a slow process but making headway as of late.
[Linked Image]
[Linked Image]
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704006
Tue Feb 06 2018 08:26 PM
Portland Oregon
Portland Oregon
It is looking good. There is lots of time involved for sure but like anything else it can be done. With the reproduction doors you can fit the body to the doors verses the other way around. Filling in the base also I see. Looking forward to seeing the final product. Good luck with it.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704025
Wed Feb 07 2018 09:15 AM
South of St. Louis, MO USA
Oldgas Offline
Oldgas  Offline
Looks like it is coming along nicely. A lot like doing custom fabrication on a chopped and channeled hot rod. Takes some skill and creativity to get it to come out right. Keep posting pictures as you go.
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: Jack Sim] #704045
Wed Feb 07 2018 04:31 PM
Tacoma,Wash. USA
tjhvintage Offline
tjhvintage  Offline
Tacoma,Wash. USA
Nice metal work! You obviously have some great fabrication skills.
a.) looks like it may be possible
b.) it appears there's more to be said.
Member #163
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: tjhvintage] #704050
Wed Feb 07 2018 05:59 PM
Lodi, CA.
Signal Gas & Oil Offline
Lodi, CA.
The can't be done looks like might be done. I have a metal working guy does this kind of stuff all the time.Good job. Keep it up.
Ted Pam Ethyl & Polly Roach
Lodi CA.
209-210-8971
Looking for Signal, Hancock, Mohawk, Douglas, Gilmore and Richfield
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704051
Wed Feb 07 2018 06:07 PM
Duluth, MN U.S.A
Ryan Underthun Online content
Ryan Underthun  Online Content
Duluth, MN U.S.A
I dont think this would be all that difficult to do. The hardest parts needed are available through gas pump heaven. The gas manifold is the same as early 70's as well as the computer mounts ect. The hardest part would be making the electrical manifold for the showcase and fabricating the top. I would think that a base could be made pretty easy out of 2 and if done correctly I dont think you would be able to tell that it was not a factory 71 base.
visit my website for original gas pumps and parts
www.thepumpdump.com
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: Ryan Underthun] #704069
Wed Feb 07 2018 11:00 PM
Cleveland,Ohio U.S.A.
JimT Offline
JimT  Offline
The top might be kind of tough-no?
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: JimT] #704086
Thu Feb 08 2018 08:37 AM
Louisville, Kentucky
LOWright Offline
LOWright  Offline
I knew if it could be done, you guys could do it! Looks great! Watching....
Re: Anyone converted Wayne 70 to a Wayne 71 showcase? [Re: bagged1961] #704116
Thu Feb 08 2018 06:41 PM
Alabama, USA
Alabama, USA
I did one of these about 4 years ago. To do the top, I cut 2 tops up and welded them together to form the wide top needed and as someone already mentioned, I cut 2 bases apart and welded them together to form the wide base. I'm just a flunky when it comes to welding and body work but it really turned out well. I'd post the pictures of it but I don't have them stored in my computer, only on my phone. If someone would post them I could sent them through a text message....Dale
Page 1 of 4 1 2 3 4
Page Time: 0.102s Queries: 14 (0.030s) Memory: 1.9219 MB (Peak: 2.0730 MB) Zlib disabled. Server Time: 2019-03-21 20:44:03 UTC
